El contenido no se encuentra disponible en el idioma seleccionado. Estamos trabajando continuamente para agregar más idiomas. Gracias por su apoyo.
- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Show all
Quick Configuration Center
The COC quick configuration center provides a centralized configuration entry for all Huawei Cloud cloud services, catering to various O&M scenarios. It enables automated operations across multiple regions and accounts, following a predetermined schedule and utilizing simplified configurations derived from best practices. This reduces the complexity of subsequent O&M tasks.
You can use the quick configuration center to quickly configure resources in different scenarios.
COC Configurations
- Log in to COC.
- On the Overview page of COC, you can view the quick configuration center module.
Figure 1 Quick configuration centerIf the quick configuration center (shown in Figure 1) module is not displayed on the Overview page, click Quick Configuration Center on the top to access it.Figure 2 Quick configuration center entry
- Click a card for a specific O&M scenario to go to the configuration page of the corresponding scenario.
- Go to the Quick Configuration Center page and click Execute corresponding to different types of configuration tasks.
Figure 3 Selecting a scenario for configuration
