Updated on 2026-08-21 GMT+08:00
Creating Alarm Rules
You can create alarm rules to monitor the usage of OBS resources or key operations on OBS resources. After an alarm rule is created, Cloud Eye immediately notifies you of any exceptions with your OBS resources in real time if the monitoring metric reaches the specified threshold or a specified event occurs.
Billing
If you use SMN to send alarm notifications, you will be billed for the message notifications and downstream Internet traffic. For details, see Billing.
Permissions Control
To set alarm rules, your account must have the CES FullAccess permission. If you are prompted that you do not have the required permissions, contact the administrator for authorization. For details, see Assigning Permissions to an IAM User.
Setting Alarm Rules
  1. Go to the Create Alarm Rule page of the Cloud Eye console.
  2. Configure the alarm name as prompted.
    Figure 1 Configuring the alarm name
    Table 1 Basic information parameters of an alarm rule
    Example Value
    Name
    alarm-obs
    Name of the alarm rule. The system generates a name randomly, and you can change it as you want.
    The name can contain a maximum of 128 characters. Only letters, digits, underscores (_), and hyphens (-) are allowed.
  3. Select an alarm type.
    • If you select Metric for Alarm Type, you can create an alarm rule for OBS metrics. Then go to 4.
    • If you select Event for Alarm Type, you can create an alarm rule for OBS events. Then go to 5.
  4. Configure alarm policies.
    Configure the key parameters as described below. Keep the default settings for other parameters. For details about how to set alarm rule parameters, see Creating an Alarm Rule.
    Table 2 Key parameters for creating an alarm rule (metric monitoring)
    Example Value
    Alarm Type
    Metric
    Select the alarm type for which you want to set an alarm rule. The following types are supported:
    • Metric: Set an alarm threshold for a metric to trigger an alarm.
    • Event: Set an alarm rule for event monitoring. When a specified event occurs, an alarm is triggered.
    Cloud Product
    Object Storage Service - Bucket Name
    Select the cloud service for which the alarm is reported. OBS supports the following two dimensions:
    • Object Storage Service - Bucket Name: If you select the bucket name dimension, the alarm rule takes effect for metrics of a single bucket.
    • Object Storage Service-User: If you select the user dimension, the alarm rule takes effect for aggregated metrics of all buckets of the user.
    Resource Level
    Cloud product (Recommended)
    Resource level of the monitored object. You can select Cloud product or Specific dimension.
    • Cloud product (Recommended): Alarm rules can be configured across dimensions.
    • Specific dimension: Alarm rules cannot be configured across dimensions.
    Monitoring Scope
    Specific resources
    Scope of resources for which the alarm rule takes effect in the specified dimension. The following options are supported:
    • All resources: An alarm will be triggered when the metric of any resource (including newly created ones) in the specified dimension meets the alarm policy.
    • Resource groups: An alarm is triggered when the metric of resources in the selected group in the specified dimension meets the alarm policy.
    • Specific resources: An alarm is triggered when the metric of the specific resources in the specified dimension meets the alarm policy.
    Use Template (Optional)
    Custom alarm template used to set the alarm triggering rule.
    This parameter is mandatory when an alarm policy template is required.
    For details about how to create a custom alarm template, see Creating a Custom Metric or Event Template.
    Alarm Policy
    If the number of GET requests for a specified bucket reaches the following threshold for three consecutive times:
    • ≥ 10,000, a warning alarm is triggered.
    • ≥ 50,000, a minor alarm is triggered.
    • ≥ 100,000, a major alarm is triggered.
    • ≥ 150,000, a critical alarm is triggered.
    In addition, after an alarm is triggered, the alarm is reported every hour.
    The preceding descriptions are only examples. Configure the policy based on your service requirements.
    Select the monitoring metric you want to set for the alarm policy. For details about the monitoring metrics, see OBS Monitoring Metrics.
    This parameter is mandatory when no alarm policy template is used.
  5. Configure an event alarm policy.
    Table 3 Key parameters for creating an alarm rule (event monitoring)
    Example Value
    Alarm Type
    Event
    Event Type
    System event
    This parameter is required if Alarm Type is set to Event. You can select System event or Custom event.
    • System event: The alarm rule takes effect for system-defined events.
    • Custom event: The alarm rule takes effect for events generated by a specified event source.
    Event Source
    Source of the event for which the alarm rule takes effect.
    • If Event Type is set to System event and Event Source is set to a specified cloud service, the alarm rule takes effect for the events defined by the cloud service system.
    • If Event Type is set to Custom event and Event Source is set to a specified resource, the alarm rule takes effect for events from the specified source. For details about the event source configuration requirements, see the event_source parameter.
    Monitoring Scope
    Specific resources
    Scope of resources for which the alarm rule takes effect. The following types are supported:
    • All resources: An alarm will be triggered when the event of any resource (including newly created ones) meets the alarm policy.
    • Specific resources: An alarm will be triggered when the event of a specific resource meets the alarm policy.
    Custom event alarm template used to set the event alarm triggering rule.
    Alarm Policy
    • If the Create bucket event is triggered 10 times Within 5 minutes, a Major alarm is generated Every 5 minutes.
    • If the Delete bucket event is triggered 1 times Within 5 minutes, a Major alarm is generated Every 5 minutes.
    • If the Set bucket policy event is triggered 1 times Within 5 minutes, a Minor alarm is generated Hourly.
    Select the event you want to set to configure the alarm policy. For details about event monitoring, see Monitored OBS Events.
  6. Click Create.
    If the new alarm rule is displayed in the alarm rule list, the rule is created successfully.
Managing Alarm Rules
You can perform the operations listed below on alarm rules.
Table 4 Managing alarm rules
Operation
Modifying an Alarm Rule
If your service changes or you need to replan an alarm rule, you can modify it.
Enabling Alarm Rules
After maintaining or upgrading a cloud product, you can enable the alarm rule again. After an alarm rule is enabled, its notification is automatically restored.
Disabling Alarm Rules
If you need to manually stop a cloud service for maintenance or upgrade, you can disable the alarm rule to prevent unnecessary alarm notifications caused by manual changes.
Deleting Alarm Rules
If an alarm rule does not meet your requirements, you can delete it. After an alarm rule is deleted, you will not receive alarm notifications for the alarm rule.
Modifying the Notification Settings of an Alarm Rule
If the notification settings of an alarm rule do not meet your requirements, you can modify them.
Configuring Global Notifications
When managing multiple alarm rules, you can configure global alarm notifications through notification policies. You can click Global Notifications on the Alarm Rules page to easily configure notification policies that apply to all alarm rules. This greatly simplifies the alarm rule configuration process and improves O&M efficiency.
Viewing Alarm Records
When a monitoring metric reaches the threshold specified in an alarm rule or an event occurs, you can view monitoring details on the Alarm Records page.
Alarm Notifications
Once alarm notifications are configured, the system notifies you in real time through SMS messages, emails, or voice calls whenever a cloud service metric breaches an alarm threshold. This allows you to stay informed of the status changes of your cloud resources. For details about how to create a notification policy, see Creating a Notification Policy.
You can configure alarm notifications when creating an alarm rule. For details, see Creating an Alarm Rule. You can also modify alarm notifications after an alarm rule is created. For details, see Modifying the Notification Settings of an Alarm Rule.
