Console Function Overview
Table 1 lists functions provided by OBS Console.
Function |
Description |
Allow you to create and delete buckets of different storage classes in specified regions (service areas), copy existing bucket configurations, as well as change bucket storage classes. |
Allow you to manage objects, including uploading (multipart upload included), downloading, sharing, and deleting objects, as well as changing object storage classes and restoring Archive objects. |
Encrypts objects on the server side to enhance security of objects stored on OBS. |
Protects objects from being deleted or tampered with within a specified period. |
Allows you to set properties for objects. |
With Cloud Trace Service (CTS), you can record data operations associated with OBS for later query, audit, and backtrack operations. |
Manages and clears fragments generated due to object upload failures. |
Stores multiple versions of an object in the same bucket. |
Logs bucket access requests for analysis and auditing. |
Controls access to OBS using IAM permissions, bucket/object policies, and bucket/object access control lists (ACLs). |
Allows you to configure lifecycle rules to periodically expire and delete objects or transition objects between storage classes. |
Implements object replication across regions under the same account. A cross-region replication rule enables OBS to automatically, asynchronously copy data from a source bucket in one region to a destination bucket in a different region. This provides disaster recovery across regions, catering to your needs for remote backup. |
Help you identify and classify buckets in OBS. |
Supports the hosting of static websites in buckets and the redirection of access requests for buckets. |
Enables you to bind your website domain name to a bucket domain name. If you want to migrate files from your website to OBS while keeping the website address unchanged, you can use this function. |
Helps you obtain the requested data from the source site if the data is not found in OBS. Usually, if the data you requested is not found in OBS, a 404 error will be returned. |
Prevents object links in OBS from being stolen by other websites. |
Allows a web client in one origin to interact with resources in another one. Cross origin resource sharing (CORS) is a browser-standard mechanism defined by the World Wide Web Consortium (W3C). For general web page requests, website scripts and contents in one origin cannot interact with those in another because of Same Origin Policies (SOPs). |
Allows you to directly download objects in the Archive storage class without restoring them first. Direct reading is a billable function. |
Periodically provides CSV files that list object information in the bucket and delivers the CSV files to the specified bucket. |
