Help Center/ Data Lake Insight/ User Guide/ Submitting a Spark Jar Job Using Livy
Updated on 2026-01-08 GMT+08:00
Introduction to DLI Livy
DLI Livy is an Apache Livy-based client tool used to submit Spark jobs to DLI.
Preparations
  • Create an elastic resource pool and create queues within it. When creating a queue, select General-purpose, which is the compute resources used to run Spark jobs. For details, see Creating a Queue.
  • Prepare a Linux ECS for installing DLI Livy.
    • Enable ports 30000 to 32767 and port 8998 on the ECS. For details, see Adding a Security Group Rule.
    • Install JDK on the ECS. JDK 1.8 is recommended. Configure Java environment variable JAVA_HOME.
    • View the ECS details to obtain its private IP address.
  • Use an enhanced datasource connection to connect the DLI queue to the VPC where the Livy instance is located. For details, see Enhanced Datasource Connection.
Step 1: Download and Install DLI Livy
The software package used in the following operations is apache-livy-0.7.2.0107-bin.tar.gz. Replace it with the latest one.
  1. Download the DLI Livy software package.
  2. Use WinSCP to upload the obtained software package to the prepared ECS directory.
  3. Log in to ECS as user root and perform the following steps to install DLI Livy:
    1. Run the following command to create an installation directory:
      mkdir Livy installation directory
      For example, to create the /opt/livy directory, run the mkdir /opt/livy command. The following operations use the /opt/livy installation directory as an example. Replace it as required.
    2. Run the following command to decompress the software package to the installation directory:
      tar --extract --file apache-livy-0.7.2.0107-bin.tar.gz --directory /opt/livy --strip-components 1 --no-same-owner
    3. Run the following commands to change the configuration file name:
      cd /opt/livy/conf
      mv livy-client.conf.template livy-client.conf
      mv livy.conf.template livy.conf
      mv livy-env.sh.template livy-env.sh
      mv log4j.properties.template log4j.properties
      mv spark-blacklist.conf.template spark-blacklist.conf
      touch spark-defaults.conf
Step 2: Modify the DLI Livy Configuration File
  1. Upload the specified DLI Livy JAR package to the OBS bucket directory.
    1. Log in to OBS console and create a directory for storing the DLI Livy JAR package in the specified OBS bucket, for example: obs://bucket/livy/jars/.
    2. Go to the installation directory of the ECS where the DLI-Livy tool has been installed in 3.a, obtain Livy JAR packages, and upload them to the OBS bucket directory created in 1.a:
      For example, if the installation path is /opt/livy, the JAR packages you need to upload are as follows:
      /opt/livy/rsc-jars/livy-api-0.7.2.0107.jar
      /opt/livy/rsc-jars/livy-rsc-0.7.2.0107.jar
      /opt/livy/repl_2.11-jars/livy-core_2.11-0.7.2.0107.jar
      /opt/livy/repl_2.11-jars/livy-repl_2.11-0.7.2.0107.jar
  2. Modify the DLI Livy configuration file.
    1. Run the following command to modify the /opt/livy/conf/livy-client.conf configuration file:
      vi /opt/livy/conf/livy-client.conf
      Add the following content to the file and modify the configuration items as required:
      # Set the private IP address of the ECS, which can be obtained by running the ifconfig command.
      livy.rsc.launcher.address = X.X.X.X
      # Set the ports enabled on the ECS.
      livy.rsc.launcher.port.range = 30000~32767
    2. Run the following command to modify the /opt/livy/conf/livy.conf configuration file:
      vi /opt/livy/conf/livy.conf
      livy.server.port = 8998
      livy.spark.master = yarn
      livy.server.contextLauncher.custom.class=org.apache.livy.rsc.DliContextLauncher
      livy.server.batch.custom.class=org.apache.livy.server.batch.DliBatchSession
      livy.server.interactive.custom.class=org.apache.livy.server.interactive.DliInteractiveSession
      livy.server.sparkApp.custom.class=org.apache.livy.utils.SparkDliApp
      livy.server.recovery.mode = recovery
      livy.server.recovery.state-store = filesystem
      # Change the following file directory of DLI Livy as needed:
      livy.server.recovery.state-store.url = file:///opt/livy/store/
      livy.server.session.timeout-check = true
      livy.server.session.timeout = 1800s
      livy.server.session.state-retain.sec = 1800s
      livy.dli.spark.version = 2.3.2
      livy.dli.spark.scala-version = 2.11
      # Enter the OBS bucket path that stores the Livy JAR file.
      livy.repl.jars = obs://bucket/livy/jars/livy-core_2.11-0.7.2.0107.jar, obs://bucket/livy/jars/livy-repl_2.11-0.7.2.0107.jar
      livy.rsc.jars = obs://bucket/livy/jars/livy-api-0.7.2.0107.jar, obs://bucket/livy/jars/livy-rsc-0.7.2.0107.jar
    3. Run the following command to modify the /opt/livy/conf/spark-defaults.conf configuration file:
      vi /opt/livy/conf/spark-defaults.conf
      Add the following content to the file. Set the parameters based on Table 1.
      # The following parameters can be overwritten when a job is submitted.
      spark.yarn.isPython=true
      spark.pyspark.python=python3
      # Enter the production environment URL of DLI.
      spark.dli.user.uiBaseAddress=https://console.huaweicloud.com/dli/web
      # Set the region where the queue is located.
      spark.dli.user.regionName=XXXX
      # Set the DLI endpoint address.
      spark.dli.user.dliEndPoint=XXXX
      # Enter the name of the created DLI queue.
      spark.dli.user.queueName=XXXX
      # Set the project ID used for submitting a job.
      spark.dli.user.projectId=XXXX
      Table 1 Mandatory parameters in spark-defaults.conf
      Name of the region where the DLI queue is.
      Obtain the region name from Regions and Endpoints.
      Endpoint where the DLI queue is located.
      Obtain the endpoint from Regions and Endpoints.
      Queue name.
      spark.dli.user.access.key
      User's AK/SK. The user must have Spark job permissions. For details, see Permissions Management.
      For how to obtain the AK/SK, see Obtaining the AK/SK.
      spark.dli.user.secret.key
      Project ID. Obtain it by referring to Obtaining a Project ID.
      The following parameters are optional. Set them based on the parameter description and site requirements. For details about these parameters, see Spark Configuration.
      Table 2 Optional parameters in spark-defaults.conf
      Spark Job Parameter
      Spark Batch Processing Parameter
      Remarks
      spark.dli.user.file
      file
      Not required for connecting to the notebook tool
      spark.dli.user.className
      class_name
      spark.dli.user.scType
      sc_type
      Same as the native Livy configuration
      spark.dli.user.args
      args
      spark.submit.pyFiles
      python_files
      spark.files
      files
      spark.dli.user.modules
      modules
      spark.dli.user.image
      Custom image used for submitting a job. This parameter is available for container clusters only and is not set by default.
      spark.dli.user.autoRecovery
      auto_recovery
      spark.dli.user.maxRetryTimes
      max_retry_times
      spark.dli.user.catalogName
      catalog_name
      To access metadata, set this parameter to dli.
Step 3: Start DLI Livy
  1. Run the following command to go to the DLI Livy installation directory:
    Example: cd /opt/livy
  2. Run the following command to start DLI Livy:
    ./bin/livy-server start
Step 4: Submit a Spark Job to DLI Using DLI Livy
The following demonstrates how to submit a Spark job to DLI using DLI Livy and by running the curl command.
  1. Upload the JAR file of the developed Spark job program to the OBS directory.
    For example, upload spark-examples_2.11-XXXX.jar to the obs://bucket/path directory.
    When writing output data from Spark Jar jobs to OBS, you need to configure an AK/SK for accessing OBS. To ensure the security of AK/SK data, you can use DEW and CSMS for centralized management of AK/SK. This approach effectively mitigates risks such as sensitive information leakage caused by hardcoding in programs or plaintext configurations, as well as potential business disruptions due to unauthorized access.
    For details, see Obtaining Temporary Credentials from a Spark Job's Agency for Accessing Other Cloud Services.
  2. Log in to the ECS server where DLI Livy is installed as user root.
  3. Run the curl command to submit a Spark job request to DLI using DLI Livy.
    ECS_IP indicates the private IP address of the ECS where DLI Livy is installed.
    curl --location --request POST 'http://ECS_IP:8998/batches' \
    --header 'Content-Type: application/json' \
    --data '{
        "driverMemory": "3G",
        "driverCores": 1,
        "executorMemory": "2G",
        "executorCores": 1,
        "numExecutors": 1,
        "args": [
            "1000"
        "file": "obs://bucket/path/spark-examples_2.11-XXXX.jar",
        "className": "org.apache.spark.examples.SparkPi",
        "conf": {
            "spark.dynamicAllocation.minExecutors": 1,
            "spark.executor.instances": 1,
            "spark.dynamicAllocation.initialExecutors": 1,
            "spark.dynamicAllocation.maxExecutors": 2
