Help Center/ Data Lake Insight/ User Guide/ Creating an Elastic Resource Pool and Creating Queues Within It/ Creating an Elastic Resource Pool and Creating Queues Within It
Updated on 2026-09-08 GMT+08:00
An elastic resource pool offers compute resources (CPU and memory) required for running DLI jobs, which can adapt to the changing demands of services.
You can create multiple queues within an elastic resource pool. These queues are associated with specific jobs and data processing tasks, and serve as the basic unit for resource allocation and usage within the pool. This means queues are specific compute resources required for executing jobs.
Queues within an elastic resource pool can be shared to execute jobs. This is achieved by correctly setting the queue allocation policy. This enhances queue utilization. This section describes how to create an elastic resource pool and create queues within it.
DLI elastic resource pools are physically isolated, while queues within the same elastic resource pool are logically isolated.
You are advised to create separate elastic resource pools for testing and production scenarios to ensure the independence and security of resource management through physical isolation.
Notes and Constraints
Table 1 Notes and constraints on elastic resource pools
Item
Resource specifications
  • An elastic resource pool currently supports up to 32,000 CUs.
  • Minimum CUs of a queue that can be created in an elastic resource pool:
    • For general purpose queue: 4 CUs
    • For SQL queue (Spark SQL queue): 8 CUs
Billing mode
  • Billing mode of the elastic resource pool, which can be pay-per-use or yearly/monthly.
  • You cannot change the billing mode once the elastic resource pool is created.
  • Currently, you can only change the specifications of yearly/monthly elastic resource pools.
  • For a pay-per-use elastic resource pool, Dedicated Resource Mode is selected by default. The resource pool is billed by the calendar hour since it is created.
  • A pay-per-use elastic resource pool can be deleted 15 minutes after its successful creation.
Managing elastic resource pools
  • You cannot change the region of an elastic resource pool once the pool is created.
  • Flink 1.10 or later jobs can run in elastic resource pools.
  • The CIDR block of an elastic resource pool cannot be changed once set.
  • You can view only the scaling history of an elastic resource pool within 30 days.
  • Elastic resource pools cannot directly access the Internet.
Associating an elastic resource pool with a queue
  • Associating an elastic resource pool with a queue:
    • Only pay-per-use queues (including dedicated queues) can be associated with elastic resource pools.
    • No resources are frozen.
Elastic resource pool scaling
  • Changes to elastic resource pool CUs can occur when setting the CU, adding or deleting queues in an elastic resource pool, or modifying the scaling policies of queues in an elastic resource pool, or when the system automatically triggers elastic resource pool scaling. However, in some cases, the system cannot guarantee that the scaling will reach the target CUs as planned.
    • If there are not enough physical resources, an elastic resource pool may not be able to scale out to the desired target size.
    • The system does not guarantee that an elastic resource pool will be scaled in to the desired target size.
      The system checks the resource usage before scaling in the elastic resource pool to determine if there is enough space for scaling in. If the existing resources cannot be scaled in according to the minimum scaling step, the pool may not be scaled in successfully or only partially.
      The scaling step may vary depending on the resource specifications, usually 16 CUs, 32 CUs, 48 CUs, 64 CUs, and more.
      For example, if the elastic resource pool has a capacity of 192 CUs and the queues in the pool are using 68 CUs due to running jobs, the plan is to scale in to 64 CUs.
      When executing a scaling in task, the system determines that there are 124 CUs remaining and scales in by the minimum step of 64 CUs. However, the remaining 60 CUs cannot be scaled in any further. Therefore, after the elastic resource pool executes the scaling in task, its capacity is reduced to 128 CUs.
    • If jobs such as Flink or Spark Streaming jobs are continuously running on a node, that node cannot be scaled in as scheduled.
Constraints for setting elastic resource pool CUs
  • The minimum CUs (minCU) of an elastic resource pool must be less than or equal to the actual CUs. If expanding minCU exceeds the current actual CUs, you must first increase the actual CUs. Otherwise, the modification will fail.
  • The sum of all queues' minimum CUs in an elastic resource pool must not exceed the pool's minCU.
  • Any single queue's maxCU cannot exceed the pool's maxCU.
  • Adjustments to a queue's CU range, changes to the pool's specifications, or modifications to the pool's CU settings take effect at the next full hour.
  • Increasing the number of queues to adjust the pool's actual CUs takes immediate effect.
  1. In the navigation pane, choose Resources > Resource Pool.
  2. On the displayed page, click Buy Resource Pool in the upper right corner.
  3. On the displayed page, set the following parameters:
    Table 2 Parameter descriptions
    Region
    Select a region where you want to buy the elastic resource pool. A region refers to the location of the physical data center of an elastic resource pool. Select a region near you to ensure the lowest latency possible.
    Project
    Each region corresponds to a project.
    Name
    Name of the elastic resource pool.
    • Only digits, letters, and underscores (_) are allowed. The value cannot contain only digits or start with an underscore (_) or digit.
    • The value can contain a maximum of 128 characters.
    The elastic resource pool name is case-insensitive. Uppercase letters will be automatically converted to lowercase letters.
    Type
    • Basic edition: offers 16 CUs to 64 CUs
      • This edition is suitable for testing scenarios with low resource consumption and low requirements for resource reliability and availability.
      • High reliability and availability are not supported.
      • Job priorities cannot be set.
    • Standard edition: offers at least 64 CUs
      This edition offers powerful computing capabilities, high availability, and flexible resource management. It is suitable for large-scale computing tasks and business scenarios with long-term resource planning needs.
    CU Range
    The maximum and minimum CUs allowed for the elastic resource pool.
    CU settings are used to control the maximum and minimum CU ranges for elastic resource pool scaling to prevent unlimited resource expansion risks.
    In CU Range, set the minimum CUs on the left and the maximum CUs on the right.
    • The total minimum CUs of all queues in an elastic resource pool must be no more than the minimum CUs of the pool.
    • The maximum CUs of any queue in an elastic resource pool must be no more than the maximum CUs of the pool.
    An elastic resource pool should at least ensure that all queues in it can run with the minimum CUs and should try to ensure that all queues in it can run with the maximum CUs.
    The specifications (yearly/monthly CUs) of an elastic resource pool are equal to the minimum CUs allocated during creation. This means that when the elastic resource pool is first created, the actual CUs will be equal to the specifications, which is also the minimum CUs.
    Description of the elastic resource pool
    CIDR Block
    CIDR block the elastic resource pool belongs to. If you use an enhanced datasource connection, this CIDR block cannot overlap that of the data source. Once set, this CIDR block cannot be changed.
    Recommended CIDR blocks:
    10.0.0.0–10.255.0.0/16–19
    172.16.0.0–172.31.0.0/16–19
    192.168.0.0–192.168.0.0/16–19
    IPv6
    After IPv6 is enabled, the elastic resource pool can communicate with data sources (the CIDR block of which have IPv6 enabled) using IPv6 addresses.
    If IPv6 is enabled, an IPv6 CIDR block will be automatically allocated to the elastic resource pool.
    • IPv6 can only be enabled during creation.
    • After enabling, both IPv4 and IPv6 addresses will be available, allowing for both private and public network access. IPv6 cannot be used independently.
    • The IPv6 CIDR block cannot be specified; it is allocated by the system.
    • IPv6 cannot be disabled after being enabled.
    Enterprise Project
    If the created elastic resource pool belongs to an enterprise project, select the enterprise project.
    Enterprise projects let you manage cloud resources and users by project.
    For details about how to configure enterprise projects, see Enterprise Management User Guide.
    This parameter is available only for users who have subscribed to the Enterprise Management Service.
    Tags
    Tags used to identify cloud resources. A tag includes the tag key and tag value. If you want to use the same tag to identify multiple cloud resources, that is, to select the same tag from the drop-down list box for all services, you are advised to create predefined tags on the Tag Management Service (TMS).
    If your organization has configured tag policies for DLI, add tags to resources based on the policies. If a tag does not comply with the tag policies, resource creation may fail. Contact your organization administrator to learn more about tag policies.
    For details, see Tag Management Service User Guide.
    • A maximum of 20 tags can be added.
    • Only one tag value can be added to a tag key.
    • The key name in each resource must be unique.
    • Tag key: Enter a tag key name in the text box.
      A tag key can contain a maximum of 128 characters. Only letters, digits, spaces, and special characters (_.:+-@) are allowed, but the value cannot start or end with a space or start with _sys_.
    • Tag value: Enter a tag value in the text box.
      A tag value can contain a maximum of 255 characters. Only letters, digits, spaces, and special characters (_.:+-@) are allowed.
  4. Click Buy and confirm the configurations.
  5. Click Pay. Wait until the status of the elastic resource pool changes to Available. The elastic resource pool is successfully created.
  6. Refer to Example Use Case: Creating an Elastic Resource Pool and Running Jobs and Example Use Case: Configuring Scaling Policies for Queues in an Elastic Resource Pool to perform subsequent operations as needed.
Creating Queues Within an Elastic Resource Pool
Create one or more queues within an elastic resource pool to run jobs. This section describes how to create a queue within an elastic resource pool.
Queues added to an elastic resource pool are not billed separately, but billed as billing items of the elastic resource pool.
Creating a queue within an elastic resource pool will trigger changes of elastic resource CUs.
  2. Locate the elastic resource pool in which you want to create queues and click Add Queue in the Operation column.
  3. On the Add Queue page, set basic queue parameters based on the table below.
    Table 3 Basic parameters for adding a queue
    Name
    Name of the queue to add
    Type
    • For SQL: The queue is used to run SQL jobs.
    • For general purpose: The queue is used to run Spark and Flink jobs.
    Engine
    If Type is For SQL, the queue engine can only be Spark.
    Enterprise Project
    Select the enterprise project the queue belongs to. Queues under different enterprise projects can be added to an elastic resource pool.
    Description about the queue.
    Tags
  4. Click Next. On the displayed page, configure a scaling policy for the queue in the elastic resource pool.
    Figure 1 Configuring a scaling policy when adding a queue
    Click Create to add a scaling policy with varying priority, period, minimum CUs, and maximum CUs. The parameters of each scaling policy are:
    Table 4 Scaling policy parameters
    Priority
    Priority of the scaling policy in the current elastic resource pool. A larger value indicates a higher priority. You can set a number ranging from 1 to 100.
    Period
    Time segment when the policy takes effect. It can be set only by hour. The start time is on the left, and the end time is on the right.
    • The time range includes the start time but not the end time, that is, [start time, end time).
      For example, if you set Period to 01 and 17, the scaling policy takes effect at 01:00 a.m. till 05:00 p.m.
    • The periods of scaling policies with different priorities should not overlap.
    Min CU
    Minimum number of CUs allowed by the scaling policy.
    • In any time segment of a day, the total minimum CUs of all queues in an elastic resource pool cannot be more than the minimum CUs of the pool.
    • If the minimum CUs of the queue are fewer than 16 CUs, both Max. Spark Driver Instances and Max. Prestart Spark Driver Instances set in the queue properties do not apply. See Setting Queue Properties.
    Max CU
    Maximum number of CUs allowed by the scaling policy.
    In any time segment of a day, the maximum CUs of any queue in an elastic resource pool cannot be more than the maximum CUs of the pool.
    • The maximum CUs of a queue in the elastic resource pool of the basic edition must be a multiple of 4.
    • The maximum CUs of a queue in the elastic resource pool of the standard edition must be a multiple of 16.
    Use Resource Pool's Max CU
    When selected, the maximum CUs of queues equal the maximum CUs of the resource pool within the period specified by the current scaling policy.
    Increasing the maximum CUs of the elastic resource pool automatically adjusts the queue's maximum CUs to match without manual intervention.
    The setting takes effect only within the period specified by the current scaling policy. You need to manually configure CU limits for other periods.
    • The first scaling policy is the default policy, and its Period parameter configuration cannot be deleted or modified.
    • Flink jobs cannot trigger automatic scaling of queues in an elastic resource pool.
  5. Click OK. View all queues and scaling policies added to the elastic resource pool by referring to Adjusting Scaling Policies for Queues in an Elastic Resource Pool.
