Configuring SLO Interruption Records
In this module, you can view, add, and modify SLO interruption records.
You can add SLO interruption records from five sources, including SLI metrics, war rooms, alarm tickets, incident tickets, and others. For alarm tickets and incident tickets, if SLA records are available and service interruption occurs, interruption records are automatically generated. For details about the rule examples, see Clearing an Alarm. For the other three sources, you can add interruption records manually.
You can also modify the unavailability start and end time points of SLO interruption records to automatically calculate the unavailability duration.
You have enabled the fault management package. For details about billing, see Billing Items.
Adding an SLO Interruption Record
- Log in to COC.
- In the navigation pane, choose Basic Configurations > SLO Management.
- Select the SLO metric to be viewed and click Interrupt Record in the Operation column. The Interrupt Record page is displayed.
- Click Add Interruption Record in the upper left corner and add interruption records by referring to Table 1.
Table 1 Parameters for adding an interruption record Parameter
Source
The options are SLI, War room, Alarm ticket, Incident ticket, and Other.
SLI
This parameter is required when Source is set to SLI. Select the SLI set in Adding an SLI.
War Room No.
This parameter is required when Source is set to War room. Select a war room.
Alarm Ticket No.
This parameter is required when Source is set to Alarm ticket. Select an alarm ticket.
Incident Ticket No.
This parameter is required when Source is set to Incident ticket. Select an incident ticket.
Other Sources
This parameter is required when Source is set to Other. Enter the description of other sources.
Region
Select the region where the interruption occurs
Unavailability Start and End Time
Enter the start and end time of the interruption.
Unavailability Duration
The preset value is Automatically calculated and cannot be changed.
Enter the description of the interruption record. The description cannot exceed 600 characters.
- Click OK.
Modifying an Interruption Record
- Log in to COC.
- Select the SLO metric to be viewed and click Interrupt Record in the Operation column. The interrupt record page is displayed.
- Locate the record you want to correct and click Correct in the Operation column. On the displayed page, change the start time, end time, and the description of the interruption record.
Table 2 Parameters for modifying an interruption record Parameter
Start time and end time of the interruption.
- Click OK.
View the Interruption Record Correction Details.
- Log in to COC.
- Locate the interruption record you want to view and click Correct Record in the Operation column.
- On the correction record page, view the interruption record correction details.
