Updated on 2026-11-24 GMT+08:00
Creating a PRR
In cloud service O&M, ensuring high availability and stability requires rigorous management of a service's entire lifecycle. However, in practice, the absence of standardized governance processes often results in insufficient preparation and testing before service release, leading to various post-deployment issues. Ensuring that a service achieves production readiness before release has therefore become a critical challenge. To address this, COC has introduced the PRR mechanism. This provides standardized governance across the service lifecycle, ensuring that every service undergoes comprehensive evaluation and validation before release—thereby significantly enhancing service stability and availability.
You have enabled the Fault Drills (Professional Edition) package. For details about billing, see Billing Items.
Procedure Description
  1. Create a PRR template. This step is optional.
    The PRR process consists of three phases: project initiation, design, and release. The review initiator can configure a review template based on service requirements.
  2. Perform self-check and initiate a PRR.
    The review initiator initiates a PRR based on the configured PRR template after the self-check is complete.
  3. Record the PRR conclusion.
    The meeting minutes taker reviews the project and records the review conclusion.
  4. Review the PRR conclusion.
    The reviewer reviews the conclusion.
    • If the conclusion is approved, the review proceeds to the next step if necessary.
    • If the conclusion is rejected, the review ends.
Creating a PRR Template
  1. Log in to COC.
  2. In the navigation pane, choose Resilience Center > PRR. The PRR page is displayed.
  3. Click PRR Template Management.
  4. On the displayed page, choose the PRR Template Management tab and then click Formulate Template.
  5. Set the basic information about the PRR template.
    Table 1 Basic information parameters
    Template
    Customize the name of a PRR template.
    The name can contain a maximum of 64 characters, including letters, digits, hyphens (-), underscores (_), and spaces. It cannot start or end with a space.
    Template Description
    Enter the description of the PRR template.
    Application Category
    The options are Core application and Non-core application.
    Application category to which the PRR template belongs, which is user-defined.
  6. Select the phase for which you want to set check items.
    The system has defined three phases: product initiation, design, and release.
  7. Click Add Check Item. In the drop-down list, click Select from System or Add and set parameters as required.
    If an A-level check item fails, the PRR fails.
    • Select from System: Select one or more predefined check items provided by COC. Expand the check items and add metrics.
    • Add: Specify the check item name and click Add Metric and set the evaluation details.
    Figure 1 Adding a check item
  8. Click Add Check Category to add multiple check items.
    You can add multiple check items to the PRR template. You can set check categories by choosing Select from System or Add as required.
    Figure 2 Adding a check category
  9. Click OK.
Initiating a PRR
You can initiate a PRR using a template baseline or directly initiate a review.
  1. Log in to COC.
  4. Locate the target PRR template and click Initiate PRR Using a Template in the Operation column.
  5. Set the basic information.
    Table 2 Basic information parameters
    PRR Name
    Customize the PRR name.
    PRR Description
    Enter the description of the PRR.
    Application
    Select the application to which the PRR belongs.
    Owner
    Specify the owner of the application to which the PRR belongs.
    The current user is set by default and cannot be changed.
    Application Description
    Enter the description of the application to which the PRR belongs.
    The preset value is the application category set in the template and cannot be changed.
    Template
    The selected template is set by default and cannot be changed.
    Review Phase
    Select one or more review phases for which the PRR needs to be initiated.
    Expected Completion Time
    Set the expected PRR completion time.
  6. Set PRR Check Items.
    Based on the PRR template selected in the Basic Information area, the self-check items required before the review will be displayed. Fill in the check items for PRR and modify the self-check result as required.
    Table 3 PRR check item parameters
    Self-Check Result
    The options are Passed and Not Passed.
    Select self-check results of check items. If an A-level check item fails, the review cannot be initiated. The self-check results are automatically displayed through automatic evaluation.
    Violated Item
    Enter details about the non-compliant items.
    If a check item fails, the information about the item that does not meet the requirements is displayed. If you use automatic evaluation, you can view details about the items that do not meet the requirements.
    Conference Initiator
    Initiator of the PRR conference.
    Participant
    Select one or more participants of the PRR conference.
    Minutes Recorded By
    Select the meeting minutes taker of the PRR conference.
    Add Self-check Materials
    Click Add Self-check Materials to upload self-check documents.
    Only one file can be uploaded. The file type can be DOCX, PDF, or PPTX. The file size cannot exceed 10 MB.
  7. Click OK.
    After the PRR is initiated, the PRR status changes to To be input. After the PRR is completed, the meeting minutes taker records the PRR conclusion. For details, see Recording the PRR Conclusion.
  1. Log in to COC.
  3. On the displayed page, click Initiate PRR.
  4. Set basic PRR information by referring to Table 4.
    Table 4 Basic information parameters
    PRR Name
    PRR Description
    Application
    Owner
    Application category to which the PRR belongs. An application category corresponds to a PRR template.
    Template
    Select a PRR template.
    Review Phase
  5. Set PRR check items by referring to Table 5.
    Table 5 PRR check item parameters
    Self-Check Result
    Violated Item
    Participant
    Minutes Recorded By
  6. Click OK.
  1. Log in to COC.
  3. On the PRRs tab page, locate the target PRR and click Input in the Operation column.
  4. In the review progress module, click Input Review Conclusion.
  5. Enter the review conclusion information by referring to Table 6.
    Table 6 Parameters for recording the PRR conclusion
    Review Result
    Select self-check results of check items. If an A-level check item fails, the PRR fails.
    Violated Item in Review
    Improvement Tickets
    Click Create Improvement Task to create an improvement ticket for the check items to be improved.
    For details about the parameters, see Table 7.
    Add Meeting Minutes
    Click Add Meeting Minutes to upload PRR conclusion documents.
    Table 7 Parameters for creating an improvement ticket
    Improvement Ticket
    Name of an improvement ticket.
    Application
    Select an application for which the improvement is performed.
    Type
    Select an improvement type.
    Improvement Owner
    Select an owner.
    Improvement Acceptor
    Select an acceptance user.
    Enter the expected completion time.
    You can select a day. The date cannot be earlier than the current day.
    Symptom
    Enter the incident-related symptom.
    The value can contain a maximum of 1,000 characters.
    Improvement Ticket Closure Criteria
    Enter the improvement ticket closure criteria.
  6. Click OK.
    If an A-level check item fails, the PRR fails. In this case, you need to perform the review again until the review is passed. Then, you can review the PRR conclusion.
Reviewing the PRR Conclusion
  1. Log in to COC.
  3. On the PRRs tab page, locate the target PRR and click Review in the Operation column.
  4. In the review process, set the review conclusion.
    • Review Result: The options are Passed and Not Passed.
    • Description: Enter the review comment if Review Result is set to Not Passed.
  5. Click OK.
More Operations
After creating a PRR template, you can perform the following operations as required.
Table 8 More operations
Function
Operation
Modifying a PRR Template
After a PRR template is created, you can modify it based on service changes.
If a PRR has been initiated using the template, the template cannot be modified.
  1. On the Resilience Center > PRR > PRR Template Management page, select the target PRR template and click Modify in the Operation column.
  2. Modify the parameters based on service requirements. For details about the parameters, see Creating a PRR Template.
  3. Click OK.
Deleting a PRR Template
You can delete a PRR template that is no longer needed.
If a PRR has been initiated using the template, the template cannot be deleted.
  1. On the Resilience Center > PRR > PRR Template Management page, select the target PRR template and click Delete in the Operation column.
  2. Click OK.
    After the PRR template is deleted, the template information is not displayed in the PRR template list.
Helpful Links
If any improvement item is found during the PRR, you can create an improvement ticket while recording the PRR conclusion. For details, see Recording the PRR Conclusion. Then, you can trace the ticket in the Improvement Management module and promote the implementation of the ticket.
