Updated on 2025-08-08 GMT+08:00
Overview
Production Readiness Review (PRR).
PRR provides the baselines for service availability and operations capabilities from dimensions such as SLI/SLO, redundancy, disaster recovery, overload control, fault management, change capability, operations, and secure production. It allows the frontend personnel to perform requirement planning, design, and development, as well as the production admission review before service rollout.
PRR ensures that the product initiation, design, and rollout processes meet the specified quality standards and requirements. You can view the PRR list and perform related operations. The main functions of PRRs include initiating PRRs and managing PRR templates.
You can click Initiate PRR to enter the PRR initiation page. Enter the basic information such as the review name, description, application name, and application owner, and specify the corresponding PRR template and check item information. During a PRR, you can upload self-check materials and record the review minutes after the review is complete. You can create improvement items for check items that need to be improved.
PRR Template Management
The PRR template is a tool used for PRRs. It contains check item information in three phases: product initiation, product design, and product rollout. You can customize a PRR template on the PRR template management page. In addition, you can initiate a PRR based on the existing template to start the review process. PRR template management is a part of the PRR management function.
PRR Management
The PRR management list displays basic information about all PRRs, including the review name, review progress, application, status, number of issue tickets, number of war rooms, and expected completion time. In addition, you can click the PRR name in the list to go to the review details page and view the review details, including the review progress details and improvement items. The PRR list is a part of the PRR management function. It enables you to effectively track and manage the entire PRR process.
