Forwarding Issue Tickets
During the issue ticket processing, if you find that the issue needs to be accepted by other O&M experts, you can forward the issue ticket to the corresponding owner.
Forwarding an Issue Ticket
- Log in to COC.
- In the navigation pane on the left, choose Fault Management > Issues.
- On the Pending tab page, locate the target issue ticket and click its title.
- Click Forwarding Owner in the upper right corner.
- Set Forwarding Owner.
Table 1 Parameters for forwarding an issue ticket Parameter
Owner
Select Shift or Individual.- Shift: Select a scenario and role from the drop-down lists based on the configured values. For details about how to configure a shift, see Shift Schedule Management.
- Individual: Select an owner. For details about how to configure an owner, see O&M Engineer Management.
Enter the forwarding description.
- Click OK.
The issue ticket is forwarded. The owner of the issue ticket is the forwarding owner you set.
