Deleting an Application
This section describes how to delete an application or sub-application.
Precautions
When an application or sub-application contains groups, components, or sub-applications, it cannot be deleted. You can delete a node only when the node does not contain sub-nodes.
- Log in to COC.
 - In the navigation pane, choose Resources > Application and Resource Management.
 - Click Applications in the upper left corner.
 - In the application list on the left, select the application to be deleted and click
. - Click OK.
The application is deleted.
Deleting a Sub-application
- Log in to COC.
 - In the application list on the left, expand the application, select the sub-application to be deleted, and click
. - Click OK.
The sub-application is deleted.
