Overview
You can customize the incident process, issue process, and change scenario. You can use the customized process management configuration for the fault management and change management modules as needed. The following table lists the processes that can be configured.
Level-1 Category |
Level-2 Category |
Scenario |
Incident Process |
Incident Level |
A maximum of five incident levels can be set. You can modify the incident level name, description, and whether to enable the incident level. |
Incident Category |
You can enable or disable incident categories, and add, delete, or modify custom incident categories (preset incident categories are not supported). |
Incident Review |
You can customize review rules for incident de-escalation and suspension scenarios. |
Fault Review |
You can customize incident fault review rules. |
Issue Process |
Issue Level |
A maximum of four issue levels can be set. You can modify the issue level name, description, and whether to enable the issue level. |
Issue Category |
You can enable or disable issue categories, and add, delete, or modify custom issue categories (preset issue categories are not supported). |
Issue Review |
You can customize review rules for issue suspension and issue level adjustment scenarios. |
Change Scenario |
Change Scenario |
You can enable or disable change scenarios and add, delete, modify, enable, or disable subnodes. Custom change scenarios can be added, deleted, or modified. Preset scenarios cannot be deleted or modified. |
