هذه الصفحة غير متوفرة حاليًا بلغتك المحلية. نحن نعمل جاهدين على إضافة المزيد من اللغات. شاكرين تفهمك ودعمك المستمر لنا.
- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Progress Notification
After a war room is started, you can view, update, and send notifications.
- Log in to COC.
- In the navigation pane on the left, choose Fault Management > WarRoom to view the war room list.
- Click a war room name in the war room list. The war room detail page is displayed.
- On the war room details page, you can view the current progress notification in the Progress Notices area.
- Click Update Notice, enter the notice content as prompted, and click OK to update the notice.
Figure 1 Updating notification
- Click Release, enter the required information as prompted, and click OK to release the notification.
If the Recipient is set to Shift, create the shift by referring to Overview.
Parent topic: WarRoom
