更新时间:2025-09-08 GMT+08:00
CoreDNS仪表盘模板
CoreDNS作为集群内的DNS服务器,您可以通过CoreDNS仪表盘模板查看CoreDNS日志来分析CoreDNS解析慢、访问高危请求域名等问题。
前提条件
- 已采集CoreDNS日志。
- 日志配置结构化,详情请参见设置云端结构化解析日志。
查看CoreDNS日志分析
- 登录云日志服务控制台,进入“日志管理”页面。
- 在左侧导航栏中选择“仪表盘 ”。
- 在仪表盘模板下方,选择“CoreDNS仪表盘模板 > CoreDNS日志分析”,查看图表详情。
- 过滤域名,所关联的查询分析语句如下所示:
* | select name group by name limit 10000
- 过滤客户端IP,所关联的查询分析语句如下所示:
* | select remote group by remote limit 10000
- 过滤状态码,所关联的查询分析语句如下所示:
* | select rcode group by rcode limit 10000
- 总请求次数图表所关联的查询分析语句如下所示:
*| select diff[1] as nowCount, diff[1] - diff[2] as delta from (select compare(total, 86400) as diff from( select count(1) as total from log ) )
- NXDOMAIN次图表所关联的查询分析语句如下所示
(* and rcode: NXDOMAIN) | select diff[1] as nowCount, diff[1] - diff[2] as delta from (select compare(total, 86400) as diff from( select count(1) as total from log ) )
- 请求成功率图表所关联的查询分析语句如下所示:
*| select diff[1] as nowCount, round(diff[1] - diff[2], 2) as delta from (select compare(total, 86400) as diff from( select round( count_if(rcode = 'NOERROR' or rcode = 'NXDOMAIN') * 100.0 / (case when count(1) = 0 then 1 else count(1) end), 2 ) as total from log ) )
- 域名数图表所关联的查询分析语句如下所示:
*| select diff[1] as nowCount, diff[1] - diff[2] as delta from (select compare(total, 86400) as diff from( select approx_distinct(name) as total from log ) )
- 平均延迟图表所关联的查询分析语句如下所示:
*| select diff[1] as nowCount, round(diff[1] - diff[2],3 ) as delta from (select compare(total, 86400) as diff from( select round(avg(duration * 1000), 3) as total from log ) )
- Timeout次数图表所关联的查询分析语句如下所示:
(level : ERROR) | select diff[1] as nowCount, round(diff[1] - diff[2], 3) as delta from (select compare(total, 86400) as diff from( select count(1) as "total" from log where errmsg like '%timeout%' ) )
- P95延迟图表所关联的查询分析语句如下所示:
*| select diff[1] as nowCount, round(diff[1] - diff[2], 3) as delta from (select compare(total, 86400) as diff from( select round(approx_percentile(duration * 1000, 0.95), 3) as total from log ) )
- P99延迟图表所关联的查询分析语句如下所示:
*| select diff[1] as nowCount, round(diff[1] - diff[2], 3) as delta from (select compare(total, 86400) as diff from( select round(approx_percentile(duration * 1000, 0.99), 3) as total from log ) )
- 请求QPS图表所关联的查询分析语句如下所示:
*| select date_format(t, '%Y-%m-%d %H:%i') as time , d[1] as "今天", d[2] as "昨天", d[3] as "上周" from( select t, ts_compare(pv, 86400,604800 ) as d from(select from_unixtime(__time - __time % 60) as t, round(count(1)/ 60.0, 2 ) as pv from log group by t order by t limit 1440 ) group by t ) where date_format(t, '%Y-%m-%d %H:%i') is not null order by time
- 请求平均延迟(ms)图表所关联的查询分析语句如下所示:
*| select date_format(t, '%Y-%m-%d %H:%i') as time , d[1] as "今天", d[2] as "昨天", d[3] as "上周" from( select t, ts_compare(pv, 86400,604800 ) as d from(select from_unixtime(__time - __time % 60) as t, round(avg(duration * 1000.0), 3 ) as pv from log group by t order by t limit 1440 ) group by t ) where date_format(t, '%Y-%m-%d %H:%i') is not null order by time
- 成功率(%)图表所关联的查询分析语句如下所示:
*| select date_format(t, '%Y-%m-%d %H:%i') as time , d[1] as "今天", d[2] as "昨天", d[3] as "上周" from( select t, ts_compare(pv, 86400,604800 ) as d from(select from_unixtime(__time - __time % 60) as t, round( count_if(rcode = 'NOERROR') * 100.0 / (case when count(1) = 0 then 1 else count(1) end), 2 ) as pv from log group by t order by t limit 1440 ) group by t ) where date_format(t, '%Y-%m-%d %H:%i') is not null order by time
- P99延迟(ms)图表所关联的查询分析语句如下所示:
*| select date_format(t, '%Y-%m-%d %H:%i') as time , d[1] as "今天", d[2] as "昨天", d[3] as "上周" from( select t, ts_compare(pv, 86400,604800 ) as d from(select from_unixtime(__time - __time % 60) as t, round(approx_percentile(duration * 1000.0, 0.99), 3 ) as pv from log group by t order by t limit 1440 ) group by t ) where date_format(t, '%Y-%m-%d %H:%i') is not null order by time
- Top请求域名图表所关联的查询分析语句如下所示:
*| SELECT name, COUNT(*) as total group by name order by total desc
- 状态码分布图表所关联的查询分析语句如下所示:
*| SELECT rcode, COUNT(*) as total group by rcode order by total desc
- TOP域名图表所关联的查询分析语句如下所示:
*| SELECT name as "域名", rcode as "状态码", round(sum(size/ 1024.0), 3) as "请求流量KB", round(sum(rsize / 1024.0),3 ) as "返回流量KB", COUNT(*) as "请求次数", round(avg(duration * 1000), 3) as "平均延迟(ms)" group by name, rcode order by "请求次数" desc
- TOP NXDOMAIN域名图表所关联的查询分析语句如下所示:
(* and rcode: NXDOMAIN)| SELECT name as "域名", rcode as "状态码", round(sum(size/ 1024.0), 3) as "请求流量KB", round(sum(rsize / 1024.0),3 ) as "返回流量KB", COUNT(*) as "请求次数", round(avg(duration * 1000), 3) as "平均延迟(ms)" group by name, rcode order by "请求次数" desc
- TOP 错误域名(非NXDOMAIN)图表所关联的查询分析语句如下所示:
(* not rcode: NXDOMAIN not rcode : NOERROR)| SELECT name as "域名", rcode as "状态码", round(sum(size/ 1024.0), 3) as "请求流量KB", round(sum(rsize / 1024.0),3 ) as "返回流量KB", COUNT(*) as "请求次数", round(avg(duration * 1000), 3) as "平均延迟(ms)" group by name, rcode order by "请求次数" desc
- TOP请求Pod图表所关联的查询分析语句如下所示:
*| SELECT remote as "IP", arbitrary(name) as "请求域名采样", round(sum(size/ 1024.0), 3) as "请求流量KB", round(sum(rsize / 1024.0),3 ) as "返回流量KB", COUNT(*) as "请求次数", round(avg(duration * 1000), 3) as "平均延迟(ms)" group by remote order by "请求次数" desc
- TOP NXDOMIN Pod图表所关联的查询分析语句如下所示:
(* and rcode : NXDOMAIN)| SELECT remote as "IP", arbitrary(name) as "请求域名采样", round(sum(size/ 1024.0), 3) as "请求流量KB", round(sum(rsize / 1024.0),3 ) as "返回流量KB", COUNT(*) as "请求次数", round(avg(duration * 1000), 3) as "平均延迟(ms)" group by remote order by "请求次数" desc
- TOP错误Pod(非NXDOMAIN)图表所关联的查询分析语句如下所示:
(* not rcode : NXDOMAIN not rcode : NOERROR)| SELECT remote as "IP", arbitrary(name) as "请求域名采样", round(sum(size/ 1024.0), 3) as "请求流量KB", round(sum(rsize / 1024.0),3 ) as "返回流量KB", COUNT(*) as "请求次数", round(avg(duration * 1000), 3) as "平均延迟(ms)" group by remote order by "请求次数" desc
- Timeout域名图表所关联的查询分析语句如下所示:
(level : ERROR)| select name as "域名", count(1) as "次数" from log where errmsg like '%timeout%' group by name order by "次数" desc limit 100
- 近100条请求APIServier的错误图表所关联的查询分析语句如下所示:
(content : reflector.go)| select date_format(from_unixtime(__time), '%Y-%m-%d %H:%i:%S') as "时间", errmsg as "错误" from log order by __time desc limit 100
- 解析日志图表所关联的查询分析语句如下所示:
(* and level: INFO and duration > 0.010)| SELECT name as "域名", round( duration * 1000.0, 3) as "延迟(ms)", remote as "请求者", port as "端口", type as "类型", rcode as "结果" , podName as "CoreDNS" from log order by duration desc limit 100
