更新时间:2026-04-20 GMT+08:00
配置监控告警(中间件类可选)
本章节主要介绍部分监控指标的告警策略以及配置操作。在实际业务中,建议按照以下告警策略,配置监控指标的告警规则。
监控指标
表1 ems指标告警
监控项说明
涉及指标
采集周期
告警名称
告警级别
告警阈值
告警阈值、PromQL说明
节点读请求失败个数
EMS_GET_KV_STAT
30s
ems_server_io_read_status_abnormal
重要级别
5%
连续3个周期内出现报错触发;连续3个周期内未报恢复
PromQL:
avg(EMS_GET_KV_STAT{namespace="ems", container="ems-server", item="BackBad"}) by (pid) > 0
节点写请求失败个数
EMS_PUT_KV_STAT
30s
ems_server_io_write_status_abnormal
重要级别
5%
PromQL:
avg(EMS_PUT_KV_STAT{namespace="ems", container="ems-server", item="BackBad"}) by (pid) > 0
请求成功率
EMS_PUT_KV_STAT、EMS_GET_KV_STAT
30s
ems_server_io_success_rate_low
紧急级别
0.95
连续5min内成功率小于0.95触发(单个周期内总请求数大于100),5min内成功率大于0.95恢复
(avg(EMS_PUT_KV_STAT{namespace="ems", container="ems-server", item="BackGood"})+avg(EMS_GET_KV_STAT{namespace="ems", container="ems-server", item="BackGood"}))/(avg(EMS_PUT_KV_STAT{namespace="ems", container="ems-server", item="Start"})+avg(EMS_GET_KV_STAT{namespace="ems", container="ems-server", item="Start"}))<0.95
节点读写QPS
ems_server_kv_concurrent_num_used、ems_server_kv_concurrent_num_limit
30s
ems_server_io_concurrent_high
重要级别
1000 key/s
连续3个周期内请求数大于1000 key/s并发限制触发,连续3个周期内小于1000 key/s恢复
PromQL:
avg(ems_server_kv_concurrent_num_used{namespace="ems", pod=~"ems-server.*"} / ems_server_kv_concurrent_num_limit{namespace="ems", pod=~"ems-server.*"}) by (pod) > 0.8
节点读请求时延
EMS_GET_KV_STAT
30s
ems_server_io_read_latency_high
重要级别
100ms
连续3个周期内存在时延大于100ms的读请求触发;连续3个周期内未出现大于100ms的读请求恢复
PromQL:
avg_over_time(EMS_GET_KV_STAT{namespace="ems", kubernetes_pod=~"ems-server.*", container="ems-server", item="Av"}[90s])>100
节点写请求时延
EMS_PUT_KV_STA
30s
ems_server_io_write_latency_high
重要级别
200ms
连续3个周期内存在时延大于200ms的写请求触发;连续3个周期内未出现大于200ms的写请求恢复
PromQL:
avg_over_time(EMS_PUT_KV_STAT{namespace="ems", kubernetes_pod=~"ems-server.*", container="ems-server", item="Av"}[90s])>200
ems server连接zk异常
ems_server_service_zk_status
30s
ems_server_zk_status_abnormal
重要级别
0
连续3个周期内出现状态异常触发;连续3个周期内状态正常则恢复
PromQL:
avg_over_time(ems_server_service_zk_status{namespace="ems", kubernetes_pod=~"ems-server.*", container="ems-server"}[90s]) != 0
ems-server cpu使用率
ems_server_process_cpu_usage
30s
ems_server_cpu_usage_high
重要级别
0.8
连续3个周期内大于阈值触发,连续3个周期内小于阈值恢复
avg_over_time(ems_server_process_cpu_usage{namespace="ems", kubernetes_pod=~"ems-server.*", container="ems-server"}[1m30s])>80
ems-server 句柄数
ems_server_fd_high
30s
ems_server_fd_high
重要级别
20000
avg_over_time(ems_server_all_process_fds{namespace="ems", kubernetes_pod=~"ems-server.*", container="ems-server"}[1m30s])>20000
ems-server 节点间带宽
ems_server_inter_io_bandwidth_high
30s
重要级别
5GB/s
avg_over_time(MFV_CE_TASK_PULL_FLOW_CONTROL_s_all{namespace="ems",   kubernetes_pod=~"ems-server.*", container="ems-server",   item="Total"}[90s])/30/1000000000>5
ems-server 节点间带宽
30s
重要级别
5GB/s
avg_over_time(MFV_CE_TASK_PUSH_FLOW_CONTROL_s_all{namespace="ems",   kubernetes_pod=~"ems-server.*", container="ems-server",   item="Total"}[90s])/30/1000000000>5
ems-server 节点间PUT IO时延
ems_server_inter_io_latency_high
30s
重要级别
50ms
avg_over_time(MFV_REM_KV_CLI_PUT_VAL{namespace="ems", kubernetes_pod=~"ems-server.*", container="ems-server", item="Av"}[90s])>50000
ems-server 节点间GET IO时延
30s
重要级别
50ms
avg_over_time(MFV_REM_KV_CLI_GET_VAL{namespace="ems", kubernetes_pod=~"ems-server.*", container="ems-server", item="Av"}[90s])>50000
ems-server 大页内存有效利用率
ems_server_pool_memory_used/ems_server_pool_memory_total
30s
ems_server_hugepage_usage_high
重要级别
0.95
avg((ems_server_pool_memory_used{namespace="ems", pod=~"ems-server.*"}) /(ems_server_pool_memory_total{namespace="ems", pod=~"ems-server.*"})) by (pod) >0.95
ems-server 网卡带宽监控
ems_server_nic_bandwidth
30s
ems_server_nic_bandwidth_high
重要级别
0.5
avg_over_time(ems_server_nic_bandwidth{namespace="ems", pod=~"ems-server.*",container = "ems-server"}[90s]) >0.5
ems-ctrl 句柄数
ems_controller_all_process_fds
30s
ems_ctrl_fd_high
重要级别
20000
avg_over_time(ems_controller_all_process_fds{namespace="ems", kubernetes_pod=~"ems-controller.*", container="ems-controller"}[1m30s])>20000
ems-ctrl cpu使用率
ems_controller_process_cpu_usage
30s
ems_ctrl_cpu_usage_high
重要级别
0.8
avg_over_time(ems_controller_process_cpu_usage{namespace="ems", kubernetes_pod=~"ems-controller.*", container="ems-controller"}[1m30s]) > 80
zk进程状态 cpu使用率
dmk_zk_cpu_usage
30s
ems_zk_cpu_usage_high
重要级别
0.8
avg_over_time(dmk_zk_cpu_usage{namespace="ems", pod=~"ems-zookeeper.*"}[90s])>80
controller pod状态
kube_pod_status_ready
30s
ems_controller_pod_status_abnormal
重要级别
ems controller pod status == notok(CCE集群监控),故障时间>5min
PromQL:
avg_over_time(kube_pod_status_ready{namespace="ems", condition="true", pod=~"ems-controller.*"}[90s]) != 1
server pod状态
30s
ems_server_pod_status_abnormal
重要级别
ems server pod status == notok (CCE集群监控),故障时间>5min
PromQL:
avg_over_time(kube_pod_status_ready{namespace="ems", condition="true", pod=~"ems-server.*"}[90s]) != 1
controller连接zk状态
ems_controller_service_zk_status
30s
ems_controller_zk_status_abnormal
重要级别
-1
controller_service_zk_status == -1,故障时间>90s
PromQL:
avg_over_time(ems_controller_service_zk_status{namespace="ems", kubernetes_pod=~"ems-controller.*", container="ems-controller"}[90s]) != 0
计费信息上报功能状态
ems_controller_service_charge_report_status
30s
ems_controller_charge_report_status_abnormal
重要级别
0
controller_service_charge_report_status == -1
PromQL:
avg_over_time(ems_controller_network_loss_packet_rate_qdisc{namespace="ems",   kubernetes_pod=~"ems-controller.*",   container="ems-controller"}[90s]) != 0
ems-ctrl容器网卡丢包
30s
重要级别
0%
avg_over_time(ems_controller_network_loss_packet_rate_qdisc{namespace="ems",   kubernetes_pod=~"ems-controller.*",   container="ems-controller"}[90s])!=0
ems-server容器网卡丢包
ems_server_network_loss_packet_rate_qdisc
30s
重要级别
0%
avg_over_time(ems_server_network_loss_packet_rate_qdisc{namespace="ems",   kubernetes_pod=~"ems-server.*",   container="ems-server"}[90s])!=0
业务进程状态异常
ems_server_process_status
30s
紧急级别
连续3个周期内不等于0/1阈值触发,连续3个周期内小于阈值恢复
avg_over_time(ems_server_process_status{namespace="ems", kubernetes_pod=~"ems-server.*", container="ems-server"} [90s]) !=1
ems-ctrl主节频繁故障
ems_controller_master_change
30s
紧急级别
3次
连续3个周期内切主三次
sum(   changes(ems_controller_master_change{namespace="ems", kubernetes_pod=~"ems-controller.*", container="ems-controller"}[5m]) > 0 ) > 3
配置文件效验
ems_server_config_error_code
30s
ems_kv_config_error
紧急级别
0
连续3个周期内不等于0阈值触发,连续3个周期内小于阈值恢复
avg_over_time(ems_server_config_error_code{namespace="ems", kubernetes_pod=~"ems-server.*", container="ems-server"} [90s]) !=0
配置监控告警步骤如下:
  1. 登录AOM控制台
  2. 选择告警中心 > 告警规则,进入告警规则页面。
  3. 单击“创建告警规则”,根据表1 ems指标告警内容填写规则,填写后单击“确定”即可。
    其中规则填写要求如下:
  4. 反复执行3,直到所有告警配置完毕。
