Updated on 2025-12-03 GMT+08:00
Scheduled System Disk Rebuilding
This section describes how to rebuild a system disk periodically for a cloud desktop or a desktop pool. For details about the impact and restrictions of system disk rebuilding on the system, see Rebuilding a System Disk or Rebuilding a System Disk.
  1. Log in to the console.
  2. In the navigation pane, choose Tasks > Scheduled Tasks.
    The Scheduled Tasks page is displayed.
  3. Click Create Scheduled Task in the upper right corner of the page.
    The Create Scheduled Task page is displayed.
  4. Configure a scheduled task.
    • Task Type: Select System disk recomposing.
    • Task Name: This parameter is user-defined.
    • Rebuilding Method: The default value is Reinstall OS.
    • Execution Interval: You can select one of the following intervals:
      • Specified time: The time is accurate to seconds.
      • By day: You can specify Time, Executed Once Per, and Expires At.
      • By week: You can specify Weekday, Time, and Expires At.
      • By month: You can specify Month, Day, Time, and Expires At.
    • Time Zone: The local time zone is selected by default.
    • Description: This parameter is optional and user-defined.
    • Confirm System Disk Reinstallation: Enter Reinstall System Disk.
  5. Determine whether to notify users.
    • Yes: Set Earlier Than Scheduled Task to a value ranging from 1 to 10,080 minutes. Enter the notification, which can only be text in 1 to 400 characters.
    • No: Perform 6.
      Notification messages are available only for Windows.
  6. Click Next: Select Object.
    The page for selecting target objects is displayed.
    For the first time when you click Next: Select Objects, the authorization description will be displayed.
    Cloud service administrator permissions: Workspace supports scheduled system disk rebuilding and auto scaling. Therefore, the tenant administrator permissions are required.
    After the permission is granted (only once), an agency named workspace_admin_trust will be created in IAM. Do not delete or modify the agency when performing a scheduled task or using a desktop pool. For details, see Entrustment Description.
  7. Select target objects as required. The objects include all desktops, desktop, desktop pool, and desktop tag.
    You can search for desktops in batches by entering multiple filter criteria. Use commas (,) to separate multiple values, for example, Desktop1,Desktop2,Desktop3.
  8. Click Create Now.
