Viewing Alarm Records
When a monitoring metric reaches the threshold specified in an alarm rule or an event (such as desktop access or startup failure) occurs, you can view monitoring details in alarm records. By default, you can view alarm records of the past seven days. You can select a time range to view alarm records of the past 30 days. When an alarm is generated, you can view alarm details.
On the Alarm Records page, set Resource Type to Workspace to view Workspace alarms.
