Help Center/ Workspace/ User Guide (Administrators)/ Tenant Configuration/ Basic Configuration/ Configuring Whether to Block Notification Emails for Desktop Unsubscription or Deletion
Updated on 2025-10-22 GMT+08:00
When you unsubscribe from or delete a desktop, you can determine whether to send a notification email to the user. The notification email informs the user of the desktop unsubscription or deletion.
  1. Log in to the console.
  2. In the navigation pane, choose Tenant Configuration > Basic Settings.
    The Basic Settings page is displayed.
  3. In the Desktop Unsubscription/Deletion area on the Tenant Configuration page, perform operations as required.
    • Email sending is enabled by default, indicating that notification emails of desktop unsubscription or deletion are sent to users.
    • If you do not want users to receive such emails, click Disable.
