Updated on 2026-02-24 GMT+08:00
Command Records
The administrator can check the remote script execution records of desktops or desktop pools on the Workspace console.
The script has been remotely executed on a desktop or desktop pool.
  1. Log in to the console.
  2. In the navigation pane, choose O&M > Command Records.
    The Command Records page is displayed.
  3. Under the Desktops tab, you can use filters, such as Desktop ID, Task ID, Execution Status, and Started, to check data of the desktop, such as Desktop Name/ID, Command Details, Task ID, Execution Status, Response, Started, and Ended.
  4. Under the Desktop Pools tab, you can use filters, such as Desktop Pool ID, Execution Status, and Started, to check data of the desktop pool, such as Desktop Pool Name/ID, Command Details, Execution Status, Execution Details, Started, and Ended.
