Updated on 2026-09-18 GMT+08:00
Creating a VPC Flow Log
A VPC flow log records information about the traffic going to and from a VPC.
Configuration Example
You can use a VPC flow log to collect and analyze the traffic of a specified VPC. This section provides guidance on the entire process in typical scenarios to help you configure and analyze flow logs.
Ensure that the following operations have been performed on the LTS console:
  • Create a log group.
  • Create a log stream.
For more information about the LTS service, see the Log Tank Service User Guide.
  1. Go to the VPC flow log list page.
  2. In the upper right corner, click Create Flow Log. On the displayed page, configure parameters as prompted.
    Table 1 Parameter descriptions
    Example Value
    Name
    The VPC flow log name. The name:
    • Can contain 1 to 64 characters.
    • Can contain letters, digits, underscores (_), hyphens (-), and periods (.).
    flowlog-495d
    Version
    VPC flow log version.
    The fields supported by VPC flow logs vary by version. v1 is selected by default. For details about differences between VPC flow logs of different versions, see VPC Flow Log Data.
    v2
    Resource Type
    Type of the resource whose traffic is to be logged. The options can be one of the following:
    • NIC
    • Subnet
    • VPC
    NIC
    Resource
    The specific resource whose traffic is to be logged.
    We recommend that you select an ECS that is in the running status. If an ECS in the stopped status is selected, restart the ECS after creating the VPC flow log for accurately recording the information about the traffic going to and from the network interface of the ECS.
    N/A
    Filter
    • All traffic: Both accepted and rejected traffic of the specified resource will be logged.
    • Accepted traffic: Only accepted traffic of the specified resource will be logged. Accepted traffic refers to the traffic allowed by the security group and network ACL.
    • Rejected traffic: Only rejected traffic of the specified resource will be logged. Rejected traffic refers to the traffic denied by the security group and network ACL.
    All
    Log Group
    The log group created in LTS.
    lts-group-abc
    Log Stream
    The log stream created in LTS.
    lts-topic-abc
    Supplementary information about the VPC flow log. This parameter is optional.
    The VPC flow log description can contain a maximum of 255 characters and cannot contain angle brackets (< or >).
    N/A
    Only two flow logs, each with a different filter, can be created for a single resource under the same log group and log stream. Each VPC flow log must be unique.
  3. Click Create Now.
    Return to the VPC flow log list and check the new VPC flow log.
