Monitoring Metrics
This section describes VOD metrics reported to Cloud Eye as well as their namespaces and dimensions. You can use the Cloud Eye console or APIs to query the VOD metrics and alarms.
You can view metrics on the management console, configure alarm rules for metrics, and enable SMN to receive notifications. If a metric meets the alarm condition, Cloud Eye notifies you by SMS message, email, HTTP, or HTTPS.
Namespace
SYS.VOD
Monitoring Metrics
| ID | Name | Description | Value Range | Unit | Conversion Rule | Dimension | Monitoring Interval (Raw) |
| flux | Traffic | Total traffic of a domain name in a specified period of time. | ≥ 0 | bit/s | 1024 | domain_name | 5 minutes |
| req_num | Access requests | Total number of access requests to a domain name in a specified period of time. | ≥ 0 | count | - | domain_name | 5 minutes |
| http_code_2xx | Status code summary 2xx | Number of server responses with 2xx status codes for a domain name. | ≥ 0 | count | - | domain_name | 5 minutes |
| http_code_3xx | Status code summary 3xx | Number of server responses with 3xx status codes for a domain name. | ≥ 0 | count | - | domain_name | 5 minutes |
| http_code_4xx | Status code summary 4xx | Number of server responses with 4xx status codes for a domain name. | ≥ 0 | count | - | domain_name | 5 minutes |
| http_code_5xx | Status code summary 5xx | Number of server responses with 5xx status codes for a domain name. | ≥ 0 | count | - | domain_name | 5 minutes |
Dimensions
| Key | Value |
| domain_name | VOD domain name You can obtain the value by referring to Querying the Original Dimension Values in Server Monitoring. |
