MFS
Updated on 2024-12-27 GMT+08:00
Message notifications of MFS are free of charge.
NOTICE:
MFS is not supported in CN North-Beijing1 and CN East-Shanghai2.
Configuring Notifications
  1. Log in to the VOD console.
  2. In the navigation pane, choose Global Settings > Notification Settings.
    1. Select desired events and enter the callback address.
    2. (Optional) If authentication is required, click Generate to generate an authentication key.
      MFS Notification Authentication Process shows the message notification authentication process.
      NOTICE:
      If you select both Snapshot captured and Thumbnail created, only Snapshot captured will trigger notifications.
      Figure 1 Configuring notifications
    MFS supports only REST messages. For details about the JSON message template, see Table 1.
    Table 1 JSON message
    Type
    event_type
    Event type. The options are as follows:
    • transcodeComplete: transcoding (encryption) completed
    • thumbnailComplete: snapshot captured
    • reviewComplete: review completed
    • createComplete: media file created
    • audioExtractComplete: audio extracted
    • coverComplete: thumbnail created
    • parseComplete: media file parsed
    String
    transcode_info
    Transcoding (including encryption) message. For details, see Transcoding Message Body.
    TranscodeInfo
    thumbnail_info
    Snapshot message. For details, see Snapshot Message Body.
    ThumbnailInfo
    review_info
    Review message. For details, see Review Message Body.
    ReviewInfo
    create_info
    Media file upload message. For details, see Media Upload and Audio Extraction Message Body.
    AssetInfo
    audio_extract_info
    Audio extraction message. For details, see Media Upload and Audio Extraction Message Body.
    AssetInfo
    cover_info
    Thumbnail message. For details, see Thumbnail Message Body.
    CoverInfo
    parse_info
    Media file parsing completion message. This parameter is available only when a media file has been parsed. For details, see Media Asset Parsing Message Body.
    ParseInfo
  3. Click OK.
  1. VOD generates a timestamp based on the current time and uses the key configured in 2.b to calculate the signature string using HmacSHA256(VOD_{timestamp}_{body}, key).
    The signature string and timestamp are sent to the device in the HTTP message header, which is header[auth_sign] and header[auth_timestamp], respectively. In the preceding information, body indicates the message attribute in the message body.
  2. After receiving the response, the customer combines strings in the VOD_{timestamp}_{body} format and uses the key in the message header to check whether the signature string generated in HmacSHA256(VOD_{timestamp}_{body}, key) is the same as that in the message header. If they are the same, the authentication is successful.
