Creating a Test Suite
In today's fast-iterating product development environment, enterprises face dual pressure to improve software quality and accelerate delivery. Applications on Huawei Cloud often feature diverse functions and complex architectures, resulting in many test cases and greater organization difficulty. Traditional testing methods often lead to scattered test cases, repeated executions, or incomplete coverage, reducing testing efficiency and result reliability.
As a key test management tool, a test suite logically groups related test cases into a set, helping test teams organize and manage tests efficiently. It helps testers systematically organize test activities based on service functions, technical architectures, or test types, ensuring complete test coverage and efficient execution. In addition, it supports flexible combination and reuse, reducing test maintenance costs.
- Multiple test cases have been created.
Creating a Manual Test Suite
- Log in to the CodeArts homepage, search for your target project, and click the project name to access the project.
- In the navigation pane, choose Testing > Testing Execution. By default, Test case library and Baseline are displayed.
- Click
next to Test case library and select a test plan. - On the Manual Test tab page, click Create Suite in the upper left corner. The creation page is displayed.
- Configure the parameters by referring to the following table.
Configuration Item
Mandatory
Name
Yes
Name of a suite. Enter 1 to 128 characters.
Plan Period
No
Select the start time and end time of the test suite.
No
Brief description of the suite. Max. 500 characters.
Tag
No
Enter up to 10 tags separated by spaces.
ID
No
Enter 3 to 128 characters. If this is not set, the service will automatically generate an ID.
Module
No
Select a module in the current project. For details about how to set a module, see Adding Work Item Modules.
Version
No
Enter a version containing at least three characters.
Processor
No
Select a person responsible for processing the suite.
- Click Add Case or Add Now, select the test cases to add, and click OK.
In the Add Test Case dialog box, you can search for the target case by case name, ID, description, or custom field. To filter test cases that have not been added to test suites, click the drop-down list box on the left of the search box and choose No Associated TestSuite.
- Click Save to create the manual test suite. The new suite will appear in the suite list on the Manual Test tab.
- (Optional) Click the test suite name to view its details page. Click the
icon in the Operation column, select the custom fields to display, and click OK. - To execute a manual test suite, see Executing a Manual Test Suite.
Creating an Automated API Test Suite
With CodeArts TestPlan, you can create API test suite, run test cases in serial or parallel mode, and accelerate execution of some test cases. The service helps you use resource pools efficiently, reduce task blocking, intercept product defects, and detect issues quickly.
- Click
next to Test case library and select a test plan. - On the Auto API Test tab page, click Create Suite in the upper left corner. The creation page is displayed.
Configuration Item
Mandatory
Name
Yes
Preparations
No
Prepare the data required during testing.
Click Add Now to select preparation cases from the list.
Followups
No
Release or restore the test data.
Click Add Now to select followup cases from the list.
Agent Pool
Yes
The agent pool allows you to access your own execution resources. When executing a task, you can select an agent in the agent pool to execute the task. This improves the task execution efficiency and does not depend on the public resources of CodeArts. Click Agent Pool Management to see existing pools. For details about how to create an agent pool, see Creating an Agent Pool.
ID
No
Tag
No
Set tags for the current task as required. The tags are separated by spaces. Each task can be associated with a maximum of 10 tags.
Module
No
Module of the current test suite. The module list comes from the project settings. For details, see Adding Work Item Modules.
Processor
No
Person who needs to complete the test task.
Version
No
Select the version that has been set for the current test plan and test cases.
No
Enter a brief description of the API test suite. Max. 500 characters.
Environment Parameters
No
Environment parameters can be referenced by parameters, checkpoints, variables, and URLs of test steps in the entire project. Click
to create an environment parameter.Max. Duration
Yes
The longest time taken for executing a test case. Cases exceeding this limit will fail. Max. 10 minutes.
Overwrite Test Suite Parameters
No
You can set advanced parameters for a test suite, and overwrite global parameters in a test suite. A maximum of three global parameters can be overwritten.
Execute
Yes
There are two types. By default, the task is executed only once.
- Once: The test suite is executed only once.
- Regularly: After you set an execution frequency, the test suite is executed periodically. Set this parameter to daily.
Start
Yes
There are two options. By default, the task is executed immediately.
- Immediately: The task is executed immediately.
- At specific time: The task is executed at a specified time.
Sequence
Yes
There are two modes. The default mode is Serial.
- Serial: Test cases in the API test suite are executed in serial mode.
- Parallel: Test cases in the API test suite are executed in parallel mode.
Case Retry on Failure
No
Number of retries after a test case fails. The value ranges from 0 to 10. The default value is 0.
- Click Add Case or Add Now and select the test case to be executed.
- Complete the execution settings as required and click Save.
- Perform the following operations on the created API test suite as required:
- Modify: Click the name of the test suite and modify its information.
- Delete: Click
in the Operation column of the test suite and click Delete. To delete test suites in batches, select the test suites and click Delete at the tool bar below the list. - Copy: Click
in the Operation column of the test suite and click Copy Test Suite. By default, the new suite will be named Name of the copied suite_copy_Current timestamp. You can rename the new suite, enter a description, and click OK to finish the copy operation.
Quickly Creating a Test Suite in the Test Feature or Requirement Directory
- In the navigation pane, choose .
- Select the execution mode tab based on the test suite type.
- Select the test feature directory or test requirement directory as required.
- Click
next to the test feature or requirement. - Click Create Suite. The page for creating a test suite of the corresponding type is displayed. For details about how to create test suites of different types, see Creating a Manual Test Suite and Creating an Automated API Test Suite.
