Viewing Top SQL Statements
After Collect All Query Logs is enabled, you can filter, search for, and analyze SQL statements in multiple dimensions and gain a comprehensive insight into all SQL statements. Top SQL helps you locate exceptions.
If you did not subscribe to Intelligent O&M, you can only view the data of the last hour. The data will be automatically deleted when it expires. If you have subscribed to Intelligent O&M, you can configure how long top SQL statements are kept (at most one day).
- Log in to the TaurusDB console.
- Click
in the upper left corner and select a region. - On the Instances page, click the target instance name.
- In the navigation pane, choose SQL Analysis and Tuning under DBA Assistant.
- Click the Top SQL tab.
- Click Subscribe. In the displayed dialog box, you can learn about Intelligent O&M functions and pricing. Figure 1 Subscribing to Intelligent O&M
- View the top SQL statements of the DB instance. Figure 2 Viewing the top SQL statements
- View execution durations of the top SQL statements in the last 1 hour, last 3 hours, last 6 hours, last 12 hours, or a custom time period (no longer than one day).
- Click a point in time or drag to select a time period to view the SQL statistics of a SQL template.
- Click
to export information about all top SQL templates in the list. To use this export function, subscribe to Intelligent O&M. - Locate a SQL template and click Details to view the total execution times, average rows scanned, average execution duration, and the like.
- Locate a SQL template and click SQL Throttling in the Operation column to add a SQL throttling rule. For details, see Configuring SQL Throttling.
- Select Comparison by Date and select dates and a time range to view the top SQL statements in the time range on different days.
