Help Center/ TaurusDB/ User Guide/ DBA Assistant/ What Is DBA Assistant?
Updated on 2025-10-27 GMT+08:00
DBA Assistant provides visualized database O&M and intelligent diagnosis for developers and database administrators (DBAs), making database O&M easy and efficient. By analyzing alarms, resource usage, health status, performance metrics, and storage usage, it helps you quickly locate faults and keep track of instance statuses.
To use DBA Assistant on the TaurusDB console, IAM users must have the TaurusDB FullAccess, CES FullAccess, and DAS FullAccess (or DAS Administrator) permissions. To grant these permissions, see Using IAM to Grant Access to TaurusDB.
Introduction Video
Functions
Table 1 lists the functions supported by DBA Assistant.
Table 1 Function description
Function
Reference
Dashboard
Shows the status of your instance, including alarms, resource usages, and key performance metrics. DBA Assistant diagnoses instance health using operational data analytics and intelligent algorithms, and provides you with solutions and suggestions for handling detected exceptions.
Viewing the Overall Status of a DB Instance
Sessions
The Sessions page displays slow sessions, active sessions, and total sessions. You can quickly filter slow sessions or active sessions by user, host IP address, or database name. Kill Session and SQL Throttling can be used for urgent instance recovery to ensure database availability.
Managing Real-Time Sessions
Performance
The Performance page displays key metrics of your instance and provides metric comparison between different days. You can keep track of metric changes and detect exceptions in a timely manner. Monitoring by Seconds helps accurately locate faults.
Performance Monitoring
Storage Analysis
Storage occupied by data and logs and changes of storage usage are important for database performance. The Storage Analysis page displays storage overview and disk space distribution of your instance. In addition, DBA Assistant can estimate the available days of your storage based on historical data and intelligent algorithms, so that you can scale up storage in a timely manner. Autoscaling, Tablespaces, Top 50 Databases, and Top 50 Tables are also available on this page.
Managing Storage
Slow Query Logs
Displays slow queries within a specified time period. You can view top 5 slow query logs by user or IP address, sort statistics, and identify sources of slow SQL statements.
Viewing Slow Query Logs
SQL Explorer
After Collect All SQL Statements is enabled, you can gain a comprehensive insight into SQL statements on the SQL Explorer page. Top SQL helps you locate exceptions.
SQL Throttling
SQL Throttling restricts the execution of SQL statements based on specified rules when there are SQL statements that cannot be optimized timely or a resource (for example, vCPU) bottleneck occurs.
Configuring SQL Throttling
