Configuring SQL Explorer for a DB Instance
Enabling SQL Explorer will allow TaurusDB to store all SQL statement logs for analysis.
You can enable SQL Explorer on the DAS console.
SQL Explorer cannot record all data. It has the following constraints:
- Some data cannot be recorded if a buffer overrun occurs.
- If the size of a SQL statement exceeds the value of rds_sql_tracer_max_record_size, the statement is not recorded by default.
rds_sql_tracer_max_record_size controls the maximum size of a SQL statement. To set this parameter, see Modifying Parameters of a DB Instance.
