Help Center/ TaurusDB/ User Guide/ Data Backup/ Automated Backups/ Configuring a Cross-Region Backup Policy
Updated on 2026-10-27 GMT+08:00
TaurusDB can store backups in a different region from the DB instance. If a DB instance in a region is faulty, you can use the backups in another region to restore data to a new DB instance.
After you enable cross-region backup, the backups are automatically stored in the region you specify. After cross-region backup is enabled, backups generated locally are not affected. Backups are stored both locally and remotely.
Precautions
  • To configure a cross-region backup policy, submit a service ticket to obtain permissions.
  • Cross-region backup can be enabled for up to 150 DB instances in a single region under a tenant. It is recommended that the data volume of a single DB instance be at most 2 TB. If the data volume is too large, the synchronization progress may be delayed.
  • The backup region needs to support OBS cross-region replication. For details about the supported regions, see Cross-Region Replication.
  • If your resource account is shared with other engines and cross-region backup policies are already configured for instances of those engines, the target region for your TaurusDB instance's cross-region backup policy must match the target region of an existing policy.
Supported Regions
Table 1 Supported regions
Instance Region
Backup Region
CN North-Beijing4
CN East-Shanghai1
CN East-Shanghai1
CN North-Beijing4
CN South-Guangzhou
  • CN East-Shanghai1
  • CN North-Beijing4
  • CN Southwest-Guiyang1
AP-Singapore
  • CN-Hong Kong
  • AP-Jakarta
AP-Jakarta
AP-Singapore
TR-Istanbul
AP-Singapore
ME-Riyadh
AP-Singapore
Billing
Table 2 Billing
Specification Code
Pricing
gaussdb.mysql.crossreg.backup.space
  • Regions in China (excluding Hong Kong): $0.000157 USD/GB/hour
  • Hong Kong and regions outside China: $0.00022 USD/GB/hour
  1. Log in to the TaurusDB console.
  2. Click in the upper left corner and select a region.
  3. On the Instances page, click the instance name.
  4. In the navigation pane, choose Backups. On the displayed page, click Configure Cross-Region Backup Policy.
  5. In the displayed dialog box, set the policy parameters.
    Figure 1 Configuring a backup policy
    Table 3 Parameter description
    Cross-Region Full Backup
    If you enable this option, automated full backups of the DB instance are stored in the region you specify.
    Cross-Region Incremental Backup
    If you enable this option, incremental backups of the DB instance are stored in the region you specify.
    • To enable cross-region incremental backup, enable cross-region full backup first.
    • After cross-region incremental backup is enabled, you can restore an instance to a specified point in time only after the next automated full backup replication is complete. The specified point in time must be later than the time when the automated full backup is complete.
    Region
    Select the region for storing backups.
    Retention Period
    Cross-region backup files can be retained from 1 to 1,825 days.
  6. Click OK.
  7. On the Cross-Region Backups tab of the Backups page, manage cross-region backups. By default, all instances with cross-region backups are displayed.
    • To modify the cross-region backup policy, click Set Cross-Region Backup in the Operation column.
    • To view generated cross-region backups, click View Cross-Region Backup in the Operation column. If a DB instance fails, you can use the cross-region backups to restore data to a new DB instance.
      Both full backups and incremental backups can be restored to new DB instances. Incremental backups can be restored to a specified point in time.
      Figure 2 Full backups
      Figure 3 Incremental backups
      Figure 4 Restoring an incremental backup to a point in time
    • To view all cross-region backups, click View All Backups.
      To restore a backup to a new DB instance, locate the backup and click Restore in the Operation. For details, see Restoring Data Across Regions.
    • To return to the instance list, click View Instances.
  2. In the upper left corner of the page, select the region where the original DB instance is located.
  3. Disable the cross-region backup policy using either of the following methods.
    Method 1:
    1. Choose Backups in the navigation pane and click the Cross-Region Backups tab.
    2. Locate the target DB instance and click Set Cross-Region Backup in the Operation column.
      Figure 5 Setting cross-region backup
    3. In the displayed dialog box, click next to Cross-Region Incremental Backup and Cross-Region Full Backup, respectively.
      Figure 6 Disabling cross-region backup
    4. Click OK.
    Method 2:
    1. On the Instances page, click the instance name.
    2. In the navigation pane, choose Backups.
    3. Click Configure Cross-Region Backup Policy.
    4. In the displayed dialog box, click next to Cross-Region Incremental Backup and Cross-Region Full Backup, respectively.
      Figure 7 Disabling cross-region backup
    5. Click OK.
