Help Center/ TaurusDB/ User Guide/ Instance Management/ Configuration Changes/ Changing the vCPUs and Memory of a DB Instance or Node Manually
Updated on 2026-06-04 GMT+08:00
You can change the specifications (vCPUs and memory) of a DB instance or node that is billed on a yearly/monthly or pay-per-use basis. You can also change specifications of multiple instances in batches. You can change the specifications of the primary node and read replicas separately. The specifications of read replicas can be different from those of the primary node. When you change the specifications of the primary node separately, the specifications of synchronous read replicas are also changed.
You can upgrade or downgrade specifications of your TaurusDB instance or node. Instance specifications can only be changed from general-purpose to dedicated.
To scale up the storage space of a yearly/monthly DB instance, see Changing the Storage Space of a DB Instance Manually and Configuring Autoscaling for a DB Instance.
Serverless DB instances do not support specification changes. To adjust the compute configuration of a serverless DB instance, see Changing the Compute Range of a Serverless Instance.
Principles
When you change the specifications of a DB instance, read replicas with the new specifications are automatically created. The number of created read replicas is the same as that of the original nodes. For example, if you change the specifications of a cluster instance with one primary node and one read replica, two read replicas with the new specifications are automatically created. Once created, these read replicas will replace the original nodes. One of the read replicas is promoted to primary, and the original primary node is automatically deleted. The remaining read replica replaces the original read replica, which then is also automatically deleted.
Table 1 Constraints
Phase
Constraint
Before the change
  • For batch specification changes, the original specifications, billing mode, instance type, AZ type, AZs, and kernel version of the instances must remain consistent.
  • You can change the specifications of a DB instance or just a single node within the instance.
  • Ensure that at least one read replica in a given instance has the same specifications as the primary node.
  • Changing the instance specifications will temporarily occupy IP addresses, and the IP addresses will not be released until 12 hours later by default. Before changing the instance specifications, ensure that there are unused private IP addresses. Otherwise, the change will fail.
    • Cluster instance: The number of private IP addresses must be the same as the number of nodes. For example, if a cluster instance has one primary node and three read replicas, four unused private IP addresses are required.
    • Single-node instance: One unused private IP address is required.
  • The time required for changing specifications depends on factors such as the number of nodes, database load, and number of database tables.
During the change
  • A DB instance or node cannot be deleted when its specifications are being changed.
  • If you want to change specifications during a maintenance window, you can cancel the task before it starts. Once started, the task cannot be canceled.
After the change
  • During an instance specification change, a read replica will be promoted to primary. To prevent service interruptions, perform the operation during off-peak hours.
  • Both the proxy instance and DB instance might be down for 15s to 30s during this change, so schedule the change during off-peak hours.
  • After instance specifications are changed, the system will change the values of the following parameters accordingly:
    • innodb_buffer_pool_size
    • innodb_log_buffer_size
    • max_connections
    • innodb_buffer_pool_instances
    • innodb_page_cleaners
    • innodb_parallel_read_threads
    • innodb_read_io_threads
    • innodb_write_io_threads
    • threadpool_size
  • The default value of innodb_parallel_select_count is OFF for instances with 16 vCPUs or less and ON for instances with more than 16 vCPUs.
    If you have modified this parameter before, the parameter value remains unchanged after the specifications are changed. Or, the default value is used.
Billing
Table 2 Billing
Billing Mode
Operation
Impact on Price
Yearly/Monthly
Specification upgrade
After instance specifications are upgraded, the new instance specifications take effect in the original usage period.
You need to pay for the difference in price based on the remaining period.
The following prices are for reference only. The actual prices are displayed on the console.
Suppose you purchased a one-month TaurusDB cluster instance (instance specifications: dedicated, 2 vCPUs | 8 GB, 2 nodes; storage: DL6, 10 GB) in CN-Hong Kong on April 1, 2025. The instance price was $296 USD per month.
On April 15, 2025, you changed the instance specifications to 4 vCPUs | 8 GB. The instance price became $586 USD per month.
Price difference = Price for the new instance specifications x Remaining period – Price for the original instance specifications x Remaining period
The remaining period is the remaining days of each calendar month divided by the maximum number of days in each calendar month.
In this example, the remaining period and price difference are calculated as follows: Remaining period = 15 (Remaining days in April)/30 (Maximum number of days in April) = 0.5. Price difference = $586 USD x 0.5 – $296 USD x 0.5 = $145 USD
Specification downgrade
After instance specifications are downgraded, the new instance specifications take effect in the original usage period.
TaurusDB refunds the difference in price based on the remaining period.
Suppose you purchased a one-month TaurusDB cluster instance (instance specifications: general-purpose, 4 vCPUs | 8 GB, 2 nodes; storage: DL6, 10 GB) in CN-Hong Kong on April 1, 2025. The instance price was $257.52 USD per month.
On April 15, 2025, you changed the instance specifications to 2 vCPUs | 4 GB. The instance price became $132.72 USD per month.
Refund = Price for the original instance specifications x Remaining period – Price for the new instance specifications x Remaining period
In this example, the remaining period and refunded fees are calculated as follows: Remaining period = 15 (Remaining days in April)/30 (Maximum number of days in April) = 0.5. Refund = $257.52 USD x 0.5 – $132.72 USD x 0.5 = $62.4 USD
Pay-per-use
After instance specifications are changed, the new instance specifications are billed by the hour immediately. For details, see Product Pricing Details.
Video Tutorial
Changing the Specifications of a DB Instance or Node
  1. Log in to the TaurusDB console.
  2. Click in the upper left corner and select a region and project.
  3. On the Instances page, locate the DB instance whose specifications you want to change and choose More > Change Instance Specifications in the Operation column.
    You can also enter the page for changing instance specifications in either of the following ways:
    • Click the instance name to go to the Basic Information page. In the Configuration area, click Change under Instance Specifications.
      Figure 1 Changing specifications in the Configuration area
    • Click the instance name to go to the Basic Information page. In the upper right corner of the page, click and choose Change Instance Specifications.
      Figure 2 Changing specifications on the Basic Information page
  4. On the displayed page, select the desired specifications. You can scale up or down the specifications as required.
    You can change the specifications immediately or during the maintenance window.
    • Upon submission: The specifications will be changed immediately after the task is submitted.
    • In maintenance window: The specifications will be changed during the maintenance window you specify.
  5. Click Next. On the displayed page, confirm the specifications.
    • If you need to modify your settings, click Previous to go back to the page where you specify details.
    • For pay-per-use instances, click Submit.
      To view the cost incurred by the specifications change, access the Billing Center page and then choose Billing > Dashboard in the navigation pane.
    • For yearly/monthly instances:
      • If you intend to scale down the specifications, click Submit.
        The refund is automatically returned to your account. You can access the Billing Center page and then choose Orders > My Orders in the navigation pane to view the details.
      • If you intend to scale up the specifications, click Submit. The scaling starts only after the payment is successful.
  6. If you have enabled operation protection, click Send Code in the displayed Identity Verification dialog box and enter the obtained verification code. Then, click OK.
    Two-factor authentication improves the security of your account. For details about how to enable operation protection, see Identity and Access Management User Guide.
  7. View the results.
    On the Instances page, check that the status of the instance is Changing instance specifications. After 5 to 15 minutes, click the instance name to view the new instance specifications on the Basic Information page.
  3. On the Instances page, click the target instance name.
  4. In the node list, locate the primary node and click Change Instance Specifications in the Operation column.
  5. On the displayed page, select the desired specifications. You can scale up or down the specifications as required.
  6. Click Next. On the displayed page, confirm the specifications.
    Check that the status of the primary node is Changing instance specifications. After 5 to 15 minutes, view its new specifications on the Basic Information page.
  4. In the node list, locate a read replica and click Change Instance Specifications in the Operation column.
      • Scaling down the specifications: click Submit.
      • Scaling up the specifications: click Submit. The scaling starts only after the payment is successful.
    Check that the status of the read replica is Changing instance specifications. After 5 to 15 minutes, view its new specifications on the Basic Information page.
  3. On the Instances page, select at least one instance (maximum: 50) and click Change Instance Specifications above the instance list.
  4. On the displayed page, select the required specifications. You can scale up or down the specifications as required.
    For batch specification changes, only the Upon submission option is available for the maintenance window.
    • If you need to modify the settings, click Previous.
  6. Check the result.
    On the Instances page, you can see that the instance status is Changing instance specifications. The process takes 5 to 15 minutes. Then, go to the Basic Information page and view the instance specifications.
Follow-up Operations
Return to the instance list. In the navigation pane, choose Task Center and check the progress of the change task.
  • If you have selected Upon submission for Scheduled Time:
    On the Instant Tasks page, search for Changing the specifications of a TaurusDB instance and check the execution progress. Instant tasks cannot be canceled.
  • If you have selected Maintenance Window for Scheduled Time:
    On the Scheduled Tasks page, search for the instance ID and check the execution status of the change task.
    If the task is in the To be executed state, you can click Cancel to cancel the task.
For details, see Viewing a Task.
