Help Center/ TaurusDB/ User Guide/ Database Usage/ Database Management/ Granting Database Permissions
Updated on 2026-07-16 GMT+08:00
You can grant permissions to database users you have created to use specific databases or revoke permissions from specific database users.
- This operation is not allowed for instances that are being restored.
- An account with read-only or read/write permissions on all databases can still be granted read-only or read/write permissions on specific databases. The account's actual permissions are a combination of permissions on all and specific databases.
- Log in to the TaurusDB console.
- Click
in the upper left corner and select a region. - On the Instances page, click the instance name.
- In the navigation pane, choose Databases. On the displayed page, locate the target database and click Authorize in the Operation column.
- In the displayed dialog box, select one or more unauthorized database users, and select the read-only or read/write permission in the Authorized Users area. Figure 1 Changing permissions
If no users are available, you can create one by referring to Creating an Account.
- Click OK.
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
