Help Center/ TaurusDB/ User Guide/ Instance Management/ Instance Lifecycle Management/ Unsubscribing from a Yearly/Monthly DB Instance
Updated on 2026-02-03 GMT+08:00
To delete a yearly/monthly DB instance, you need to unsubscribe from the order. You can unsubscribe from a single instance by referring to Unsubscribing from a DB Instance on the TaurusDB Console and Unsubscribing from a DB Instance in the Billing Center or unsubscribe from instances in batches by referring to Unsubscribing from DB Instances in Batches. For unsubscription fees, see Unsubscription Rules.
For pay-per-use and serverless DB instances, you need to delete them on the Instances page. For details, see Deleting a DB Instance.
  • A DB instance cannot be unsubscribed when any operations are being performed on it. It can only be unsubscribed after the operations are complete.
  • If a backup of a DB instance is being restored, the instance cannot be unsubscribed.
  • After an unsubscription request is submitted, resources and data will be deleted and cannot be retrieved. To retain data, back it up before submitting the unsubscription request.
Unsubscribing from a Single DB Instance
You can unsubscribe from a yearly/monthly DB instance on the Instances page of the TaurusDB console or on the Billing Center page.
Unsubscribe from a yearly/monthly DB instance on the Instances page.
  1. Log in to the TaurusDB console.
  2. Click in the upper left corner and select a region and project.
  3. On the Instances page, locate the instance and choose More > Unsubscribe in the Operation column.
  4. On the displayed page, confirm the order to be unsubscribed and select a reason. Then, click Confirm.
    For unsubscription details, see Unsubscription Rules.
  5. In the displayed dialog box, confirm the unsubscription information, enter YES, and click OK.
    Figure 1 Unsubscribing from resources
  6. If you have enabled operation protection, click Send Code in the displayed Identity Verification dialog box and enter the obtained verification code. Then, click OK.
    Two-factor authentication improves the security of your account. For details about how to enable operation protection, see Identity and Access Management User Guide.
  7. Check the unsubscription results. After you unsubscribe from the instance order, the instance is no longer displayed on the Instances page.
Unsubscribe from a yearly/monthly DB instance on the Billing Center page.
  3. In the upper right corner, click Billing.
  4. In the navigation pane, choose Orders > Unsubscriptions.
  5. On the displayed page, select the order to be unsubscribed and click Unsubscribe in the Operation column.
    • You can select TaurusDB in the Product Type/Specifications filter box to filter all TaurusDB orders.
    • You can search for resources by instance ID/resource ID, instance name, or order number above the order list.
  6. On the displayed page, confirm the order to be unsubscribed and select a reason. Then, click Confirm.
  7. In the displayed dialog box, click OK.
  8. Check the unsubscription results. After you unsubscribe from the instance order, the instance is no longer displayed on the Instances page.
Unsubscribe from yearly/monthly DB instances in batches on the Billing Center page.
  5. On the displayed page, select the orders to be unsubscribed and click Batch Unsubscribe.
    Up to 100 resources can be unsubscribed at once.
  6. On the displayed page, confirm the orders to be unsubscribed and select a reason. Then, click Confirm.
  8. Check the unsubscription results. After you unsubscribe from the instance orders, the instances are no longer displayed on the Instances page.
