Help Center/ TaurusDB/ User Guide/ Instance Management/ Configuration Changes/ Changing the Maintenance Window of a DB Instance
Updated on 2026-02-13 GMT+08:00
The maintenance window is 02:00–06:00 by default and you can change it as required. To prevent service interruption, set the maintenance window to off-peak hours.
  1. Log in to the TaurusDB console.
  2. Click in the upper left corner and select a region and project.
  3. On the Instances page, click the instance name to go to the Basic Information page.
  4. On the Instance Information page, click Change under Maintenance Window.
    Figure 1 Changing a maintenance window
  5. In the displayed dialog box, select a maintenance window and click OK.
    Figure 2 Changing a maintenance window
    Changing the maintenance window will not affect the timing that has already been scheduled.
  6. On the Basic Information page, check that the maintenance window is updated.
