Upgrading a Component in Dark Launch Mode
Updated on 2024-12-16 GMT+08:00
NOTICE:
During the dark launch upgrade in this operation, do not perform dark launch of the component bound to a ServiceComb engine or through registry/configuration enter. Otherwise, this operation will fail.
  • For details about how to perform dark launch of a component through ServiceComb engines, see Dark Launch.
  • For details about how to perform dark launch of a component through registry/configuration centers, see Configuring Dark Launch.
After a component is created and deployed, you can upgrade a component in ServiceStage dark launch mode.
For details about how to upgrade multiple component versions of the same application in batches, see Upgrading Components in Batches.
Introduction to Dark Launch
In dark launch mode, a certain proportion of instances are upgraded, and traffic is directed to the new version to verify whether functions of the new version are normal. Then, the remaining instances will be upgraded in rolling mode. Dark launch ensures stability of the entire system. During initial dark launch, problems can be detected and fixed.
Table 1 Dark launch types and description
Type
Microservice Dark Launch
Applies to container-deployed ServiceComb and Spring Cloud components. Dark launch tasks function on microservices. Multiple microservices can work together to roll out new features.
  1. The Java, Tomcat, or Docker technology stack must be selected for the component.
  2. The component must be bound to a ServiceComb engine with security authentication disabled and multi-language access to service mesh disabled.
    • For ServiceComb engines, Java chassis 2.7.8 or later and Spring Cloud Huawei 1.10.4-2021.0.x or later are required.
    • For registry/configuration centers, Spring Cloud Huawei version must be 1.11.9-2021.0.x, 1.11.9-2022.0.x, 1.11.9-2023.0.x, or later.
ELB Dark Launch
Applies to ELB traffic-based and container-deployed components. Dark launch tasks function on ELB.
  1. Log in to ServiceStage.
  2. Use either of the following methods to go to the component Overview page.
    • On the Application Management page, click the application to which the component belongs, and click the target component in Component List.
    • On the Component Management page, click the target component.
  3. Click Upgrade in the upper right corner of the page.
  4. Select Dark Launch (Canary).
  5. Click Next and set the component version configuration information by referring to the following table. Parameters marked with an asterisk (*) are mandatory.
    Stack
    Select a component technology stack and version.
    For details, see Technology Stack.
    *Software Package/Image
    The value is fixed to the component source selected during component creation and deployment.
    • If you select Source code repository, create authorization by referring to Creating Repository Authorization and set the code source.
    • If you select a software package or image package, the option is fixed to the software package type (JAR, WAR, or ZIP) or image package type selected during component creation and deployment. It is determined by the selected technology stack type. For details, see Table 1.
    *Upload Method
    If the component source is software package or image package, select an uploaded software package or image package. For details about the upload method, see Component Source.
    • If the component source is software package and Custom file address is selected, perform the following operations:
      1. Enter the custom HTTP/HTTPS file download address of the software package.
      2. Determine whether to enable authentication.
        If authentication is disabled, any user can download the software package in the custom file address by default.
        Click to enable authentication. Only authenticated users can download the software package in the custom file address. Authentication mode can be User name and password authentication or User-defined Header Authentication. The authentication mode and the corresponding authentication parameters are determined by the authentication mode supported by the server where the custom file directory is located.
    • If the component source is image package:
      • You can customize the container name. The name contains 1 to 63 characters, including lowercase letters, digits, and hyphens (-), and must start with a lowercase letter and end with a lowercase letter or digit.
      • Click in the upper right corner of the selected image package to change the image package source.
    Image Access Credential
    • You can select up to 16 image access credentials.
    • Click Create Secret to create an image access credential. Secret Type must be kubernetes.io/dockerconfigjson. For details, see Creating a Secret.
    *Command
    This parameter is mandatory when the component source is Source code repository and the selected technology stack type is Java, Tomcat, Node.js, Python, or PHP.
    • Default command or script: preferentially executes build.sh in the root directory. If build.sh does not exist, the code will be compiled using the common method of the selected language. Example: mvn clean package for Java.
    • Custom command: Commands are customized using the selected language. Alternatively, the default command or script is used after build.sh is modified.
      NOTICE:
      • If Custom command is selected, exercise caution when inputting sensitive information in the echo, cat, or debug command, or encrypt sensitive information to avoid information leakage.
      • To run the compilation command in the project subdirectory, you need to go to the project subdirectory and then run other script commands. Example:
        cd ./weather/
        mvn clean package
    *Dockerfile Address
    Dockerfile Address is the directory where the Dockerfile is located relative to the root directory (./) of the project. The Dockerfile is used to build an image.
    If Dockerfile Address is not specified, the system searches for the Dockerfile in the root directory of the project by default. If the Dockerfile does not exist in the root directory, the system automatically generates the Dockerfile based on the selected operating environment.
    *Component Version
    Component version number, which can be automatically generated or customized.
    • Automatically-generated: Click Generate. By default, the version number is the time when you click Generate. The format is yyyy.mmdd.hhmms, where s is the ones place of the second in the timestamp. For example, if the timestamp is 2022.0803.104321, the version number is 2022.0803.10431.
    • Customized: Enter a value in the format of A.B.C or A.B.C.D. A, B, C, and D are natural numbers. For example, 1.0.0 or 1.0.0.0.
      NOTICE:
      The customized version number must be unique and cannot be the same as any historical version number of the component. Otherwise, the current deployment record will overwrite the historical deployment record of the same version.
    *Container Name
    This parameter is mandatory when the technology stack is not Docker.
    The name contains 1 to 63 characters starting with a lowercase letter and ending with a lowercase letter or digit. Only lowercase letters, digits, and hyphens (-) are allowed.
    Resources
    You can customize CPU and Memory to set their quota, and set the maximum/minimum number of CPU cores and memory size (GiB) that can be used by components. In this way, you can set the number of resources required by each component instance.
    When resource Request is specified for a component instance, CCE uses this information to determine the node to which the component instance is scheduled. When resource Limit is specified for a component instance, CCE ensures that the resources occupied by the running component instance do not exceed the limit. CCE will also reserve the requested number of system resources for the component instance. For details about how to configure them, see Resource Management.
    To modify them, select the item to be changed and enter a new value. Unselected parameters indicate no restriction.
    JVM Parameters
    This parameter is available when the technology stack type is Java or Tomcat. It configures the memory parameter size during Java code running.
    Enter the JVM parameter, for example, -Xms256m -Xmx1024m. Multiple parameters are separated by spaces. If the parameter is left blank, the value is empty.
    Tomcat
    This parameter is available when the technology stack type is Tomcat. It configures parameters such as the request path and port number of Tomcat.
    1. Select Tomcat. The Tomcat dialog box is displayed.
    2. Click Use Sample Code and edit the template file based on service requirements.
      In Tomcat configuration, the default server.xml configuration is used. The context path is /, and no application path is specified.
      If you need to customize an application path, customize the Tomcat context path by referring to How Do I Customize a Tomcat Context Path?
    3. Click OK.
    Container Settings
    Set this parameter as required by referring to Managing Container Settings of a Container-Deployed Component.
    Application Settings
    Set this parameter as required by referring to Managing Application Settings of a Container-Deployed Component.
    Advanced Settings
    Set this parameter as required by referring to Managing Advanced Settings of a Container-Deployed Component.
    *Deployment Architecture
    1. Click Select and select an instance deployment architecture for dark lunch.
    2. Click OK.
    NOTICE:
    You must choose the correct architecture. Otherwise, dark launch will fail and services will be affected.
    Click Change to reselect a deployment architecture.
    *Dark Launch Policy
    Select a dark lunch policy.
    • Traffic ratio-based: Flexibly and dynamically adjust the traffic ratio of different versions.
    • Content-based: Control the version to which the request is sent according to the request.
      ELB dark launch supports only the Traffic ratio-based policies.
    *Traffic Ratio
    When Dark Launch Policy is set to Traffic ratio-based, set the traffic ratio.
    • Traffic Ratio: percentage of traffic directed to the new version.
    • Current Traffic Ratio: percentage of traffic directed to the current version.
    *Takes effect
    When Dark Launch Policy is set to Content-based, set the effective mode of the dark launch policy.
    • With single criterion: The dark launch policy takes effect when any matching rule is met.
    • With full criteria: The dark launch policy takes effect when all matching rules are met.
    *Matching Rule
    When Dark Launch Policy is set to Content-based, set the matching rule for the dark launch policy to take effect.
    1. Click Add Matching Condition.
    2. Set Matching Type. Currently, only Request header is supported.
    3. Set Parameter Name, that is, the key corresponding to Matching Type.
    4. Set Condition Type, that is, the matching rule that Condition Value meets.
      • Equal: The value corresponding to Matching Type is equal to the configured Condition Value.
      • Matching: Condition Value supports PERL-compatible regular expressions. It is supported by only microservice dark launch.
      • Enumerated: Multiple Condition Value are separated by commas (,).
    5. Set Condition Value, that is, the value corresponding to Matching Type.
    *Instances Deployed for Dark Launch
    Select a mode for adding an instance during dark launch.
    • Blue-green
      Add new version instances with the same number as the old version instances, and switch traffic to the new version based on dark launch rules. After verification based on the dark launch rules, switch all traffic to the new version and delete the old version.
      Scenarios: lossless service capacity, fast rollback, and when resources are needed in the cluster.
      This mode requires one or more component instances.
    • Canary (increase, then decrease)
      Add new version instances with the specified number, and switch traffic to the new version based on dark launch rules. After verification based on the dark launch rules, delete some old instances, add corresponding new instances, and switch traffic. Repeat this process until all traffic is switched to the new instances and old instances are deleted.
      Scenarios: lossless service capacity, slow rollback, and when resources are needed in the cluster.
      This mode requires two or more component instances.
    • Canary (decrease, then increase)
      Delete some old instances and add corresponding new instances, and switch traffic to the new version based on dark launch rules. After verification based on the dark launch rules, delete some old instances, add corresponding new instances, and switch traffic. Repeat this process until all traffic is switched to the new instances and old instances are deleted.
      Scenarios: lossy service capacity and slow rollback.
    To change the number of component instances to meet the requirements, see Configuring a Manual Scaling Policy.
  6. Click Upgrade.
    • Wait until the component status changes from Upgrading/Rolling back the component to Running, indicating that the component has been upgraded.
    • On the Deployment Records page, view the deployment logs.
      For container-deployed components, if "Querying the Status of a Workload Instance" is displayed, click View Event to view details.
Follow-up Operations
Operation
View the deployment logs
Select a deployment record in the Deployment Records list and view component deployment logs on the Deployment Log tab.
View system monitoring
If the component is upgraded through dark launch, choose System Monitoring to check the CPU and memory usage of instances of the dark launch version and the current version after the first batch of dark launch is complete.
Modify a dark launch policy
If the component is upgraded through dark launch, you can modify the dark launch policy by referring to Modifying a Component Dark Launch Policy after the first batch of dark launch is complete.
Complete processes
If the component is upgraded through dark launch after the first batch of dark launch is successful and the functions of the new version are normal, you can perform the following operations to upgrade the remaining component instances:
  1. Select the deployment record of the Dark Launch type.
  2. Click Complete Processes.
  3. In the displayed dialog box, click OK.
    Upgrade the remaining instances to the new version.
Roll back a component
The component can be rolled back in the following scenarios:
  • The first batch of dark launch is complete if the component is upgraded through dark launch.
  • All component instances have been upgraded to the new version.
To roll back the component configuration to the source version, refer to Rolling Back a Component.
Redeploy a component
After all component instances are upgraded to the new version, select a deployment record and use it as a template to deploy components again. For details, see Redeploying a Component.
