Viewing Component Details
After the component is created and deployed, you can view the component details on its Overview page.
- To view the YAML configurations of a CCE-deployed component, enable View YAML Mode. The parameters in the YAML configuration file are described in Deployment.
- Click Synchronize Workload to synchronize latest configurations after CCE-based component workload changes (such as workloads upgraded using CCE).
- Log in to ServiceStage.
- Use either of the following methods to go to the component Overview page.
- On the Application Management page, click the application to which the component belongs, and click the target component in Component List.
- On the Component Management page, click the target component.
- On the component Overview page, view the component status and other details.
For details about component status description, see Table 1.
- Click a component in a state except Draft to view the deployment records.
- Click a component in the Draft state. You can continue to create and deploy components by referring to Creating a Component Based on a Container Using Manual Configurations, Creating a Component Based on a Container Using YAML Configurations, or Creating a Component Based on a VM.
Table 1 Component statuses Status
Initializing
When Creating a Component Based on a Container Using Manual Configurations, Creating a Component Based on a Container Using YAML Configurations, Creating a Component Based on a VM, or Creating a Component Using a Component Template, the component is in this state after you click Create and Deploy.
Upgrading/Rolling back the component
The component is in this state when Upgrading a Component in Single-batch Release Mode, Upgrading a Component in Rolling Release Mode, Upgrading Components in Batches, Rolling Back a Component, Redeploying a Component in Single-batch Release Mode, Upgrading a Component Using a Component Template, or Redeploying a Component in Rolling Release Mode.
Scaling
After Configuring a Manual Scaling Policy, the component is in this state during policy execution.
Failed
The operation on the component fails. For example, component deployment, upgrade, or rollback fails.
You can click Failed to go to the Deployment Records list to view the failure cause.
Running
The operation on the component is successful, and the component status is normal. For example, component deployment, upgrade, or rollback is successful.
Deleting
The component is in this state when Deleting a Component.
Starting
The component is in this state during the start process by referring to Starting or Stopping a Component.
Stopping
The component is in this state during the stop process by referring to Starting or Stopping a Component.
Stopped
The component is in this state after being stopped by referring to Starting or Stopping a Component.
Restarting
The component is in this state during the restart process by referring to Starting or Stopping a Component.
Not ready
The component is in this state when the number of running component instances is less than the total number of component instances.
Unknown
A container-deployed component is in this state after Unknown is returned during synchronization from its CCE.
Abnormal
A container-deployed component is in this state after its CCE cluster or workload is deleted.
Releasing
The component is in this state when Upgrading a Component in Dark Launch Mode or Redeploying a Component in Dark Launch Mode.
Gray Release Failed
The component is in this state after Upgrading a Component in Dark Launch Mode or Redeploying a Component in Dark Launch Mode fails.
Draft
The component is being created and the parameter configuration is not complete. It is used to prevent the configured parameters from being lost due to factors such as page closing.
When Creating a Component Based on a Container Using Manual Configurations, Creating a Component Based on a Container Using YAML Configurations, or Creating a Component Based on a VM, the component is in this state after you click Save as Draft.
Imported and to be restarted
The component is waiting to restart after Creating a Component by Importing a CCE Workload.
Imported and restarting
The component is restarting after Creating a Component by Importing a CCE Workload.
Restart failed
The component is in this state if it fails to be restarted by referring to Starting or Stopping a Component.
Processing
The container-deployed component whose Workload Type is Job is in this state when each job is processed in sequence.
Completed
The container-deployed component whose Workload Type is Job is in this state when all jobs have been processed.
