Managing Basic Resources
After an environment is created, you can manage required basic resources and combine them into an environment for deploying and running components.
- You have created an environment. For details, see Creating an Environment.
- You have created basic resources based on the environment type and site requirements by referring to the following table.
Resource Type
Resource Name
Restrictions
Creation Method
Billing
Clusters
Used to deploy components in container mode. Components are deployed using container images and scheduled by Kubernetes.
Clusters can be bound to a Kubernetes or VM + Kubernetes environment.
See Binding a Cluster.
See CCE Billing.
ECSs
Used to deploy and run components based on a VM.
ECSs can be managed in a VM or VM + Kubernetes environment.
The ECS must be in the same VPC as the environment and cannot be managed by other environments.
See ECS Billing.
Custom servers
You can manage custom servers on ServiceStage for deploying and running components based on a VM.
Custom servers can be managed in a VM or VM + Kubernetes environment.
You have obtained the name, unique ID, and IP address of the custom server, and the custom server cannot be managed by other environments.
AS Groups
AS groups can be managed in a VM or VM + Kubernetes environment.
The AS group must be in the same VPC as the environment and cannot be managed by other environments.
See Creating an AS Group.
See AS Pricing Details.
Load Balancers
Used to access services provided by a component through the domain name using the load balancer bound with an EIP, or to upgrade the container-deployed components through ELB dark launch.
- Use the domain name to access an application.
- See Creating a Shared Load Balancer.
- Create an application load balancer by referring to Creating a Dedicated Load Balancer.
- ELB dark launch
See ELB Billing.
EIP
Used to access services provided by a component.
See Assigning an EIP.
See EIP Billing.
VPCs
Provides a logically isolated, configurable, and manageable virtual network environment, improving cloud resource security and simplifying network deployment.
See VPC Billing.
Subnet
A subnet is a CIDR block in a VPC, and is on the Layer 3 network. You can create multiple subnets in a VPC to manage cloud resources.
See VPC Billing.
ACL
Provides security protection for associated subnets.
See VPC Billing.
DCS Instances
Used to read environment variables to obtain distributed cache information during application running.
See DCS Billing.
ServiceComb Engines
Microservice engine (see Cloud Service Engine Overview), which is used to connect microservices running in the environment to the engine to implement microservice registry and discovery, service governance, and configuration management.
In an HA environment of the Kubernetes type, each AZ can manage only one ServiceComb engine.
- If you have purchased a ServiceStage resource package, you can create a ServiceComb engine of the corresponding version for free. For details, see Buying a ServiceStage Resource Package.
- If you use ServiceStage in pay-per-use billing mode or create additional ServiceComb engines, see ServiceComb Engine Billing.
Registry/Configuration Center
Connects microservices running in the environment to implement microservice registry and discovery, and configuration management.
For details, see Creating a Registry/Configuration Center.
RDS Instances
Used for persistent storage of application data.
For details, see Buying an RDS for MySQL DB Instance.
See RDS Billing.
Application Gateways
Connects microservices running in the environment to implement full-link rate limiting and API management.
In an HA environment of the Kubernetes type, each AZ can manage only one application gateway.
See GaussDB Billing.
RocketMQ
Used for application production message storage and consumption subscription.
See RocketMQ Billing.
CSS
Uses the multi-condition search, statistics, and report capabilities of structured and unstructured text provided by the Elasticsearch cluster of Cloud Search Service (CSS) to analyze component logs in all scenarios.
See CSS Billing.
- Log in to ServiceStage.
- Choose Environment Management. The Environment Management page is displayed.
- Click the target environment. The Overview page is displayed.
- Manage the required basic resources in the environment by referring to the following table.
Resource Type
Resource Name
Operation
Clusters
Clusters (CCE and custom Kubernetes clusters) can be bound to a Kubernetes or VM + Kubernetes environment. To manage clusters in the environment, see Managing Cluster Resources.
ECSs
- Choose Compute > ECSs.
- Click Manage Resource.
- Select the ECSs to be managed.
- Click OK.
- ECSs can be managed in a VM or VM + Kubernetes environment.
- ECSs that have been managed by other environments cannot be managed again.
- If Agent Status of the managed ECSs indicates that the agent is missing and to install it first, install the agent. For details, see Installing a VM Agent.
Custom servers
- Choose Compute > Custom servers.
- Set Server Name, ID, and IP of the target custom server.
- Click Add Server to add more custom servers to the environment.
- Click Remove to remove a custom server from the list.
- Click OK.
- Custom servers can be managed in a VM or VM + Kubernetes environment.
- For custom servers that are initially managed and do not have a VM agent installed (see Installing a VM Agent), you need to customize the Server Name and ID. Where,
Server Name contains 1 to 128 characters. Use letters, digits, underscores (_), hyphens (-), and dots (.).
ID contains 1 to 64 characters. Use letters, digits, underscores (_), and hyphens (-).
Keep the custom ID properly for future operations such as re-management.
- To manage a custom server with a VM agent installed (see Installing a VM Agent), set ID to the value you have defined during the first management. Server Name can be customized.
- The custom server to be managed must be able to access the environment where ServiceStage is deployed through network and cannot be managed by other environments.
AS Groups
- Choose Compute > AS Groups.
- Select the AS groups to be managed.
- Click OK.
- AS groups can be managed in a VM or VM + Kubernetes environment.
- AS groups that have been managed by other environments cannot be managed again.
- If Agent Status of the ECSs of the managed AS groups indicates that the agent is missing and to install it first, install the agent. For details, see Installing a VM Agent.
Load Balancers
- Choose Networking > Load Balancers.
- Select the load balancers to be managed.
- Click OK.
EIP
- Choose Networking > VPC EIPs.
- Select the EIPs to be managed.
- Click OK.
VPCs
- Choose Network > VPCs.
- Select the VPCs to be managed.
- Click OK.
Subnet
- Choose Network > Subnet.
- Select the VPC subnets to be managed.
- Click OK.
ACL
- Choose Network > ACL.
- Select the ACLs to be managed.
- Click OK.
DCS Instances
- Choose Middleware > DCS Instances.
- Select the DCS instances to be managed.
- Click Next.
- (Optional) Set Redis Login Password.
If the selected DCS instances are configured with the password access mode, you need to set the login password.
You can also skip this operation and configure the parameters by referring to Follow-up Operations after the DCS instances are successfully managed.
- Click OK.
After the DCS instances are successfully managed in the environment, ServiceStage writes the built-in and custom environment variables in the environment by referring to Table 1 for use.
ServiceComb Engines
- Choose Middleware > ServiceComb Engines.
- Select the ServiceComb engines to be managed.
- Click OK.
After the ServiceComb engines are successfully managed in the environment, ServiceStage writes the built-in environment variables in the environment by referring to Table 1 for use.
- Choose Middleware > Registry/Configuration Center.
- Select the registry/configuration centers to be managed.
- Click OK.
After the registry/configuration centers are successfully managed in the environment, ServiceStage writes the built-in environment variables in the environment by referring to Table 1 for use.
RDS Instances
- Choose Middleware > RDS Instances.
- Select the RDS instances to be managed.
- Click Next.
- (Optional) Set Database Name, Database User Name, and Database Login Password.
You can also skip this operation and configure the parameters by referring to Follow-up Operations after the RDS instances are successfully managed.
- Click OK.
After the RDS instances are successfully managed in the environment, ServiceStage writes the built-in and custom environment variables in the environment by referring to Table 1 for use.
- Choose Middleware > Application Gateways.
- Before managing the application gateways in the HA environment of the Kubernetes type, select the AZ where these application gateways are located.
- Select the application gateways to be managed.
- Click OK.
- Choose Middleware > GaussDB.
- Select the GaussDB instances to be managed.
- Click Next.
You can also skip this operation and configure the parameters by referring to Follow-up Operations after the GaussDB instances are successfully managed.
- Click OK.
After the GaussDB instances are successfully managed in the environment, ServiceStage writes the built-in and custom environment variables in the environment by referring to Table 1 for use.
RocketMQ
- Choose Middleware > RocketMQ.
- Select the RocketMQ instances to be managed.
- Click Next.
- (Optional) Set Username and Password.
You can also skip this operation and configure the parameters by referring to Follow-up Operations after the RocketMQ instances are successfully managed.
- Click OK.
After the RocketMQ instances are successfully managed in the environment, ServiceStage writes the built-in and custom environment variables in the environment by referring to Table 1 for use.
CSS
- Choose Middleware > CSS.
- Select the Elasticsearch cluster to be managed.
- Click Next.
You can also skip this operation and configure the parameters by referring to Follow-up Operations after the Elasticsearch clusters are successfully managed.
- Click OK.
After the Elasticsearch clusters are successfully managed in the environment, ServiceStage writes the built-in and custom environment variables in the environment by referring to Table 1 for use.
- Click OK.
After the basic resources are managed, click Overview and select the basic resources (for example, VPC) managed in 4. You can see that Status is Available and Resource Mode is Manage.
Resource Type |
Maintenance Operation |
Description |
DCS |
Setting the connection password |
A password has been set for the managed DCS instances. You need to enter the password.
Setting environment variables of an environment |
RDS |
Setting the account and password |
Set the name, username, and password of the database that can be accessed by the managed RDS instance.
RocketMQ |
Set the username and password for accessing the managed RocketMQ instance.
GaussDB |
Set the name, username, and password of the database that can be accessed by the managed GaussDB instance.
CSS |
Set the username and password for accessing the managed CSS Elasticsearch cluster.
