Updated on 2026-02-06 GMT+08:00
Viewing a Workspace
This section describes how to view the information about a workspace, including its name, type, and creation time.
SecMaster allows you to view the information about all region workspaces on the workspace management page. If the workspace information cannot be viewed and a message is displayed indicating that you have not purchased SecMaster, enable any SecMaster edition.
For example, if you have purchased SecMaster and created workspaces in the CN-Hong Kong region, when you switch to the AP-Bangkok region, you can still view the workspaces in the CN-Hong Kong region on the workspace management page. If the system displays a message indicating that you have not purchased SecMaster and cannot view the workspace information, enable any SecMaster edition.
Limitations and Constraints
The newly created workspace needs to be initialized. After the workspace is created, wait for about 10 minutes and refresh the page to view the workspace.
Viewing a Workspace
  1. Log in to the SecMaster console.
  2. Click in the upper left corner of the management console and select a region or project.
  3. In the navigation pane on the left, choose Workspaces > Management.
    Figure 1 Workspaces > Management
  4. On the Management page, view information about existing workspaces.
    If there are many workspaces, you can use filters to quickly search for a specific workspace.
    Figure 2 Workspace details
    Table 1 Workspace parameters
    Workspace Name
    Name of the workspace.
    Workspace Type
    Type of the workspace.
    Workspaces are classified as common workspaces and workspace agency views.
    • Common workspaces
      • Not hosted: Workspaces are not managed by any workspace agency view. These workspaces have their tags displayed next to their names.
      • Managed: Workspaces that are managed by a workspace agency view. Managed is displayed next to workspace names.
    • Agency views
      • Agency view: You can use an agency view to manage other workspaces centrally for cross-account security operations. For more details, see Creating a Workspace Agency.
    ID
    ID of the workspace.
    Region
    Region to which the workspace belongs.
    Project
    Project to which the workspace belongs.
    More
    Hover over More to view the workspace ID, region, project, enterprise project, and creation time.
    Hosting Status
    Whether the workspace is hosted.
    Incidents
    Number of incidents in the workspace. For more details, see Viewing Incidents.
    Vulnerabilities
    Number of vulnerabilities in the workspace. For more details, see Overview.
    Alerts
    Number of alerts in the workspace. For more details, see Overview.
    Indicators
    Number of indicators in the workspace. For more details, see Viewing Indicators.
    Assets
    Number of assets in the workspace. For more details, see Overview.
    Security Analysis
    Number of data spaces in the workspace.
    Instances
    Number of instances in the workspace.
    Playbooks
    Number of playbooks in the workspace For more details, see Overview.
  5. To view details about a workspace, click on the right of the workspace. The workspace details page is displayed.
    • On the workspace details page, you can view the workspace name, creation time, and project a workspace belongs to. You can also modify the workspace name and description.
    • On the Tag Management tab, you can edit tags. For details, see Managing Workspace Tags.
    • On the Navigation Settings tab, you can set the directories of the current workspace. The following table lists the parameters on the Navigation Settings tab.
    Table 2 Directory parameters
    Display Breadcrumb Navigation
    This function is enabled by default. This parameter determines whether users can return to the upper-level navigation directory.
    • Enabled: Users can return to the outer workspace management navigation directory.
    • If this function is disabled, users cannot return to the outer workspace management navigation directory.
    Workspace Navigation Settings
    • Add: You can add a custom directory.
    • Edit: You can edit multiple directories at a time, set Landing Page, and configure Display. The landing page is the default page displayed after you click a workspace name.
    • Delete: You can delete multiple directories at a time. Only custom directories can be deleted. Built-in directories cannot be deleted.
    Navigation Name
    Name of the level-1 directory that the navigation belongs to. You can click next to the level-1 directory name to expand the level-2 directory names of the level-1 directory.
    Status
    Type of the directory.
    Publisher
    Publisher of the directory. The default publisher of a built-in directory is CloudService.
    Layout
    Layout associated with the directory.
    Address
    Address of the directory. URL of the directory page. The URL is automatically generated by the system.
    Chinese Alias
    Chinese name of the directory.
    Alias
    English name of the directory.
    Landing Page
    Default page that is displayed when you click a workspace name.
    • A workspace must have a landing page.
    • Only one directory that can be displayed can be set as the landing page.
    • A level-1 directory cannot be set as a landing page.
    Display
    Whether the directory is displayed in the navigation pane.
    Operation
    Operations you can do for the directory. You can edit a directory and change the layout.
    Edit: You can edit Chinese Alias, Alias, Landing Page, and Display of the directory.
    Change Layout: You can change the layout of a custom directory or a built-in directory that is associated with a layout. Only other layouts of the same type can be replaced.
