On this page
(Optional) Configuring Fault Information Storage
Updated on 2023-02-28 GMT+08:00
Overview
This section describes how to configure data storage for abnormal data integration tasks. You can configure data storage only if the data source type is DB2, DWS, MySQL, GaussDB(for MySQL), Oracle, PostgreSQL/openGauss, SQL Server, or Gauss100 at the destination.
During each task execution, if some data at the source meets integration conditions but cannot be integrated to the destination due to network jitter or abnormal data conversion, ROMA Connect stores the data to the OBS bucket as text files.
NOTICE:
Expand the abnormal data storage module if you need to configure it (Table 1 describes its parameters). Otherwise, collapse the module to prevent task saving exceptions.
Before configuring fault information storage, ensure that you have connected the OBS data source to ROMA Connect. For details, see Connecting to an OBS Data Source.
  1. On the Create Task page, configure parameters for fault information storage.
    Table 1 Parameters for fault information storage
    Integration Application
    Select the integration application to which the OBS data source belongs.
    Data Source Type
    This parameter can only be set to OBS.
    Name
    Select the OBS data source that you configured.
    Path
    Enter the object name of the OBS data source where abnormal data is to be stored. The value of Path cannot end with a slash (/).
  2. If you need to configure the post-integration operation, go to (Optional) Configuring the Post-Integration Operation. Otherwise, click Create to complete the data integration task configuration.
