Connecting to a DB Instance from a Linux ECS over a Private Network
You can connect to your DB instance using a Linux ECS with a PostgreSQL client installed over a private network.
You can connect to the instance using SSL through the PostgreSQL client. SSL connections encrypt data in transit and provide enhanced security.
SSL is enabled by default when you create an RDS for PostgreSQL DB instance and cannot be disabled after the instance is created.
Enabling SSL reduces the read-only and read/write performance of your instance by about 20%.
Step 1: Buy an ECS
- Log in to the ECS console and check whether there is an ECS available. Figure 1 ECS
- Buy an ECS and select Linux (for example, CentOS) as its OS.
To download a PostgreSQL client to the ECS, bind an EIP to the ECS. The ECS must be in the same region, VPC, and security group as the RDS for PostgreSQL DB instance for mutual communications.
For details about how to purchase a Linux ECS, see Purchasing an ECS in Elastic Cloud Server User Guide.
- On the ECS Information page, view the region and VPC of the ECS. Figure 2 ECS information
- Log in to the RDS console.
- Click the target RDS for PostgreSQL instance name. On the Summary page, find its region and VPC. Figure 3 Summary
- Check whether the ECS and RDS for PostgreSQL instance are in the same region and VPC.
- If yes, go to Installing a PostgreSQL Client (PostgreSQL 15 and Earlier).
- If they are not in the same region, purchase another ECS. The ECS and DB instance in different regions cannot communicate with each other. To reduce network latency, deploy your DB instance in the region nearest to your workloads.
- If the ECS and DB instance are in different VPCs, change the VPC of the ECS to that of the DB instance. For details, see Changing a VPC.
Step 2: Test Connectivity and Install a PostgreSQL Client
- Log in to the ECS. For details, see Logging In to a Linux ECS Using VNC in Elastic Cloud Server User Guide.
- On the Instances page of the RDS console, click the DB instance name.
- Choose Connectivity & Security from the navigation pane. In the Connection Information area, obtain the floating IP address and database port of the DB instance. Figure 4 Connection information
- On the ECS, check whether the floating IP address and database port of the DB instance can be connected.
curl -kv 192.168.0.7:5432
- If the command output contains Connected to ip (ip) port port_number (#0), the network is normal and they can communicate with each other.
- If no such information is returned, they cannot communicate with each other. Check the security group rules.
- If in the security group of the ECS, there is no outbound rule with Destination set to 0.0.0.0/0 and Protocol & Port set to All, add an outbound rule for the floating IP address and port of the DB instance. Figure 5 ECS security group
- If in the security group of the DB instance, there is no inbound rule allowing the access from the private IP address and port of the ECS, add an inbound rule for the private IP address and port of the ECS. For details, see Configuring a Security Group Rule.
- Install a PostgreSQL client.
The PostgreSQL community provides client installation methods for different OSs. You can download and install a client using the installation tool of the OS. This installation method is simple but can be used only for the OSs supported by the PostgreSQL community.
In this example, CentOS 7 is used. Use the default installation tool of the OS to install a client (PostgreSQL 15 or earlier).
Figure 6 Obtaining the installation tool
Run the installation commands:
sudo yum install -y https://download.postgresql.org/pub/repos/yum/reporpms/EL-7-x86_64/pgdg-redhat-repo-latest.noarch.rpm sudo yum install -y postgresql15-server
Check whether the installation is successful.
psql -V
Figure 7 Successful installation
- Choose Connectivity & Security from the navigation pane. In the Connection Information area, obtain the floating IP address and database port of the DB instance. Figure 8 Connection information
- If in the security group of the ECS, there is no outbound rule with Destination set to 0.0.0.0/0 and Protocol & Port set to All, add an outbound rule for the floating IP address and port of the DB instance. Figure 9 ECS security group
Installation from source code: This installation method has no restrictions on RDS for PostgreSQL instance versions and ECS OS types.
The following uses an ECS using the Huawei Cloud EulerOS 2.0 image as an example to describe how to install a PostgreSQL 16.4 client.
Figure 10 Checking the ECS image
- To use SSL, download OpenSSL to the ECS in advance.
sudo yum install -y openssl-devel
- Obtain the code download link, and run wget to download the installation package to the ECS, or download the installation package to the local PC and then upload it to the ECS.
wget https://ftp.postgresql.org/pub/source/v16.4/postgresql-16.4.tar.gz
- Decompress the installation package.
tar xf postgresql-16.4.tar.gz
- Compile the source code and install the client.
cd postgresql-16.4 ./configure --without-icu --without-readline --without-zlib --with-openssl make -j 8 && make install
If --prefix is not specified, the default path is /usr/local/pgsql. The client can be installed in the simplest way.
Figure 11 Compilation and installation
- Add the following code to the /etc/profile file to configure environment variables:
export PATH=/usr/local/pgsql/bin:$PATH export LD_LIBRARY_PATH=/usr/local/pgsql/lib:$LD_LIBRARY_PATH source /etc/profile
- Test whether the psql is available.
psql -V
Figure 12 Testing psql
Step 3: Connect to the DB Instance Using a CLI (SSL Connection)
- On the Instances page, click the DB instance name.
- In the navigation pane, choose Connectivity & Security.
- In the Connection Information area, click
next to the SSL field to download Certificate Download.zip, and extract the root certificate ca.pem and bundle ca-bundle.pem from the package. Figure 13 Downloading a certificate
- Upload the root certificate ca.pem to the ECS.
- TLS v1.2 or later is recommended. Versions earlier than TLS v1.2 have security risks.
- The recommended protocol algorithm is EECDH+ECDSA+AESGCM:EECDH+aRSA+AESGCM:EDH+aRSA+AESGCM:EDH+aDSS+AESGCM:!aNULL:!eNULL:!LOW:!3DES:!MD5:!EXP:!SRP:!RC4. Using other options have security risks.
- ca-bundle.pem contains both the new certificate provided as of April 2017 and the old certificate.
- Both ca.pem and ca-bundle.pem can be used for SSL connections because ca-bundle.pem contains ca.pem.
- Run the following command on the ECS to connect to the DB instance:
psql --no-readline -h <host> -p <port> "dbname=<database> user=<user> sslmode=verify-ca sslrootcert=<ca-file-directory>"
Example:
psql --no-readline -h 192.168.0.7 -p 5432 "dbname=postgres user=root sslmode=verify-ca sslrootcert=/root/ca.pem"
Table 1 Parameters Parameter
<host>
Floating IP address obtained in 3.
<port>
Database port obtained in 3. The default value is 5432.
<database>
Name of the database to be connected. The default database name is postgres.
<user>
Administrator account root.
<ca-file-directory>
Directory of the CA certificate used for the SSL connection. This certificate should be stored in the directory where the command is executed.
sslmode
SSL connection mode. Set it to verify-ca to use a CA to check whether the service is trusted.
- Enter the password of the database account as prompted.
Password:
If the following information is displayed, the connection is successful.SSL connection (protocol: TLSv1.2, cipher: ECDHE-RSA-AES256-GCM-SHA384, bits: 256, compression: off)
Follow-up Operations
After logging in to the DB instance, you can create or migrate databases.
