Help Center/ CodeArts Req/ User Guide/ IPD-System Device Projects/ Review/ Creating and Reviewing Baseline Reviews (BRs)
Updated on 2024-05-21 GMT+08:00
When a baseline needs to be set for an R&D requirement or system feature, you can create a BR.
A project has been created.
Creating a BR
  1. On the project homepage, choose Review > Baseline Review.
  2. Click BR. The BR page is displayed.
    Configure whether to display Require Decision-Making on the review creation page or review editing page by referring to Configuring Review Settings. If Require Decision-Making is set to No, Decisioning will not be displayed on the status navigation bar of the corresponding details page.
  3. Enter BR information.
    Baseline Object: Add the objects to be baselined, including system features and R&D requirements. Only system features and R&D requirements that are not baselined can be added.
    Associated Files: Add files related to the change object.
  4. Select Approver and Reviewer.
    If Require Decision-Making is set to No, Approver will not be displayed.
    If Reviewer is not selected, the review phase will be skipped.
  5. Click Submit to create a BR.
    You can view the new BR in the BR list.
Reviewing a BR
This operation is performed by reviewers and the approver.
  2. Click a BR which is in the To Be Reviewed or To Be Approved state.
  3. Review a BR.
    • If Require Decision-Making is set to Yes, perform the following operations:
      1. Click Decide by reviewer.
      2. Select a decision-making result, enter Comments, and click OK.
        Check the completed BR in the BR list. The review status changes to Passed, Rejected, To Be Approved, or Turn back based on the review result.
    • If Require Decision-Making is set to No, perform the following operations:
      1. Click Reviewer Review.
      2. Select a review result, enter comments, and click OK.
        The approved BR is now in the To Be Approved, Rejected, or To Be Reviewed state.
      3. Perform 3.a to 3.b to complete the BR approval.
