Help Center/ CodeArts Pipeline/ User Guide/ CodeArts Pipeline Usage
Updated on 2025-11-24 GMT+08:00
CodeArts Pipeline is a visual platform that facilitates automated task scheduling. It relies on the automated tasks in other CodeArts services such as Build, Check, TestPlan, and Deploy.
You can orchestrate these automated tasks based on your requirements, such as application deployment in the development, test, or production environment. A single configuration triggers executions to save manual operations.
CodeArts Pipeline is a service provided by the CodeArts solution. For details about its role in the solution, see CodeArts Architecture.
Operation Process
Figure 1 Pipeline operation process
Table 1 Description of the operation process
Process
Enable and authorize CodeArts Pipeline
Enable and authorize CodeArts Pipeline.
Create a pipeline
Create a pipeline through either the GUI or YAML. Configure parameters, pipeline triggers, roles and permissions, and event notifications for the pipeline.
Execute the pipeline
Execute a pipeline manually or through schedulers.
Check the pipeline
Check pipeline information and execution results.
