Pipeline Contexts
About Contexts
Pipeline contexts store and transfer pipeline information during pipeline running. They store information such as pipeline instances, variables, and tasks. Each context is an object that contains various attributes. You can use pipeline contexts to transfer information among jobs to streamline a pipeline. The following table lists pipeline contexts.
Context |
Type |
Description |
pipeline |
object |
Information about the pipeline run. |
sources |
object |
Information about the pipeline sources in each pipeline run. |
env |
object |
Information about the custom parameters in each pipeline run. |
jobs |
object |
Information about jobs that have been executed in each pipeline run. |
Context Reference Format
${{ <context>.<attribute_name> }}
- context: pipeline context.
- attribute_name: attribute.
Contexts Attributes
Context |
Attribute |
Type |
Description |
Example |
pipeline context |
pipeline |
object |
Information about the pipeline run. This object contains the following attributes: project_id, pipeline_id, run_number, timestamp, trigger_type, and run_id. |
pipeline.project_id |
string |
ID of the project to which the current pipeline belongs. This string is the same as the predefined parameter PROJECT_ID. |
pipeline.component_id |
string |
ID of the microservice to which the current pipeline belongs. This string is the same as the predefined parameter COMPONENT_ID. |
pipeline.pipeline_id |
string |
Current pipeline ID. This string is the same as the predefined parameter PIPELINE_ID. |
pipeline.run_number |
string |
Pipeline execution number. This string is the same as the predefined parameter PIPELINE_NUMBER. |
pipeline.timestamp |
string |
Pipeline execution timestamp. This string is the same as the predefined parameter TIMESTAMP. The format is yyyyMMddHHmmss. For example, 20211222124301. |
pipeline.trigger_type |
string |
Pipeline trigger type. This string is the same as the predefined parameter PIPELINE_TRIGGER_TYPE. |
pipeline.run_id |
string |
Pipeline execution ID. This string is the same as the predefined parameter PIPELINE_RUN_ID. |
pipeline.execute_user_name |
string |
Name of the user who executes the pipeline. This string is the same as the predefined parameter EXECUTE_USER_NAME. |
pipeline.external_system |
string |
External system that triggers the pipeline. This string is the same as the predefined parameter EXTERNAL_SYSTEM. This parameter is available only when the pipeline is triggered by an external system. |
pipeline.external_user_id |
string |
The ID of the user who triggered the pipeline via an external system. This string is the same as the predefined parameter EXTERNAL_USER_ID. |
pipeline.external_user_name |
string |
The name of the user who triggered the pipeline via an external system. This string is the same as the predefined parameter EXTERNAL_USER_NAME. |
pipeline.upstream_status |
string |
Status of the pipeline upstream stages. |
sources context |
sources |
object |
Information about the pipeline sources in each pipeline run. This object contains the following attributes: alias, repo_name, commit_id, commit_id_short, commit_message, repo_url, repo_type, repo_name, ssh_repo_url, tag, merge_id, source_branch, and target_branch. |
sources.<alias> |
object |
Information about the pipeline source which has an alias. |
sources.<repo_name> |
object |
Information about the pipeline source which does not have an alias but only a repository name. It contains the same information as that in sources.<alias>. |
sources.<alias>.commit_id |
string |
The last commit ID before execution. This string is the same as the predefined parameter COMMIT_ID. |
sources.<alias>.commit_id_short |
string |
The first 8 characters of the last commit ID before execution. This string is the same as the predefined parameter COMMIT_ID_SHORT. |
sources.<alias>.commit_message |
string |
The commit information from the last code commit before the pipeline execution. |
sources.<alias>.repo_url |
string |
Code repository address (HTTPS). This string is the same as the predefined parameter REPO_URL. |
sources.<alias>.repo_type |
string |
Type of the code repository. For example, codehub, gitlab, github, gitee, and general_git. |
sources.<alias>.repo_name |
string |
Name of the code repository. |
sources.<alias>.ssh_repo_url |
string |
Code repository address (SSH). |
sources.<alias>.tag |
string |
Tag name when the tag is triggered. |
sources.<alias>.merge_id |
string |
Merge request ID when the merge request is triggered. |
sources.<alias>.source_branch |
string |
Source branch name when the merge request is triggered. |
sources.<alias>.target_branch |
string |
If the merge request is triggered, this string indicates the name of the target branch. Otherwise, this string indicates the name of the running branch. |
env context |
name |
string |
Name of a custom parameter. |
value |
string |
Value of a custom parameter. |
jobs context |
jobs |
object |
Information about jobs in a pipeline. This object contains the following attributes: job_id, status, outputs, output_name, metrics, and metric_name. |
jobs.<job_id> |
object |
Information about the job with a specified ID. |
jobs.<job_id>.status |
string |
Job execution result. The value can be INIT, QUEUED, RUNNING, CANCELED, COMPLETED, FAILED, PAUSED, IGNORED, SUSPEND, or UNSELECTED. |
jobs.<job_id>.outputs |
object |
The running value, as a key-value pair. |
jobs.<job_id>.outputs.<output_name> |
string |
The running value name. |
jobs.<job_id>.metrics |
object |
The running metrics of a job. For example, the number of code check issues and the test pass rate. |
jobs.<job_id>.metrics.<metric_name> |
string |
The running metric name of a job. |
Related Information
The following are context scenarios:
