- Billing
- Getting Started
User Guide
- Before You Start
- Buying an Instance
- Instance Management
Enterprise Administrator Guide
- Logging In to the OneAccess Administrator Portal
- User Management
Resources
- Overview
Applications
- Adding an Application
- Enabling, Disabling, or Deleting an Application
- General Information
- Authentication Integration
- Synchronization Integration
- Login Configuration
- Access Control
- Object Models
- Authorization Management
- API Permission Management
- Application Permission Management
- Security Settings
- Audit Logs
- APIs
- Authentication
- Security
- Audit
- Settings
- Common User Guide
- Key Operations Recorded by CTS
Best Practices
- OneAccess Best Practices
- Identity Source Integration
Application Integration
Logging In to the Huawei Cloud Through User Portal
- Introduction
- Logging In to Single Huawei Cloud Account via OneAccess Without Password (SAML - Virtual User SSO)
- Logging In to Multiple Huawei Cloud Accounts via OneAccess Without Password (SAML - Virtual User SSO)
- Logging In to Single Huawei Cloud Account via OneAccess Without Password (SAML - IAM User SSO)
- Logging In to Multiple Huawei Cloud Accounts via OneAccess Without Password (SAML - IAM User SSO)
- Logging In to Huawei Cloud via OneAccess Without Password (OIDC)
- SSO Access to Applications Through SAML
- SSO Access to Applications Through OAuth 2.0
- SSO Access to Applications Through OIDC
- SSO Access to Applications Through CAS
- SSO Access to Applications Through Plug-in Autocompletion
- Data Synchronization
- Authentication Provider Integration
- Authorizing IAM Users to Access a OneAccess Instance Administrator Portal
- API Usage
- Configuring MFA for User Login
- Developer Guide
API Reference
- Before You Start
- API Overview
OneAccess APIs
Management APIs
- Calling APIs
- Access Credentials
User Management
- Creating a User
- Modifying a User
- Deleting a User
- Enabling a User
- Disabling a User
- Changing a User Password
- Verifying and Modifying the Original User Password
- Querying User Details by User ID
- Querying User Details by Username
- Querying the User List
- Authorizing an Application Account
- Querying All Authorized Application Accounts of a User
- Organization Management
- Application Organization Management
- Application Account Management
- Application Role Management
- User APIs
- Application Integration APIs
Management APIs
- Appendix
- FAQs
Managing Shared Accounts
A shared account is used by multiple users. You can configure a responsible person to authorize the users to manage the account. For details, see Shared Accounts.
If synchronization parameters have been configured and the synchronization is normal, adding, editing, and deleting shared accounts will trigger synchronization to downstream applications. For details, see Synchronizing Data to Applications Through Event Callback.
Adding Accounts
- Log in to the administrator portal.
- On the top navigation bar, choose Resources > Applications.
- On the displayed page, click an application name to access the application details page.
- Click the application icon to access the general information page.
- In the navigation pane on the left, choose Authorization > Shared Accounts to access the shared accounts page.
- Click add Accounts and enter the account information.
- Click Next. On the displayed page, add a responsible person, and click Save. The added shared account is displayed in the shared account list.
- If the entered responsible person exists, after you click Save, the responsible person of the shared account is displayed.
- If the entered username does not exist, the responsible person of the shared account is empty.
- If the responsible person of the shared account is empty, you can add one. For details, see Responsible person.
- The account attributes displayed on the shared account adding page can be configured based on the attribute definition of the application account. For details, see Application Accounts.
Enabling or Disabling an Account
- Click
in the Status column of the target account to disable the account or click
to enable the account.
- If a user only has permission to use a shared account, disabling the account will remove the application from the user's portal and prevent access. Enabling the account will display the application for access on the user's portal again. For details about how to access an application, see Logging In to the User Portal and Accessing Applications.
- If a user can use a shared account and also owns an application account, the application is still displayed on the user portal of the user after the shared account is disabled. When the user accesses the application, the application account information is used. After the shared account is enabled, the user can select an account for accessing the application. For details about how to access an application, see Logging In to the User Portal and Accessing Applications.
Modifying an Account
- Click Modify in the Operation column of the target shared account to modify the shared account information. The account attributes displayed on this page can be configured based on the attribute definition of the application account. For details, see Application Accounts.
Adding a Responsible Person
- Choose More > Principal in the Operation column of the target account. In the displayed dialog box, enter the username of the new responsible person.
- Click OK to adding a responsible person. The user can manage users through the shared account on the user portal. For details, see Shared Accounts.
Adding a User
- Choose More > Select Users in the Operation column of the target account. On the displayed page, select the users to be authorized.
- Click Save. The user is added. After logging in to the user portal, the responsible person can manage authorized users through the shared account. For details, see Shared Accounts.
Deleting an Account
- In the Operation column of the target shared account, choose More > Delete.
- Click OK to delete the account.
