- Billing
- Getting Started
User Guide
- Before You Start
- Buying an Instance
- Instance Management
Enterprise Administrator Guide
- Logging In to the OneAccess Administrator Portal
- User Management
Resources
- Overview
Applications
- Adding an Application
- Enabling, Disabling, or Deleting an Application
- General Information
- Authentication Integration
- Synchronization Integration
- Login Configuration
- Access Control
- Object Models
- Authorization Management
- API Permission Management
- Application Permission Management
- Security Settings
- Audit Logs
- APIs
- Authentication
- Security
- Audit
- Settings
- Common User Guide
- Key Operations Recorded by CTS
Best Practices
- OneAccess Best Practices
- Identity Source Integration
Application Integration
Logging In to the Huawei Cloud Through User Portal
- Introduction
- Logging In to Single Huawei Cloud Account via OneAccess Without Password (SAML - Virtual User SSO)
- Logging In to Multiple Huawei Cloud Accounts via OneAccess Without Password (SAML - Virtual User SSO)
- Logging In to Single Huawei Cloud Account via OneAccess Without Password (SAML - IAM User SSO)
- Logging In to Multiple Huawei Cloud Accounts via OneAccess Without Password (SAML - IAM User SSO)
- Logging In to Huawei Cloud via OneAccess Without Password (OIDC)
- SSO Access to Applications Through SAML
- SSO Access to Applications Through OAuth 2.0
- SSO Access to Applications Through OIDC
- SSO Access to Applications Through CAS
- SSO Access to Applications Through Plug-in Autocompletion
- Data Synchronization
- Authentication Provider Integration
- Authorizing IAM Users to Access a OneAccess Instance Administrator Portal
- API Usage
- Configuring MFA for User Login
- Developer Guide
API Reference
- Before You Start
- API Overview
OneAccess APIs
Management APIs
- Calling APIs
- Access Credentials
User Management
- Creating a User
- Modifying a User
- Deleting a User
- Enabling a User
- Disabling a User
- Changing a User Password
- Verifying and Modifying the Original User Password
- Querying User Details by User ID
- Querying User Details by Username
- Querying the User List
- Authorizing an Application Account
- Querying All Authorized Application Accounts of a User
- Organization Management
- Application Organization Management
- Application Account Management
- Application Role Management
- User APIs
- Application Integration APIs
Management APIs
- Appendix
- FAQs
User Agreement Configuration
You and other administrators can configure agreements and privacy statements on the OneAccess console. This ensures that users are fully aware of their rights and limitations when they first log in or register with the user portal.
Enabling and Configuring the User Agreement
- Log in to the administrator portal.
- On the top navigation bar, choose Settings > Enterprise Settings.
- On the displayed page, choose User Agreement Configuration.
- (Optional) Click
to enable user agreement configuration.
By default, the user agreement configuration is disabled. Once this configuration is enabled, users will be required to check the service agreement and privacy terms during login or registration.
- Click Modify to set the agreement for different GUI languages.
- Click the button to insert an agreement. In the displayed dialog box, enter the agreement name and text. Repeat this operation for different interface languages.
- Click OK. The agreement name will be displayed in the text box, for example, I have read and agree to the {Agreement name}. You can click the agreement name in the text box to view its details.
You can insert up to 10 agreements at the same time.
- Click Save to finish the user agreement configuration.
Modifying the User Agreement
Ensure that the user agreement configuration has been enabled.
- Click Modify.
- Click the agreement name in the text box. In the displayed dialog box, modify the agreement name and content.
- Click OK. The modified agreement name is displayed in the text box.
Viewing Consented Users and Historical Agreement Versions
Ensure that you have configured user agreements.
- Click the agreement name to view the consented users and historical versions.
- The consented users tab allows you to see information about the users who have agreed to the terms, including the time of signing, username, name, version number, signing location, and signing result.
- The historical version tab allows you to see the agreement's version history, including the version numbers, number of consented users, effective date, and expiration date. You can click the view button in the Operation column to view historical agreements.
Disabling the User Agreement Configuration
- Click
to disable the user agreement configuration. Once this configuration is disabled, users will no longer need to check the service agreement and privacy terms during login or registration.
