On this page
Show all
SMS Gateway
Updated on 2024-12-30 GMT+08:00
The SMS gateway helps users receive SMS messages and verification codes, giving them the choice between a built-in gateway or a custom gateway.
When users purchase and create OneAccess instances, the SMS message limit is automatically set. By default, users can send up to 1,000 SMS messages per month for free cost. If more SMS messages are required, users can adjust the SMS gateway settings or contact technical support to increase the limit.
  • Built-in gateway
    • The built-in gateway helps users obtain SMS messages and verification codes. On the SMS Gateway page, select Built-in gateway, and view the total and used SMS messages.
    • Check out the preset templates for different scenarios. In each situation, users will receive the preset SMS message or verification code.
    • To test the SMS message template for a specific scenario, click Test in the Operation column, specify a user, and click Test. Then check whether the user can receive the SMS message or verification code.
  • Custom gateway
    Register an account at the SMS service provider in advance and configure the gateway parameters in OneAccess. According to national message regulations, message template IDs and codes can be used only after the templates have been registered with and approved by the SMS service provider.
    Supported SMS service providers include Huawei Cloud, Alibaba Cloud, and Horiz. Huawei Cloud is used for illustration.
    1. Log in to the administrator portal.
    2. On the top navigation bar, choose Settings > Enterprise Settings.
    3. On the Enterprise Settings page, choose SMS Gateway in the navigation pane. On the displayed page, select Custom gateway and set the basic parameters.
      Table 1 Basic settings
      Mandatory
      SMS Service Provider
      Yes
      Select an SMS service provider, for example, Huawei Cloud.
      Access Key ID
      Yes
      APP_Key of an SMS application created on the SMS service platform.
      Access Key Secret
      Yes
      APP_Secret of the SMS application created on the SMS service platform.
      Signature
      Yes
      Signature applied on the SMS service platform.
      Verification Channel No.
      Yes
      Channel number generated when you apply for the verification signature on the SMS service platform.
      Notification Channel No.
      No
      Channel number generated when you apply for the notification signature on the SMS service platform.
      App Access Address
      Yes
      Access address of the SMS application created on the SMS service platform.
    4. In the Scenarios area, select a language, configure the template ID/code, and click Save.
      The ID/code of each template must be the same as that of the template applied on the SMS service platform.
    5. (Optional) Click Test in the Operation column of the target scenario, specify a user, and click Test to check whether the SMS gateway configuration is successful.
