Overview
You can manage applications, and enterprise APIs in a unified manner. This chapter describes how to do this with OneAccess.
Applications
Applications can be regarded as the downstream systems of an enterprise. OneAccess supports single sign-on (SSO) based on SAML, OAuth2, OIDC, and CAS. It also supports SDKs/APIs. After the configuration is complete, you can log in to the OneAccess user portal and sign in to multiple authorized applications in SSO mode. For details, see Logging In to the User Portal and Accessing Applications. Data can also be synchronized from OneAccess to applications based on event callback, SCIM, and LDAP
OneAccess has pre-integrated more than 1000 applications. You can add applications as needed.
For details about application management and authorization, see Adding an Application, Applications, and Enabling, Disabling, or Deleting an Application.
Enterprise APIs
OneAccess supports system and custom APIs.
- System API products: built-in API products of OneAccess.
- Custom API products.
You can also register open APIs with OneAccess and authorize access to specific applications.
System APIs and related permissions are defined by OneAccess. Custom APIs and related permissions are defined by yourself. System APIs can only be viewed and authorized.
For details about how to authorize and call system APIs, see Authorizing Access to Built-in APIs, Calling Built-in APIs, Modifying Built-in APIs, Adding a Custom API, Configuring a Custom API, and Deleting a Custom API.
