- What's New
- Function Overview
- Product Bulletin
Billing
- Billing Overview
- Billing Modes
- Billing Items
- Billing Examples
- Billing Mode Changes
- Renewing Subscriptions
- Bills
- Arrears
- Billing Termination
- Cost Management
Billing FAQ
- Why Do I Get Additional Charges or Arrears After Purchasing a Package?
- Why Can I Still Call the Service and Incur Arrears When My Account Balance Is Zero?
- Why Do I Get Additional Charges or Arrears After Unsubscribing from an OCR Service?
- Can I Refund a Package After I Buy It?
- How Is Billing Handled When a Package Is Used Up? And How Can I Check the Remaining Quota and Receive Alerts for My Package?
- How Does a Member Account Use a Package Purchased by an Enterprise Master Account?
- What Is Fee Deduction Order for Multiple Packages?
- What are Grace Period and Retention Period?
- What Is Considered Valid Billing for OCR?
- Can Different API Packages Be Shared?
- Can OCR Be Charged by Project?
- Getting Started
- User Guide
- SDK Reference
- API Reference
- Subscription
Token-based Authentication
- What Are the Username, Domain Name, and Project Name in the Token Message Body?
- Why Is the Error Message "The account is locked." Displayed?
- Why Is the Error Message "The username or password is wrong." Displayed?
- Why Does the Token Retrieval Process Return a 401 Status Code?
- Why Does the Token Fail to Be Obtained When I Use Postman to Call an ORC API?
- Why Don't I Have Programming Access Permissions?
- Why Does the Header Overflow When I Use Postman to Call an OCR API?
API
- How Do I View the API Usage?
- Why Is the Actual Number of API Calls Inconsistent with the Record Displayed on the Management Console?
- Does OCR Support Batch Processing?
- Can the OCR Results Be Converted into Word, TXT, or PDF Files?
- How Do I Obtain the Base64 Code of an Image?
- What Is the Number of Concurrent OCR API Calls?
- How Do I Use OCR APIs?
- Can the Region Where OCR Is Called Be Different from the Region Where OBS Resources Are Located?
- Can the Input Data of OCR Be Stored Locally?
- How Do I Improve the Recognition Speed?
- How Do I Convert a PDF to an Image?
- Can OCR Read Images from Non-Huawei Cloud Storage?
SDK
- Do OCR SDKs Need to Be Purchased?
- Do OCR SDKs Need Maven to Manage Dependency Packages?
- How Do I Change the Response Type in Returned Results?
- How Can I Fix an SSL Configuration Error?
- How Can I Fix a "connect timed out" Error?
- Why Does the Project ID Fail to Be Obtained?
- What Should I Do if I Forget My AK and SK?
Error Code
- Why Do I Fail to Call an OCR API?
- How Do I Handle the Error APIG.0301?
- How Do I Handle the Error APIG.0201?
- How Do I Handle the Error APIG.0101?
- How Do I Handle the Error APIG.0106?
- How Do I Handle the Error APIG.0308?
- How Do I Handle the Error ModelArts.0212?
- How Do I Handle the Error ModelArts.4603 or ModelArts.4704?
- How Do I Handle the Error ModelArts.4204?
- Permissions
- Data Security and Privacy
- Regions and AZs
- General Consulting
- Videos
- Glossary
- More Documents
Show all
Application Scenario
OCR uses Enterprise Project Management Service (EPS) to split fees for resources used by different user groups and users. An enterprise can plan different enterprise projects based on the organizational structure and set user groups and users with different permissions for each enterprise project. Multiple enterprise projects are independent of each other, and resources are settled separately.
- The enterprise project function can be enabled using enterprise accounts. Enterprise accounts must be authenticated by real enterprise names. For details, see Enterprise Real-Name Authentication. If an enterprise account is registered as a Huawei Cloud partner, it cannot be used to access the Enterprise Project Management page.
- After the enterprise project function is enabled, when users in an enterprise project call OCR APIs, accounting statistics can be collected by enterprise project only after the Enterprise-Project-Id parameter (enterprise project ID) is specified in the request header. For details about how to transfer parameters, see Optical Character Recognition API Reference.
- This function is available only to APIs deployed in the CN-Hong Kong, AP-Bangkok, and AP-Singapore regions. For details about API deployment, see Endpoints.
