Updated on 2026-08-21 GMT+08:00
OBS Monitoring Metrics
Functions
This section defines the namespace, list, and dimensions of monitoring metrics reported by OBS to Cloud Eye. You can use the Cloud Eye console or API to search for monitoring metrics and alarms generated by OBS.
Cloud Eye can monitor dimensions nested to a maximum depth of four levels (levels 0 to 3). 3 is the deepest level. For example, if the monitored dimension of a metric is bucket_name,api_name, bucket_name indicates level 0 and api_name indicates level 1.
Namespace
SYS.OBS
Background Information
Before using monitoring, you may need to know the following terms.
Table 1 Terms
Term
Example
P50 E2E latency
P50 latency is the median latency, which means that 50% of all requests finish below this threshold, while the remaining 50% exceed it.
P50 latency is 100 ms, meaning 50% of all requests finish within 100 ms, while the remaining 50% take longer.
P90 E2E latency
P90 latency means that 90% of all requests finish below this threshold, while the remaining 10% exceed it.
P90 latency is 200 ms, meaning 90% of all requests finish within 200 ms, while the remaining 10% take longer.
P95 E2E latency
P95 latency means that 95% of all requests finish below this threshold, while the remaining 5% exceed it.
P95 latency is 300 ms, meaning 95% of all requests finish within 300 ms, while the remaining 5% take longer.
P99 E2E latency
P99 latency means that 99% of all requests finish below this threshold, while the remaining 1% exceed it.
P99 latency is 500 ms, meaning 99% of all requests finish within 500 ms, while the remaining 1% take longer.
Monitoring Metrics
Table 2 OBS metrics (for requests)
Metric ID
Metric
Value Range
Unit
Conversion Rule
Dimension
Monitoring Interval (Raw)
get_request_count
GET Requests
Number of all GET requests made to all buckets and objects in the buckets of a region.
≥ 0
Count
N/A
bucket_name
1 minute
put_request_count
PUT Requests
Number of all PUT requests made to all buckets and objects in the buckets of a region.
≥ 0
Count
N/A
bucket_name
1 minute
post_request_count
POST Requests
Number of all POST requests made to all buckets and objects in the buckets of a region.
≥ 0
Count
N/A
bucket_name
1 minute
head_request_count
HEAD Requests
Number of all HEAD requests made to all buckets and objects in the buckets of a region.
≥ 0
Count
N/A
bucket_name
1 minute
delete_request_count
DELETE Requests
Number of all DELETE requests made to all buckets and objects in the buckets of a region.
≥ 0
Count
N/A
bucket_name
1 minute
first_byte_latency
First Byte Download Delay
Average time from receiving a GET request to the time that the system starts to respond in a measurement period.
≥ 0
ms
N/A
bucket_name
1 minute
request_count_4xx
4XX Status Codes
Number of requests whose status code returned by the server is 4xx.
≥ 0
Count
N/A
tenant_id
bucket_name
bucket_name,domain_name
1 minute
request_count_5xx
5XX Status Codes
Number of requests whose status code returned by the server is 5xx.
≥ 0
Count
N/A
tenant_id
bucket_name
1 minute
total_request_latency
Average Request Latency
Average time from receiving a request to the time that the system response ends in a measurement period.
≥ 0
ms
N/A
tenant_id
bucket_name
1 minute
total_request_callback_latency
Average Request Callback Latency
Average time required for calling a specific API in a request.
≥ 0
ms
N/A
bucket_name
1 minute
request_count_per_second
Total TPS
Average number of requests per second in a statistical period.
≥ 0
Count/s
N/A
tenant_id
bucket_name
1 minute
request_count_get_per_second
GET Request TPS
The average number of GET requests per second in a measurement period
≥ 0
Count/s
N/A
tenant_id
bucket_name
1 minute
request_count_put_per_second
PUT Request TPS
The average number of PUT requests per second in a measurement period
≥ 0
Count/s
N/A
tenant_id
bucket_name
1 minute
request_count_delete_per_second
DELETE Request TPS
The average number of DELETE requests per second in a measurement period
≥ 0
Count/s
N/A
tenant_id
bucket_name
1 minute
request_count_post_per_second
POST Request TPS
The average number of POST requests per second in a measurement period
≥ 0
Count/s
N/A
tenant_id
bucket_name
1 minute
request_count_head_per_second
HEAD Request TPS
The average number of HEAD requests per second in a measurement period
≥ 0
Count/s
N/A
tenant_id
bucket_name
1 minute
request_success_rate
Request Success Rate
Used to measure the availability of the storage service system. It refers to the percentage of non-server error requests (with status code 5xx returned) in the total request count. It is calculated as follows:
(1 – 5xx requests/Total requests) x 100%
≥ 0, ≤ 100
N/A
tenant_id
bucket_name
1 minute
effective_request_rate
Valid request rate
Validity of client requests. Percentage of the valid requests in the total requests. It is calculated as follows:
(Number of client requests whose returned status code is 2xx or 3xx/Total number of requests) x 100%
≥ 0, ≤ 100
N/A
tenant_id
bucket_name
1 minute
request_break_rate
Request interruption rate
Percentage of the number of requests interrupted by a client to the total number of requests. It is calculated as follows:
(Number of requests interrupted by a client/Total number of requests) x 100%
≥ 0, ≤ 100
N/A
tenant_id
bucket_name
1 minute
request_code_count
HTTP status code count
Measures the number of requests with status codes returned by the server. For details about the response status codes, see HTTP Status Codes.
≥ 0
Count
N/A
bucket_name
bucket_name,http_code
bucket_name,api_name,http_code
1 minute
api_request_count_per_second
API request TPS
Average number of specific API requests sent to all buckets and objects of a tenant per second within a statistical period. For details about the supported APIs, see Request APIs.
≥ 0
Count/s
N/A
bucket_name
1 minute
request_count_monitor_2XX
2xx Status Codes
Times that the server responds to requests whose status codes are 2xx.
≥ 0
Count
N/A
tenant_id
bucket_name
1 minute
request_count_monitor_3XX
3xx Status Codes
Times that the server responds to requests whose status codes are 3xx.
≥ 0
Count
N/A
tenant_id
bucket_name
1 minute
request_count_monitor_4XX
4XX Status Codes
≥ 0
Count
N/A
tenant_id
bucket_name
1 minute
download_bytes
Total Download Bandwidth
Total size of objects downloaded per second in a measurement period.
≥ 0
Byte/s
1024 (IEC)
tenant_id
bucket_name
1 minute
download_bytes_extranet
Download Bandwidth (Internet)
Total size of objects downloaded over the Internet per second in a measurement period.
≥ 0
Byte/s
1024 (IEC)
tenant_id
bucket_name
1 minute
download_bytes_intranet
Download Bandwidth (Intranet)
Total size of objects downloaded over the Intranet per second in a measurement period.
≥ 0
Byte/s
1024 (IEC)
tenant_id
bucket_name
1 minute
upload_bytes
Total Upload Bandwidth
Total size of objects uploaded per second in a measurement period.
≥ 0
Byte/s
1024 (IEC)
tenant_id
bucket_name
1 minute
upload_bytes_extranet
Upload Bandwidth (Internet)
The total size of objects uploaded over the Internet per second in a measurement period
≥ 0
Byte/s
1024 (IEC)
tenant_id
bucket_name
1 minute
upload_bytes_intranet
Upload Bandwidth (Intranet)
Total size of objects uploaded over the Intranet per second in a measurement period.
≥ 0
Byte/s
1024 (IEC)
tenant_id
bucket_name
1 minute
cdn_bytes
CDN Pull Bandwidth
The object size that CDN pulls per second from an origin server over the Internet in a given measurement period.
≥ 0
Byte/s
1024 (IEC)
tenant_id
bucket_name
1 minute
download_traffic
Total Download Traffic
Total size of objects downloaded in a measurement period.
≥ 0
Byte
1024 (IEC)
tenant_id
bucket_name
1 minute
download_traffic_extranet
Download Traffic (Internet)
The total size of objects downloaded over the Internet in a measurement period
The Internet download traffic includes the CDN pull traffic.
≥ 0
Byte
1024 (IEC)
tenant_id
bucket_name
1 minute
download_traffic_intranet
Download Traffic (Intranet)
Total size of objects downloaded over the Intranet in a measurement period.
≥ 0
Byte
1024 (IEC)
tenant_id
bucket_name
1 minute
download_traffic_infrequent_access
Download Traffic (Infrequent Access)
Total size of Infrequent Access objects downloaded in a measurement period.
≥ 0
Byte
1024 (IEC)
tenant_id
bucket_name
1 minute
upload_traffic
Total Upload Traffic
Total size of objects uploaded in a measurement period.
≥ 0
Byte
1024 (IEC)
tenant_id
bucket_name
1 minute
upload_traffic_extranet
Upload Traffic (Internet)
The total size of objects uploaded over the Internet in a measurement period
≥ 0
Byte
1024 (IEC)
tenant_id
bucket_name
1 minute
upload_traffic_intranet
Upload Traffic (Intranet)
Total size of objects uploaded over the Intranet in a measurement period.
≥ 0
Byte
1024 (IEC)
tenant_id
bucket_name
1 minute
cdn_traffic
CDN Pull Traffic
The total traffic generated when CDN pulls data from an origin server over the Internet in a given measurement period
≥ 0
Byte
1024 (IEC)
tenant_id
bucket_name
1 minute
upload_transfer_rate
Average Upload Rate
Size of objects uploaded per second in a measurement period.
≥ 0
Bytes/s
1024 (IEC)
bucket_name
1 minute
download_transfer_rate
Average Download Rate
Size of objects downloaded per second.
≥ 0
Bytes/s
1024 (IEC)
bucket_name
1 minute
request_get_size_le_1MB_latency
GET Request Latency (Object ≤ 1 MB)
Average latency of GET requests against objects no larger than 1 MB in a measurement period.
≥ 0
ms
N/A
bucket_name
1 minute
request_get_size_between_1MB_4MB_latency
GET Request Latency (1 MB < Object ≤ 4 MB)
Average latency of GET requests against objects that are larger than 1 MB but no larger than 4 MB in a measurement period.
≥ 0
ms
N/A
bucket_name
1 minute
request_get_size_between_4MB_10MB_latency
GET Request Latency (4 MB < Object ≤ 10 MB)
Average latency of GET requests against objects that are larger than 4 MB but no larger than 10 MB in a measurement period.
≥ 0
ms
N/A
bucket_name
1 minute
request_get_size_between_10MB_100MB_latency
GET Request Latency (10 MB < Object ≤ 100 MB)
Average latency of GET requests against objects that are larger than 10 MB but no larger than 100 MB in a measurement period.
≥ 0
ms
N/A
bucket_name
1 minute
request_get_size_gt_100MB_latency
GET Request Latency (Object > 100 MB)
Average latency of GET requests against objects larger than 100 MB in a measurement period.
≥ 0
ms
N/A
bucket_name
1 minute
request_put_size_le_1MB_latency
PUT Request Latency (Object ≤ 1 MB)
Average latency of PUT requests against objects no larger than 1 MB in a measurement period.
≥ 0
ms
N/A
bucket_name
1 minute
request_put_size_between_1MB_4MB_latency
PUT Request Latency (1 MB < Object ≤ 4 MB)
Average latency of PUT requests against objects that are larger than 1 MB but no larger than 4 MB in a measurement period.
≥ 0
ms
N/A
bucket_name
1 minute
request_put_size_between_4MB_10MB_latency
PUT Request Latency (4 MB < Object ≤ 10 MB)
Average latency of PUT requests against objects that are larger than 4 MB but no larger than 10 MB in a measurement period.
≥ 0
ms
N/A
bucket_name
1 minute
request_put_size_between_10MB_100MB_latency
PUT Request Latency (10 MB < Object ≤ 100 MB)
Average latency of PUT requests against objects that are larger than 10 MB but no larger than 100 MB in a measurement period.
≥ 0
ms
N/A
bucket_name
1 minute
request_put_size_gt_100MB_latency
PUT Request Latency (Object > 100 MB)
Average latency of PUT requests against objects larger than 100 MB in a measurement period.
≥ 0
ms
N/A
bucket_name
1 minute
upload_server_request_latency
Total Server-Side Upload Latency
Average time required for uploading objects on the OBS server.
≥ 0
ms
N/A
bucket_name
1 minute
upload_total_request_latency
Total E2E Upload Latency
Average end-to-end time required for uploading objects.
≥ 0
ms
N/A
bucket_name
1 minute
download_server_request_latency
Total Server-Side Download Latency
Average time required for downloading objects on the OBS server.
≥ 0
ms
N/A
bucket_name
1 minute
download_total_request_latency
Total E2E Download Latency
Average end-to-end time required for downloading objects.
≥ 0
ms
N/A
bucket_name
1 minute
request_size_le_1MB_latency_p99
P99 E2E Request Latency (Object ≤ 1 MB)
P99 E2E Latency of all requests for objects smaller than 1 MB.
≥ 0
ms
N/A
bucket_name
1 minute
request_size_between_1MB_4MB_latency_p99
P99 E2E Request Latency (1 MB < Object ≤ 4 MB)
P99 E2E Latency of all requests for objects ranging from 1 MB to 4 MB.
≥ 0
ms
N/A
bucket_name
1 minute
request_size_between_4MB_10MB_latency_p99
P99 E2E Request Latency (4 MB < Object ≤ 10 MB)
P99 E2E Latency of all requests for objects ranging from 4 MB to 10 MB.
≥ 0
ms
N/A
bucket_name
1 minute
request_size_between_10MB_100MB_latency_p99
P99 E2E Request Latency (10 MB < Object ≤ 100 MB)
P99 E2E Latency of all requests for objects ranging from 10 MB to 100 MB.
≥ 0
ms
N/A
bucket_name
1 minute
request_size_gt_100MB_latency_p99
P99 E2E Request Latency (Object > 100 MB)
P99 E2E Latency of all requests for objects larger than 100 MB.
≥ 0
ms
N/A
bucket_name
1 minute
request_size_le_1MB_latency_p95
P95 E2E Request Latency (Object ≤ 1 MB)
P95 E2E Latency of all requests for objects smaller than 1 MB.
≥ 0
ms
N/A
bucket_name
1 minute
request_size_between_1MB_4MB_latency_p95
P95 E2E Request Latency (1 MB < Object ≤ 4 MB)
P95 E2E Latency of all requests for objects ranging from 1 MB to 4 MB.
≥ 0
ms
N/A
bucket_name
1 minute
request_size_between_4MB_10MB_latency_p95
P95 E2E Request Latency (4 MB < Object ≤ 10 MB)
P95 E2E Latency of all requests for objects ranging from 4 MB to 10 MB.
≥ 0
ms
N/A
bucket_name
1 minute
request_size_between_10MB_100MB_latency_p95
P95 E2E Request Latency (10 MB < Object ≤ 100 MB)
P95 E2E Latency of all requests for objects ranging from 10 MB to 100 MB.
≥ 0
ms
N/A
bucket_name
1 minute
request_size_gt_100MB_latency_p95
P95 E2E Request Latency (Object > 100 MB)
P95 E2E Latency of all requests for objects larger than 100 MB.
≥ 0
ms
N/A
bucket_name
1 minute
request_size_le_1MB_latency_p90
P90 E2E Request Latency (Object ≤ 1 MB)
P90 E2E Latency of all requests for objects smaller than 1 MB.
≥ 0
ms
N/A
bucket_name
1 minute
request_size_between_1MB_4MB_latency_p90
P90 E2E Request Latency (1 MB < Object ≤ 4 MB)
P90 E2E Latency of all requests for objects ranging from 1 MB to 4 MB.
≥ 0
ms
N/A
bucket_name
1 minute
request_size_between_4MB_10MB_latency_p90
P90 E2E Request Latency (4 MB < Object ≤ 10 MB)
P90 E2E Latency of all requests for objects ranging from 4 MB to 10 MB.
≥ 0
ms
N/A
bucket_name
1 minute
request_size_between_10MB_100MB_latency_p90
P90 E2E Request Latency (10 MB < Object ≤ 100 MB)
P90 E2E Latency of all requests for objects ranging from 10 MB to 100 MB.
≥ 0
ms
N/A
bucket_name
1 minute
request_size_gt_100MB_latency_p90
P90 E2E Request Latency (Object > 100 MB)
P90 E2E Latency of all requests for objects larger than 100 MB.
≥ 0
ms
N/A
bucket_name
1 minute
request_count_monitor_6XX
6XX Status Codes
Number of requests whose status code returned by the server is 6xx.
≥ 0
Count
N/A
tenant_id
bucket_name
1 minute
request_count_monitor_7XX
7XX Status Codes
Number of requests whose status code returned by the server is 7xx.
≥ 0
Count
N/A
tenant_id
bucket_name
1 minute
get_mirror_range_bandwidths
Range Retrieval Bandwidth (Mirroring-based Back to Source)
Bandwidth for retrieving object ranges with mirroring-based back to source
≥ 0
Byte/s
1024 (IEC)
tenant_id
1 minute
get_mirror_fetch_bandwidths
Fetch Bandwidth (Mirroring-based Back to Source)
Bandwidth for fetches triggered by mirroring-based back to source
≥ 0
Byte/s
1024 (IEC)
tenant_id
1 minute
get_mirror_fetch_task_status
Fetch Status (Mirroring-based Back to Source)
Status of asynchronous fetches triggered by mirroring-based back to source. A value of 1 indicates that asynchronous fetches can be triggered, while a value less than 1 indicates that asynchronous fetches cannot be triggered.
≤ 1
Count
N/A
tenant_id
1 minute
standard_request_upload_bandwidths
Avg. Bandwidth for Uploading Standard Objects
Average size of all Standard objects uploaded using PUT and POST per second in a measurement period
≥ 0
Byte/s
1024 (IEC)
bucket_name
1 minute
infrequent_request_upload_bandwidths
Avg. Bandwidth for Uploading Infrequent Access Objects
Average size of all Infrequent Access objects uploaded using PUT and POST per second in a measurement period
≥ 0
Byte/s
1024 (IEC)
bucket_name
1 minute
archive_request_upload_bandwidths
Avg. Bandwidth for Uploading Archive Objects
Average size of all Archive objects uploaded using PUT and POST per second in a measurement period
≥ 0
Byte/s
1024 (IEC)
bucket_name
1 minute
standard_request_delete_bytes
Avg. Bandwidth for Deleting Standard Objects
Average size of all Standard objects deleted using DELETE per second in a measurement period
≥ 0
Byte/s
1024 (IEC)
bucket_name
1 minute
infrequent_request_delete_bytes
Avg. Bandwidth for Deleting Infrequent Access Objects
Average size of all Infrequent Access objects deleted using DELETE per second in a measurement period
≥ 0
Byte/s
1024 (IEC)
bucket_name
1 minute
archive_request_delete_bytes
Avg. Bandwidth for Deleting Archive Objects
Average size of all Archive objects deleted using DELETE per second in a measurement period
≥ 0
Byte/s
1024 (IEC)
bucket_name
1 minute
standard_request_download_bandwidths
Avg. Bandwidth for Downloading Standard Objects
Average size of all Standard objects downloaded using GET per second in a measurement period
≥ 0
Byte/s
1024 (IEC)
bucket_name
1 minute
infrequent_request_download_bandwidths
Avg. Bandwidth for Downloading Infrequent Access Objects
Average size of all Infrequent Access objects downloaded using GET per second in a measurement period
≥ 0
Byte/s
1024 (IEC)
bucket_name
1 minute
archive_request_download_bandwidths
Avg. Bandwidth for Downloading Archive Objects
Average size of all Archive objects downloaded using GET per second in a measurement period
≥ 0
Byte/s
1024 (IEC)
bucket_name
1 minute
standard_download_request_count
Avg. Standard Object Download Requests
Average number of GET requests for Standard objects per second in a measurement period
≥ 0
Count/s
N/A
bucket_name
1 minute
infrequent_download_request_count
Avg. Infrequent Access Object Download Requests
Average number of GET requests for Infrequent Access objects per second in a measurement period
≥ 0
Count/s
N/A
bucket_name
1 minute
archive_download_request_count
Avg. Archive Object Download Requests
Average number of GET requests for Archive objects per second in a measurement period
≥ 0
Count/s
N/A
bucket_name
1 minute
standard_upload_request_count
Avg. Standard Object Upload Requests
Average number of PUT and POST requests for Standard objects per second in a measurement period
≥ 0
Count/s
N/A
bucket_name
1 minute
infrequent_upload_request_count
Avg. Infrequent Access Object Upload Requests
Average number of PUT and POST requests for Infrequent Access objects per second in a measurement period
≥ 0
Count/s
N/A
bucket_name
1 minute
archive_upload_request_count
Avg. Archive Object Upload Requests
Average number of PUT and POST requests for Archive objects per second in a measurement period
≥ 0
Count/s
N/A
bucket_name
1 minute
Table 3 OBS metrics (for storage)
Metric ID
Metric
Value Range
Unit
Conversion Rule
Dimension
capacity_total
Total Used Storage Space
Measures the storage space occupied by all data.
≥ 0
Bytes
1024 (IEC)
tenant_id
bucket_name
30 minutes
capacity_standard
Used Space - Standard Storage
Measures the storage space occupied by Standard data.
≥ 0
Bytes
1024 (IEC)
tenant_id
bucket_name
30 minutes
capacity_infrequent_access
Used Space - Infrequent Access Storage
Measures the storage space occupied by Infrequent Access data.
≥ 0
Bytes
1024 (IEC)
tenant_id
bucket_name
30 minutes
capacity_archive
Used Space - Archive Storage
Measures the storage space occupied by Archive data.
≥ 0
Bytes
1024 (IEC)
tenant_id
bucket_name
30 minutes
capacity_deep_archive
Used Space - Deep Archive Storage
Measures the storage space occupied by Deep Archive data.
≥ 0
Byte
1024 (IEC)
tenant_id
bucket_name
30 minutes
capacity_standard_single_az
Standard Storage (Single-AZ)
Space occupied by Standard data stored in a single AZ
≥ 0
Byte
1024 (IEC)
tenant_id
bucket_name
30 minutes
capacity_standard_multi_az
Standard Storage (Multi-AZ)
Space occupied by Standard data stored in multiple AZs
≥ 0
Byte
1024 (IEC)
tenant_id
bucket_name
30 minutes
capacity_infrequent_access_single_az
Infrequent Access Storage (Single-AZ)
Space occupied by Infrequent Access data stored in a single AZ
≥ 0
Byte
1024 (IEC)
tenant_id
bucket_name
30 minutes
capacity_infrequent_access_multi_az
Infrequent Access Storage (Multi-AZ)
Space occupied by Infrequent Access data stored in multiple AZs
≥ 0
Byte
1024 (IEC)
tenant_id
bucket_name
30 minutes
object_num_all
Total Number of Objects
Total number of objects (including folders and all file versions) stored in all storage classes
≥ 0
Count
N/A
tenant_id
bucket_name
30 minutes
object_num_standard_total
Number of Objects - Standard Storage
Total number of objects (including folders and all file versions) stored in the Standard storage class
≥ 0
Count
N/A
tenant_id
bucket_name
30 minutes
object_num_infrequent_access_total
Number of Objects - Infrequent Access Storage
Total number of objects (including folders and all file versions) stored in the Infrequent Access storage class
≥ 0
Count
N/A
tenant_id
bucket_name
30 minutes
object_num_archive_total
Number of Objects - Archive Storage
Total number of objects (including folders and all file versions) stored in the Archive storage class
≥ 0
Count
N/A
tenant_id
bucket_name
30 minutes
object_num_deep_archive_total
Number of Objects - Deep Archive Storage
Total number of objects (including folders and all file versions) stored in the Deep Archive storage classes
≥ 0
count
N/A
tenant_id
bucket_name
30 minutes
object_num_standard_single_az
Standard Objects (Single-AZ)
Total number of Standard objects (including folders and all object versions) stored in a single AZ
≥ 0
count
N/A
tenant_id
bucket_name
30 minutes
object_num_standard_multi_az
Standard Objects (Multi-AZ)
Total number of Standard objects (including folders and all object versions) stored in multiple AZs
≥ 0
count
N/A
tenant_id
bucket_name
30 minutes
object_num_infrequent_access_single_az
Infrequent Access Objects (Single-AZ)
Total number of Infrequent Access objects (including folders and all object versions) stored in a single AZ
≥ 0
count
N/A
tenant_id
bucket_name
30 minutes
object_num_infrequent_access_multi_az
Infrequent Access Objects (Multi-AZ)
Total number of Infrequent Access objects (including folders and all object versions) stored in multiple AZs
≥ 0
count
N/A
tenant_id
bucket_name
30 minutes
If a metric has multiple monitoring dimensions, you need to specify each dimension when you use an API to query this metric.
For example, the request_code_count metric represents the number of requests with status code 400 for the bucket test-bucket. This metric has the dimensions of bucket_name,http_code, where bucket_name indicates level 0 and http_code indicates level 1.
  • To individually query this metric via API, specify the http_code dimension as follows:
    dim.0=bucket_name,test-bucket&dim.1=http_code,400
    test-bucket and 400 are the values of dimensions bucket_name and http_code, respectively. For details about how to obtain the values, see Dimensions.
  • To query this metric via API in a batch operation, specify the http_code dimension as follows:
    "dimensions": [
                         "name": "bucket_name",
                         "value": "test-bucket"
                         "name": "http_code",
                         "value": "400"
Dimensions
Table 4 Dimensions
Key
Value
tenant_id
User dimension. The value is an account ID.
To obtain the ID, see Obtaining Account, IAM User, Project, User Group, Region, and Agency Information.
bucket_name
Bucket dimension. The value is the bucket name. For details about the value, see Listing Buckets.
API dimension. For details about the value, see Table 5.
Domain name dimension. The value is the domain name of the bucket to be accessed. For details about the value, see Viewing Bucket Information.
  • tenant_id,http_code
  • bucket_name,http_code
  • bucket_name,api_name,http_code
HTTP return code dimension. For details about the values, see Table 6.
Request APIs
The following table lists the APIs supported by the bucket_name,api_name dimension in Table 4.
Table 5 Request APIs
ID
Name
LIST.BUCKETS
Listing Buckets
PUT.BUCKET
Creating a Bucket
LIST.BUCKET.OBJECTS
Listing Objects in a Bucket
LIST.BUCKET.OBJECTVERSIONS
Listing Objects in a Bucket (Versioning)
HEAD.BUCKET
Obtaining Bucket Metadata
GET.BUCKET.LOCATION
Obtaining Bucket Location
LIST.BUCKET.UPLOADS
Listing Multipart Uploads
POST.OBJECT.MULTIDELETE
Batch Deleting Objects
POST.OBJECT
Uploading Objects - POST
PUT.PART
Uploading Parts
PUT.PART.COPY
Copying Parts
DELETE.UPLOAD
Canceling a Part
LIST.OBJECT.UPLOAD
Listing Uploaded Parts of an Object
POST.UPLOAD.COMPLETE
Completing a Multipart Upload
POST.UPLOAD.INIT
Initiating a Multipart Upload
PUT.OBJECT
Uploading Objects
APPEND.OBJECT
Appending an Object
PUT.OBJECT.COPY
Copying an Object
DELETE.OBJECT
Deleting an Object
GET.OBJECT
Downloading an Object
HEAD.OBJECT
Heading objects
POST.OBJECT.RESTORE
Restoring an Object
PUT.OBJECT.METADATA
Modifying Object Metadata
HTTP Status Codes
The following table lists the HTTP status codes supported by the tenant_id,http_code, bucket_name,api_name,http_code, and bucket_name,http_code dimensions in Table 4.
Table 6 HTTP status codes
HTTP Status Code
400
Incorrect request packet format.
301
Permanent redirection. Retry according to the returned location.
307
Temporary redirection. When DNS updates, requests are redirected to the bucket.
401
Authentication and authorization failed.
403
Insufficient permission, access denied, limited MimeType, file type not allowed, or others
404
Requested resource not found
405
The specified method is not allowed against the requested resource.
406
CRC32 check failed for the uploaded data.
408
No read or write operations occurred within the timeout period of the socket connection between the client and the server.
409
There was a conflict with the current state of the requested resource.
411
The HTTP request did not include the required Content-Length header.
412
At least one of the specified preconditions was not met.
413
Incorrect size of the uploaded object.
414
The URI used in the request was too long.
416
The requested range could not be obtained.
429
There were too many requests in a short period of time.
499
The traffic on the client is interrupted or data transmission on the client times out.
500
Internal error. Please try again later.
501
The request method was not implemented by the server.
503
Service was unavailable because either an internal error occurred or high concurrency triggered connection throttling.
579
The object is successfully uploaded, but the callback fails.
599
The server fails to operate.
612
The specified resource does not exist or has been deleted.
614
The target resources already exist.
650
Access of monitoring callbacks to the origin server times out or fails.
701
The block expires, the segments are discontinuous, or the total block size does not match the object size.
