Help Center/ Migration Center/ User Guide/ New Edition/ Migration Plans (New)/ Creating a Batch File Storage Migration Plan
Updated on 2025-12-02 GMT+08:00
Follow this section to configure a migration plan for batch file system migration.
The Batch File Storage Migration template is designed to migrate file systems in batches. If only one file system needs to be migrated, create a migration workflow directly.
Preparations
Warnings
When creating a workflow, there are four overwriting policies for objects with the same name at the source and target: If older or different size, Never, Always, and If different CRC64 checksum. If you choose Never, restarting a migration after an interruption or pause may lead to incomplete data migration, even though the task may appear successful. This could impact data integrity, so use the Never option with caution.
  • Only the AP-Singapore and TR-Istanbul regions are supported.
  • Only one migration workflow can be created for a migration plan.
  • A migration plan can include a maximum of 100 file systems.
  • Target file systems included in a migration plan must be in the same region.
  • A target file system must have more available space than the total data volume of the paired source file system.
Step 1: Create a Migration Plan
  1. Sign in to the MgC console. In the navigation pane, under Project, select your application migration project from the drop-down list.
  2. In the navigation pane, choose Migration Plans (NEW).
  3. Click Create Migration Plan.
  4. Set migration plan parameters based on Table 1.
    Table 1 Parameters for creating a migration plan
    Configuration
    Migration Plan Template
    Select Batch File Storage Migration.
    Plan Name
    The system assigns a default plan name. You can also specify a plan name.
    Description (Optional)
    Enter a description.
  5. Click Confirm. The migration plan for batch file storage migration is created, and the page for configuring source and target resources is displayed.
Step 2: Configure Migration Resources
You can add resources in either of the following ways.
  1. On the Configure Source/Target page, from the Target Region drop-down list, select the region where the target file systems are located.
  2. In the File Systems area, click Add. A new row will be added below, allowing you to configure a source file system. Each click of this button will add another row, enabling you to include multiple source file systems in this plan.
  3. Configure source file systems based on Table 2.
    Table 2 Parameters for configuring source file systems
    Remarks
    Source Storage Type
    Supported source storage types include NAS_GFS, NAS_NFS_V3_PROTOCOL, NAS_NFS_V3_MOUNT, and NAS_SMB. Select a type based on your needs.
    NAS_GFS: Google Cloud file systems
    NAS_NFS_V3_PROTOCOL: file systems that support standard NFSv3
    NAS_NFS_V3_MOUNT: file systems that support non-standard NFSv3
    NAS_SMB: SMB/CIFS file systems
    Credential
    Select the credential from the drop-down list. If the credential has not been added, click Add Credential, enter a credential name, select an authentication mode, and enter the username, password, and domain. Click Confirm.
    • Username: Enter the username of the account that can access all files in the source file system, for example, administrator.
    • Password: Enter the password corresponding to the username.
    • (Optional) Domain: Open the console and run the following command to obtain the domain name.
      wmic computersystem get domain
      • You only need to enter the content before .com. For example, if the domain is test.com, enter test.
      • If the returned domain information is WORKGROUP, this parameter can be left empty.
    This parameter is mandatory when the source storage type is set to NAS_SMB.
    Source File System Address
    Enter the mount address of the source file system.
    • If the storage type is NAS_GFS, the file system address can include a host name, domain name, (optional) subdomain, port, and path.
    • If the storage type is NAS_NFS_V3_PROTOCOL or NAS_NFS_V3_MOUNT, the file system address must match any of the following formats:
      • <IP-address>:/
      • <IP-address>:/<path>
      • <domain-name>:/
      • <domain-name>:/<path>
    For both full and list migrations, a unique combination of source file system address and path or list path is required. In each case, the prefix matching rule applies.
    For example, if you have added the file system address 192.168.0.1:/a with a migration path /abc/a, an error will be reported if you try to add the file system address 192.168.0.1:/a with a migration path /abc. To overwrite an existing path, you need to delete the existing address and path combination first.
    Source Path
    Enter the directory that contains the files to be migrated. The format is /<folder-name>.
    For a list migration, enter / for the path.
    Target Storage Class
    Supported: NAS_NFS_V3_MOUNT (non-standard NFSv3 file systems)
    Target File System Address
    Enter the address of the target file system in the region you are migrating to. Input format: <IP-address>:/<path> or <domain-name>:/<path>, for example, 192.1.1.1:/0001
    • If a General Purpose file system is used as the target, enter the mount address of the file system. To obtain the mount address, go to the file system list and click the icon next to the address in the Mount Point column.
    • If an SFS Turbo file system is used as the target, enter the shared path of the file system. To obtain the shared path, go to the SFS Turbo file system list and click next to the path in the Shared Path column.
    Combinations of target file system addresses and paths can be duplicated.
    Target Path
    Enter the directory for storing migrated files. The format is /<folder-name>.
  4. Click Save in the Operation column. You can also click Save All after setting multiple records. After the settings are saved, batch modification is supported. Click Next to configure migration settings.
  2. In the area for adding resources, click Import to open the dialog box for importing file system settings.
  3. Click Download Template to download the import template. Configure file system information in the Excel template based on Table 3 and save the file.
    Table 3 Configuration details
    Remarks
    Source Storage Type
    Source Credential Name
    This parameter is optional. Enter the source credential name.
    This field is only required for NAS_SMB sources with connection credentials (usernames/passwords/domains) added to MgC.
      • <IP-address>:/
      • <domain-name>:/
    Source Path
    Target Storage Type
    The available options are NAS_NFS_V3_MOUNT (non-standard NFSv3 file systems) and NAS_SMB (SMB/CIFS file systems).
    Target Credential Name
    This parameter is optional. Enter the target credential name.
    This field is only required for NAS_SMB targets with connection credentials (usernames/passwords/domains) added to MgC.
    Target Path
    Migration Method
    The available migration methods are DEFAULT and LIST.
    DEFAULT indicates full migration. This method enables the migration of all data in a specific path in a source file system.
    LIST indicates list-based migration. This method enables the migration of specific files and folders recorded in predefined lists.
    Migration Scope
    If the list migration method is used, enter the path to the list files.
    If the full migration method is used, leave it blank.
  4. In the displayed dialog box, click Access OBS at the bottom.
  5. Select a bucket and upload the Excel file to the bucket. For details about how to upload the file, see Uploading a File to OBS.
  6. After the upload is successful, return to the MgC console. In the Import dialog box, select the file stored in the OBS bucket from the drop-down list.
  7. Click Confirm. The file storage information will be added to the page. Batch modification is supported. Click Next to configure migration settings.
Step 3: Configure Migration Settings
  1. In the Migration Method Configuration area, modify or remove resource. Select a migration method for each resource.
    • Full migration: This method enables the migration of all data in a specific path in a source file system.
    • List migration: This method enables the migration of specific files and folders recorded in predefined lists.
  2. In the Migration Settings area, set the parameters based on Table 4.
    Table 4 Migration settings
    Sub-parameter
    Migrate Metadata
    Determine whether to migrate metadata.
    • If you select this option, object metadata will be migrated.
    • If you do not select this option, only the Content-Type and Content-Encoding metadata will be migrated.
    Concurrent Subtasks
    User-defined. There cannot be more than 10 concurrent subtasks for each online migration node. For example, if there are 2 online migration nodes, the maximum number of subtasks can be 20 or any number below.
    Overwrite Existing
    NAS systems do not allow any files or folders with identical names, regardless of case. The migration fails if a source file has the same name as a target folder or vice versa.
    Never
    Files existing at the target will never be overwritten.
    WARNING:
    • If you choose Never for the initial migration, the attributes of involved parent folders at the source will not be migrated to the target. As a result, the folder attributes may be incomplete at the target. To avoid this issue, use the Never option with caution for the initial migration.
    • If you choose Never, restarting a migration after an interruption or pause may lead to incomplete data migration, even though the task may appear successful. This could impact data integrity, so use the Never option with caution.
    Always
    Files existing at the target will always be overwritten.
    • The system replaces existing target files if they are older than or differ in size from their source counterparts. Files with matching modification times and sizes remain unchanged and are skipped during migration.
    • The system verifies folders after their content is migrated. Folders that already exist at the target will be overwritten if they have different last modification times, sizes, or permissions from the paired folders at the source.
      The same overwriting policy is applied to empty folders as files.
    Limit Traffic
    Set the maximum bandwidth for the migration task during different periods.
    • If you do not select this option, migration traffic will not be limited.
    • If you select this option, you can limit the migration traffic by setting Start Time, End Time, and Bandwidth Limit.
      For example, if you set Start Time to 08:00, End Time to 12:00, and Bandwidth Limit to 20 MB/s, the maximum migration speed is limited to 20 MB/s from 08:00 to 12:00. The migration speed is not limited outside this period.
      • The bandwidth limit ranges from 1 MB/s to 1,048,576 MB/s.
      • A maximum of five rules can be added.
      • The time is the local standard time of the region you are migrating to.
  3. (Optional) Configure advanced options based on Table 5.
    Table 5 Advanced options
    Sync Incremental Before Cutover
    • If this option is selected, incremental data will be migrated before the migration reaches the cutover phase.
    • If this option is not selected, the migration will proceed directly to the cutover phase without transferring incremental data.
    Filter Source Data
    Use exclude patterns, include patterns, and time ranges to filter files to be migrated. For details about the filters, see Source Data Filters.
    Send SMN Notifications
    Determine whether to use SMN to get notifications about migration results.
    • If you do not select this option, no SMN messages will be sent after the migration is complete.
    • If you select this option, after the migration is complete, SMN messages will be sent to the subscribers of the selected topic. You can select the language and trigger conditions for sending messages.
  4. After the migration settings are configured, click Next to open the Configure Migration Cluster page.
Step 4: Configure a Migration Cluster
  1. In the Migration Cluster area, select the cluster to be used. To modify the cluster, click Modify in the Operation column and modify the cluster by referring to Managing a Migration Cluster.
  2. After the migration cluster is configured, click Next to open the confirmation page.
Step 5: Confirm the Configurations
After performing steps 1 to 4, check the resource and migration settings on the Confirm page. To update the settings, click Previous to return to the corresponding stage for modification.
Step 6: Perform Follow-Up Operations
After confirming that the configurations are correct, perform follow-up operations as required.
Click Complete to save the migration plan. Then you can:
On the Confirm page, click Create Workflow. The Start Workflow dialog box is displayed, indicating that the workflow has been created.
  • If you want to start the migration immediately, click OK to start the workflow and view the workflow details.
  • If you want to save the migration workflow without starting the migration, click Cancel. The migration workflow will move to a Waiting status, and the migration has not started yet. To run the workflow, click Run in the Operation column to manually start the migration.
For more information about migration workflows, see Creating a Batch File Storage Migration Workflow.
