Updated on 2025-09-12 GMT+08:00
Creating a Connection to a Target Component
To verify the consistency of data stored using big data components, you need to establish connections between MgC and the big data components.
The supported big data components include:
  • Doris
  • HBase
  • ClickHouse
  • Hive Metastore
  1. Sign in to the MgC console. In the navigation pane, under Project, select your big data migration project from the drop-down list.
  2. In the navigation pane, choose Migrate > Big Data Verification.
  3. In the Features area, click Migration Preparations.
  4. Choose Connection Management and click Create Connection.
    Figure 1 Creating a connection
  5. Select a big data component and click Next.
  6. Set parameters based on the big data component you selected.
    Table 1 Parameters for creating a connection to Doris
    Configuration
    Connection To
    Select Target.
    Connection Name
    The default name is Doris-4 random characters (including letters and numbers). You can also customize a name.
    MgC Agent
    Select the MgC Agent installed in the source environment.
    Doris Credential
    Select the credential added to the MgC Agent for accessing your target Doris cluster. For details about how to add credentials, see "Big data - Doris" in Adding Resource Credentials.
    Database IP Address
    Enter the IP address for accessing the target Doris cluster.
    You can log in to FusionInsight Manager and choose Cluster > Services > Doris > Instances to view the access IP address of the cluster.
    Database Port
    Enter the port for accessing the target Doris cluster.
    To obtain the port, log in to FusionInsight Manager, choose Cluster > Services > Doris > Configurations, and search for query_port.
    Database Name
    Enter the name of the target Doris database.
    Collect Usage Metrics
    This parameter is optional. If this option is enabled, usage metrics for your big data resources will be collected during the execution of tasks created using this connection. The collected information is used to generate reports on the MgC console and for performance optimization.
    NOTICE:
    Before using this function, ensure that the Huawei Cloud account you added to the MgC Agent has the read-only permission for MRS and DLI.
    • If the selected credential is the one you currently use to access MgC, you can select This is my MgC credential, and the projects in the region you choose will be listed.
      • Under Region, select the region where the data to be verified is located.
      • Under Project, select the project where the data to be verified is managed.
      • Under Cluster ID, enter the ID of the cluster where the data to be verified is located.
    • If the selected credential is not the one you currently use to access MgC:
      • Under Region ID, enter the ID of the region where the data to be verified is located. For example, if the region is CN South-Guangzhou, enter cn-south-1.
      • Under Project ID, enter the project ID corresponding to the region.
    Table 2 Parameters for creating a connection to HBase
    Configuration
    Connection To
    Select Target.
    Connection Name
    The default name is HBase-4 random characters (including letters and numbers). You can also customize a name.
    MgC Agent
    HBase Credential
    Select the credential added to the MgC Agent for accessing your target HBase cluster. For details about how to add credentials, see Big data - HBase in Adding Resource Credentials.
    Secured Cluster
    Choose whether the cluster is secured.
    ZooKeeper IP Address
    Enter the IP address for connecting to the target ZooKeeper node. You can enter the public or private IP address of the ZooKeeper server.
    ZooKeeper Port
    Enter the port number for connecting to the target ZooKeeper node. The default value is 2181.
    HBase Version
    Select the HBase version used by the target cluster.
    NOTICE:
    Table 3 Parameters for creating a connection to ClickHouse
    Configuration
    Connection To
    Select Target.
    Connection Name
    The default name is ClickHouse-4 random characters (including letters and numbers). You can also customize a name.
    MgC Agent
    ClickHouse Credential (Optional)
    Select the credential added to the MgC Agent for accessing your target ClickHouse cluster. For details about how to add credentials, see "Big data - ClickHouse" in Adding Resource Credentials.
    Secured Cluster
    ClickHouse Server IP Address
    Enter the IP address of the target ClickHouse server.
    HTTP Port
    If the ClickHouse cluster is unsecured, enter the HTTP port for communicating with the target ClickHouse server. The default value is 8123.
    HTTP SSL/TLS Port
    If the ClickHouse cluster is secured, enter the HTTPS port for communicating with the target ClickHouse server.
    NOTICE:
    Table 4 Parameters for creating a connection to Hive Metastore
    Configuration
    Connection To
    Select Target.
    Connection Name
    The default name is Hive-Metastore-4 random characters (including letters and numbers). You can also customize a name.
    MgC Agent
    Secure Connection
    Choose whether to enable secure connection.
    • If Hive Metastore is deployed in an unsecured cluster, do not enable secure connection.
    • If Hive Metastore is deployed in a secured cluster, enable secure connection and provide access credentials. For details about how to obtain and add credentials to MgC, see "Big data - Hive Metastore" in Adding Resource Credentials.
    Hive Version
    Select the target Hive version.
    CAUTION:
    Only version 3.x is available.
    Hive Metastore IP Address
    Enter the IP address for connecting to the Hive Metastore node.
    Hive Metastore Thrift Port
    Enter the port for connecting to the Hive Metastore Thrift service. The default port is 9083.
    Connect to Metadata Database
    During an incremental data verification, querying with Hive Metastore on more than 30,000 partitions may lead to a memory overflow (OOM) since all partition information is loaded into memory. Connecting to the MySQL metadata database can effectively prevent this issue.
    • If you disable this option, the system queries the information of Hive tables and partitions using Hive Metastore.
    • If you enable this option, configure the MySQL database information. The system will query the information of Hive tables and partitions through the MySQL database. You need to set the following parameters:
      • Metadata Database Type: Only MySQL is supported.
      • MySQL Credential: Select the credential for accessing the MySQL database. You need to add the credential to the MgC Agent and synchronize it to MgC. For details, see Adding Resource Credentials.
      • MySQL Node IP Address: Enter the IP address of the MySQL database server.
      • MySQL Port: Enter the port of the MySQL database service.
      • Database Name: Enter the name of the database that stores the Hive table metadata.
    Ensure that the entered MySQL credential, node IP address, service port, and database name match the MySQL database used by Hive. Otherwise, data verification will fail.
  7. Click Test. MgC verifies whether the component can be connected using the configuration information. If the test is successful, the cloud services can be connected.
  8. After the connection test is successful, click Confirm. The connection is created.
  9. On the Connection Management page, view the created connection and its basic information. In the Operation column, click Modify to modify the connection settings.
