SQL JOIN Syntax
The JOIN clause queries data in two or more tables. This section describes how to use the JOIN clause.
Syntax
select key from t1 LEFT|RIGHT|INNER JOIN t2 on t1.key=t2.key
Currently, LTS supports LEFT JOIN, RIGHT JOIN, and INNER JOIN.
| JOIN Mode | Description |
| LEFT JOIN | Join the right table (t2) based on the result of the left table (t1). If the table name contains only digits, add double quotation marks to the table name to convert it into a string. For example, if the table name is 123, enter "123" in the JOIN statement. |
| RIGHT JOIN | Join the left table (t1) based on the result of the right table (t2). |
| INNER JOIN | Intersection data of the results (elb1 and elb2) of two tables |
Examples
- LEFT JOIN
- Query statements
SELECT "access".__time, "access".host_ip, "access".cost, "host".cpu, "host".memory FROM log "access" LEFT JOIN (select memory,cpu,host_ip from log) host ON "access".host_ip = "host".host_ip
- 60 data records returned
- Query statements
- RIGHT JOIN
- Query statements
SELECT "access".__time, "host".host_ip, "access".cost, "host".cpu, "host".memory FROM log "access" RIGHT JOIN (select memory,cpu,host_ip from log) host ON "access".host_ip = "host".host_ip
- Query statements
- INNER JOIN
- Query statements
SELECT "access".__time, "host".host_ip, "access".cost, "host".cpu, "host".memory FROM log "access" INNER JOIN (select memory,cpu,host_ip from log) host ON "access".host_ip = "host".host_ip
- 45 data records returned
- Query statements
