Updated on 2026-09-18 GMT+08:00
Other SQL Functions
SQL functions also support some conversion types and logical operations such as CASE and WHEN. For details, see Table 1.
Syntax
SELECT CAST(fieldname1 AS VARCHAR) AS fieldname1_str
Other Function Statements
Table 1 Other function statements
Keyword
Example
CAST(value AS TYPE)
Converts the data type. Data types can be converted only to varchar or float.
SELECT fieldname1, CAST(fieldname1 AS VARCHAR)
CASE WHEN boolean_expr1 THEN result1 \[ WHEN boolean_expr2 THEN result2 ... \] \[ ELSE resultN \] END
Simple CASE function.
SELECT CASE WHEN httpStatus = 200 THEN 1 ELSE 0 END
NULLIF(value1, value2)
If value1 is equal to value2, null is returned. Otherwise, value1 is returned.
SELECT fieldname1, fieldname2, NULLIF(fieldname1, fieldname2)
NVL(expr,expr-for-null)
If expr is null or an empty string, this function returns expr-for-null.
SELECT NVL(str1, 'expr-for-null')
