Updated on 2025-09-07 GMT+08:00
SQL Query Example
This section describes how to query ELB raw logs in LTS.
  1. Log in to the LTS console.
  2. Choose Log Management in the navigation pane, and click a log group or stream to access the log details page.
  3. View logs on the Log Search tab page. The system obtains ELB raw logs.
  4. Click Log Settings in the upper right corner. On the displayed page, click the Cloud Structuring Parsing tab.
  5. Select Structuring Template, and configure log structuring based on the ELB template. For other logs, you can select other structuring templates.
  6. On the Visualization tab page, enter a SQL statement in the search box.
Display of Query Results
Table
The following statement queries the host, the number of logs of each request_uri, the request body size in MB, and the ratios of 2xx, 3xx, 4xx, and 5xx responses. Then the results are displayed in a table, and sorted in descending order by the number of logs.
SELECT "router_request_uri" as "request_uri", "host", COUNT(*) as pv,
round(sum(body_bytes_sent) / 1024.0 , 5) as "body_bytes_sent(MB)",
round(sum(case when status >= 200 and status < 300 then 1 else 0 end ) * 100.0 / COUNT(1), 6) as "2xx ratio(%)",
round(sum(case when status >= 300 and status < 400 then 1 else 0 end ) * 100.0 / count(1), 6) as "3xx ratio(%)",
round(sum(case when status >= 400 and status < 500 then 1 else 0 end ) * 100.0 / count(1), 6) as "4xx ratio(%)",
round(sum(case when status >= 500 and status < 600 then 1 else 0 end ) * 100.0 / count(1), 6) as "5xx ratio(%)"
GROUP BY "host", "router_request_uri"
ORDER BY pv DESC
LIMIT 100
Bar chart
The following statement queries the number of requests for each request URL and displays the results in a bar chart, with request_uri set as the X axis and pv as the Y axis.
ORDER BY pv DESC
LIMIT 100
Line chart
The following statement displays a line chart based on the query result, with _time_ set as the X axis and QPS as the Y axis. The chart shows the queries per second (QPS) change at an interval of 5s in the query period.
select TIME_FORMAT(TIME_CEIL(TIME_PARSE(SUBSTRING(time_iso8601, 2, 25) ,'yyyy-MM-dd''T''HH:mm:ssZZ'),'PT5S'),'yyyy-MM-dd HH:mm:ss','+08:00') AS _time_ , COUNT(*) as QPS from log group by _time_
Pie chart
The following statement queries the percentage of different values of status in the query period, and displays the results in a bar chart, with Category set to status and Value set to rm.
SELECT status, COUNT(1) AS rm GROUP BY status
Number chart
The following statement queries the total number of normal requests in the last hour and displays the results in a number chart.
SELECT count(*) AS normalRequest WHERE status = 200
